Trance X Pics Thread...
Printable View
  • 10-17-2012
    VERT1
    my custom 2011 X
  • 10-17-2012
    bloodpuddle
    Originally Posted by VERT1 View Post
    my custom 2011 X
    Very nice. :thumbsup:
    Are you running a single front chainring with derailleur as chain guide? Thinking about going the same way with mine.
  • 10-17-2012
    aizen
    my custom 2011 X
    Is that a 140mm fork upfront?
  • 10-17-2012
    BustedBearing
    my custom 2011 X
    What is the saddle you're using?
  • 10-20-2012
    alekosty
    My Trance X:
    Updates since I posted a pic here more than a year ago:
    - Shimano XT M785 brakes
    - Shimano XT 10-speed drivetrain
    - KS Supernatural seatpost
    - black grips
  • 10-20-2012
    Liternit
    guys I need a front derailleur for my new frame Trance X 2011, had a Bottom Swing but since the seatube has a curve it won´t work. Tried an old Derailleur but the cage was too short will any SLX/XT Bottom swing work?
    thanks
  • 10-20-2012
    Dirthugger
    The new Trance X posted here are all great looking. But I still prefer my 09 X...
  • 12-05-2012
    joncy
    My trance latest setup...
    Latest addition : raceface bash ring, Bionicon c.guide n joplin4
    Sent from my ST27i using Tapatalk 2
  • 12-05-2012
    joncy
    -deleted- Double post sorry....
  • 12-09-2012
    Aspean
    5 Attachment(s)
    There is my Trance X4 2011
    Changes:
    Kore Repute 50mm sterm
    Kore OCD 800mm flat bars, only on the first photo and they will be shortened to 750mm
    ESI Chunky grips
    XT BR-M785 brakes, XT Icetech rotors 203/180mm
    1x9 setup (32t and 11-34t casette) Shaman Drake seat mounted chain guide
    Force BMX Magnesium pedals
    2,4" NN TSC up front, 2,25" RaR PSC back
    Sweet ride for me :)
  • 12-19-2012
    mrstranger
    2011 Trance X 2.
    Planning on getting a dropper post and upgrade to XT shifters and brakes sometime next month.
  • 12-19-2012
    WarBoom
    2011 Giant Trance XL
    Fork- 2013 Fox Float CTD 140mm 15mm
    Shock- 2013 Fox Float CTD 7.5-2.0
    Wheels- American Classic All Mountain
    Tires- Michelin Wild Grip'r Advanced tubeless 26-2.25
    Saddle- Tioga Spyder D
    Bars- Thomson Carbon 730mm
    Headset- Chris King
    Stem- Thomson X4 90mm with red faceplate
    Grips- Oury
    Post- Thomson Elite
    Clamp- Loaded Xlite QR
    Brakes- Hayes Stroker Ace
    Rotors- Sram HSX 180f 160r
    Crank- RaceFace Turbine
    Chain Ring- RaceFace 34t
    Ring Bolts- Loaded
    Chain Guide- E13 XCX-ST
    Pedals- E13 LG1+
    Cassette- XT 10spd
    Derailleur- XT Shadow Plus
    Jockey Wheels- Hawk Racing Ceramic
    Shifter- XT
    Chain- KMC X10SL-TI
    I posted this here about 6 months ago but alot of the entire bike is new since then
    Its still 25lb and change
  • 12-20-2012
    jari777
    Loved!:thumbsup:
  • 01-04-2013
    lucifuge
    My 2012 Trance X Advanced SL 0 underwent surgery;
    Removed:
    1x Schwalbe Nobby Nic tubeless
    Giant Seatdropper (587gms)
    Specialized Gel Milano saddle (374gms)
    Added:
    Thomson Masterpiece 350mm (190gms)
    Thomson seatpost collar
    1x Schwalbe Rocket Ron tubeless ready
    Selle Italia gel flow saddle (240gms)
    12.1kg -> 11.3kg (26.8lbs -> 24.9lbs)
  • 01-04-2013
    pujetta
    Removed:
    Added:
    Cool
  • 01-04-2013
    gribble
    Well, I am finally building up my 2011 frame set, which arrived at the end of 2012.
    Have fitted forks, stem, bars, brakes, rear mech and front shifters. Need to sort out cables, wheels etc tomorrow. Still, it looks good in the sitting room.
    I am either getting a BB from the local bike store or online, but either way I wanted to check out the size. I posted a while ago on here and someone said for a Trance X that the BB was BB30, but the US bike shop I bought the frame from said Shimano BB91 (the cranks used will be shimano). Can anyone please confirm?
    Also, I need still to get myself a front mech, seat post and saddle. I plan to get another fizik gobi, as I found mine comfortable on my hardtail, unless anyone can recommend anything cheaper? Was also thinking of getting a layback post, as I have a size L frame and am 6ft 2, and have got a 50mm stem. Anyone got a layback post on theirs? Also, anyone know what size the front mech band needs to be?
    Any help much appreciated.
  • 01-04-2013
    mrstranger
    My DIRTY lady!! lol
  • 01-05-2013
    chadalex78
    5 Attachment(s)
    2011 custom X2..
    my trail machine...
  • 01-06-2013
    chadalex78
    Headset- Chris King
    Grips- Oury
    Post- Thomson Elite
    Ring Bolts- Loaded
    Pedals- E13 LG1+
    Cassette- XT 10spd
    Shifter- XT
    Chain- KMC X10SL-TI
    How do you like the 140mm fork? Thinking of going to a 140-150mm Talas on mine... Bet it brings out the best in the beast.
  • 01-06-2013
    chadalex78
    Wait a sec! you put a 7.5 on the rear?! how?! Huh what? does that work correctly?
  • 01-06-2013
    wooyek
    I ride my 2010 frame with 190x50 mm shock too. It is quite a good setup if you have 140 mm fork - angles are similar to stock and BB height isn’t dramatic. There is a table with my measurements with different setups:
    none at none in Katowice, Poland - photo by wooyek - Pinkbike
    BUT I decided that having more travel and same angles makes no sense and so I put one offset bushing in the upper eyelet of rear shock (-3 mm). It puts the length of the shock halfway between 190 mm and stock 184 mm, so you can easily imagine what the values from the table would be.
  • 01-07-2013
    WarBoom
    The 7.5 bolts right up no issues at all. It raises the bb less than .20 inches but gives an additional .75 inches in travel. So I have 140mm in back and 140mm out front. With the 140f and 140r the bb is .22-.25inches higher which is hardly noticeable to me as my bike is a XL anyways.
  • 01-10-2013
    desertrider1
    My 2011 Trance X
    Got the frame, moved some stuff from my RX. I'm very happy with the way this one
    rides. I did the Enduro shock bearing mod as well. Next on the list are a Kronolog post, and shadow plus 10 spd. drivetrain.
    JT
  • 01-10-2013
    chadalex78
    JT
    What enduro shock bearing mod?
  • 01-10-2013
    akaBrowntown
    Hope this doesnt come across as me being a smartass, but I think he means replacing the stock bearings with Enduro brand bearings.
    Enduro Bearings - precision bearings for mountian bike and road bicycle applications
    Anyone stick with the 26 opposed to going to the Trance 29?
