Page 76 of 91 FirstFirst ... 26 66 72 73 74 75 76 77 78 79 80 86 ... LastLast
Results 1,876 to 1,900 of 2251
  1. #1876
    Dec 2011
    2011 Trance XL X4
    fork- 2013 Fox Float 140 15mm
    shock- Fox RP3 7.5x2.0 instead of stock 7.125x1.750
    brakes- Hayes Stoker Ace
    rotors- Avid HSX 180mm, 160mm (on it now), Alligator Wind-Cutter (in pic)
    Grips- Oury
    H bar- Loaded AMXC 710mm
    Stem- Loaded X-Lite 90mm
    Wheels- America Classic All Mountain
    Tires- Michelin Advanced Wild Grip'r
    Crank- Raceface Turbine with RF ring
    Guide- E13 XCX-ST
    Pedals- Loaded Cromo (on it now) HTs (in pic)
    Post- Thompson Elite
    Seat- WTB Speed-V
    Clamp- Loaded X-Lite
    25lbs and change with the HT pedals it should be 5lb 3oz with loaded pedals and I can will still lose more with a XTR rear der and cass which will be soon
    My bike isnt light because I have light parts but because I have taken off alot of parts lol
    Attached Thumbnails Attached Thumbnails Trance X Pics Thread...-photo_4-4-.jpg
  2. #1877
    Reputation: BustedBearing's Avatar
    XL frame & a setback seatpost, you must be big!
    When installing a bigger shock, isn't there any problems with the lower link touching the bottom bracket?
  3. #1878
    Dec 2011
    Quote Originally Posted by BustedBearing View Post
    I am 6'2" but have 34" inseam and 6'4" wingspan so I needed the extra length lol
    No there are no clearance issues for the frame components but, it did raise the bb 1/16in and when I had a granny gear the chain would rub on the chain stay in low-high gearing which shouldn't be used anyways due to cross chaining.
    I checked the shock clearance by removing all psi and running it thru the full range of motion btw.
  4. #1879
    I've asked about the shock because even though I've got a similar frame (Anthem) I can't still quite visualize the geometry differences caused by a few inches difference. What's the effective real travel now? Any way to properly calculate that?
  5. #1880
    Dec 2011
    There is a thread somewhere about the usable travel gained, that's where I got the idea, I think it's somewhere around .5inch
  6. #1881
    Reputation: 'size's Avatar
    ...What's the effective real travel now? Any way to properly calculate that?
    the same way you calculate the stock travel.
    length of new shock stroke x avg leverage ratio of the bike, which is determined by dividing the stock wheel travel by the stock shock stroke.
    5.00/1.75 = 2.857 x 2.0 = 5.71
  7. #1882
    Reputation: chadalex78's Avatar
    Oct 2011
    My firecracker...
    Attached Thumbnails Attached Thumbnails Trance X Pics Thread...-559086_464105350268869_817881623_n.jpg
  8. #1883
    Jun 2012
    Hi All,
    Here are my two cents..
    First of all thanks for the great pics and inspiration, this thread is great!
    I bought my X5 last year and despite the fact it was waaay better than my previous bike I wasn't fully satisfied.
    This year I spent some time studying possible options for a fork upgrade and picked Rev DA RCT3
    I must say I am AMAZED. It's so plush, smooth.. compared to stock Tora TK the difference is huge so all of you who hesitate and wondering like me if spending some money (actually a lot.. ) is worth - I can assure you - it is. Finally I feel this suspension is working.
    Now fork is so good that the stock damper (giant's one) can't keep up. I'm thinking about fox rp23 but the question is.. 184mm or 190mm? Any advise will be much appreciated as I'm not sure how maestro will react to 190mm.
    Cheers
  9. #1884
    You seem to like your suspension to be active and plush, if that turns out to be true, go for something without Boost Valve. Just my two cents too... Either get one of those new Fox Floats without it or a Monarch.
  10. #1885
    Jun 2012
    oh yes, now I really like plush and active suspension. If I'm not able to adjust damper I'll consider also Monarch (need to dig through all topics about it..) Still wondering which one to choose from: 184mm or 190mm?
  11. #1886
    Oct 2011
    The X2 is complete for now... Its a beast.
    Attached Thumbnails Attached Thumbnails Trance X Pics Thread...-205351_465788933433844_1928809402_n-1-.jpg
  12. #1887
    wheelie king
    Reputation: 661lee's Avatar
    Nice.
  13. #1888
    Reputation: borbntm's Avatar
    A couple of updated photo's with some new Mutano Raptor tires, ODI grips and Salsa red anodized bling...Just turned over 4,284 miles on the ODO and still rides like a champ.
    Trance X Pics Thread...-imageuploadedbytapatalk1341893762.365884.jpgTrance X Pics Thread...-imageuploadedbytapatalk1341893787.026981.jpg
  14. #1889
    KC Weekend Warrior
    Reputation: the.rebot's Avatar
    Jun 2010
    Stock except for the wheels, bars and obvious color bits. Taken in Ellicottville NY last week.
    Yup, jammed between the trees
    '12 Giant Trance X1, Mavic Crossride Wheels, StansTubeless, SPD Pedals
  15. #1890
    Oct 2011
    Ultimate trail bike...
    Attached Thumbnails Attached Thumbnails Trance X Pics Thread...-555806_467570863255651_291941785_n.jpg
  16. #1891
    Tance x4
    Was 1x9 but setup 2x9 with this crazy heat
    Mostly slx. front stuff is ghetto mixed
    elixir r brakes
    fox f32 rl 120mm
    will probably get a monarch next month
    pxc2 wheels setup tubeless with gorilla tape and stans
    Just ordered some blue candies
  17. #1892
    Mar 2011
    My Trance X3 2008. 11.25 Kg.
    Attached Thumbnails Attached Thumbnails Trance X Pics Thread...-20120716_181111.jpg
  18. #1893
    is RAD
    Reputation: Van Cuz's Avatar
    Jun 2010
    I am loving this bike!
    Attached Thumbnails Attached Thumbnails Trance X Pics Thread...-uploadfromtaptalk1342778267150.jpg
  19. #1894
    An update of my Trance X via instagram.
    Now running a Glute saddle, Onza tires and Shimano's new Zee
  20. #1895
    My first trail ride on this bad boy!
    For it being 2 sizes to large.... I felt really comfortable riding it!
  21. #1896
    May contain nuts
    Reputation: Haggis's Avatar
    Quote Originally Posted by DAnREal View Post
    It does look big, given your saddle height.
    Some things which would help the handling:
    1. Short, flipped stem with all spacers underneath removed. (You can replace that cone headset cover with a flat one and reclaim some steerer).
    2. Lower rise or flat bar, with sweep and width that feels best.
    Attached Thumbnails Attached Thumbnails Trance X Pics Thread...-img_1792.jpg
  22. #1897
    Quote Originally Posted by Haggis View Post
    That's my plan when I save some money ..... That will be my temporary fix until I find a med frame to buy
  23. #1898
    Upgraded Trance 2011
    Fox RP2
    XT-Shifters
    XT-Chain
    XT-RD
    XT-Sprocket
    Giant seatpost
    26gram carbon bottle cage
    Ritchey WCS Carbon Handlebar
    CrankBrothers Foam Lock Grips
    ZTR Podium MMX
    DT240S
    Ashima ARO-08 Ultralight 180mm Brake Disc
    Tubeless with Schwalbe Racing Ralph
    Superb bike, but looking for an Anthem X29 for XC-racing, but going to keep the Trance for fun stuff.
  24. #1899
    Reputation: aizen's Avatar
    That is one shiny looking bike, plupp. Is it a small or medium?
    2010 Giant Trance X3
    2013 Giant Reign 1
  25. #1900
    Quote Originally Posted by aizen View Post
    A small, did a deep clean for today's marathon race.
