Page 55 of 89 FirstFirst ... 5 45 51 52 53 54 55 56 57 58 59 65 ... LastLast
Results 1,351 to 1,375 of 2220
  1. #1351
    Oct 2010
    How exactly does that NeoGuard work?
    Quote Originally Posted by andituk View Post
    Giant Trance X2 by 555Andi, on Flickr
  2. #1352
    Jan 2009
    Mud gets thrown up and forward by the tyre, and then because of your forward motion, you ride into it. The Neoguard catches it, and keeps the worst of the mud out of your face. Not as much coverage as a full mud guard, but it gets the worst stuff, and looks much prettier!
  3. #1353
    Update...
    A few new lighter (but still strong and trail/all mountain) parts now bring it down to 24.7lbs with a dropper post and a 150mm fork.
  4. #1354
    New grips/Painted a few parts..
    I plan to add some custom vinyl die-cut stickers but I'm not sure how the design should look.. maybe have a lime green pinstripe that goes on the top tube and on the side have it say Trance X. Also I went out to ride around my block and my chain broke! The front derailleur was on the smallest ring and I was trying to shift to second but it wasn't working... so I left the front derailleur on the smallest gear and shifted the rear derailleur to the smallest gear. Did my chain break because of this? Anyways here are the pics.
    Attached Thumbnails Attached Thumbnails Trance X Pics Thread...-img_0585.jpg
  5. #1355
    Quote Originally Posted by dangerzone9k View Post
    Look up MTBR member David C for custom stickers. He is a graphic designer and would help you come up with something, I think for pretty cheap.
    Putting your chain in the small/small combo puts the most lateral stress on your chain and generally should be avoided. But I've never heard of a chain breaking because of that. If something was about to break anyway, that could have pushed it over the edge. If you couldn't shift on the front, that sounds like you are having some issues anyway. I noticed front shifting gets much worse when the chain needs lube. How did it break? Pin pop out? Plates twisted?
  6. #1356
    Do you think the chain is repairable?
    Quote Originally Posted by smilinsteve View Post
  7. #1357
    Reputation: 'size's Avatar
    if you replace the broken link, sure. the question is - if the chain did in fact break from cross chaining what lifespan does it have left anyway? measure it out and determine the amount of stretch, could be time for a new one anyway.
  8. #1358
    Oct 2010
    My ride
    Attached Thumbnails Attached Thumbnails Trance X Pics Thread...-brcounty1.jpg
  9. #1359
    Quote Originally Posted by 'size View Post
    Exactly.
    Also, if you make it one link shorter you have to make sure its still long enough to fit the big big combo (unless you can guarantee you will never use that combo).
    For the wear, stretch out the chain and put the zero mark of a 12 inch ruler on the center of a pin. The 12" mark should also line up on the center of a pin, on a brand new chain. If the pin center is an 1/8th inch or more away from the 12 mark, throw it away.
  10. #1360
    Quote Originally Posted by samurai75 View Post
    My ride
    very stealth - they'll never see you coming.
  11. #1361
    fnar fnar brrraaaaap
    Reputation: ilostmypassword's Avatar
  12. #1362
    Here is mine again
    Attached Thumbnails Attached Thumbnails Trance X Pics Thread...-snc00903.jpg
  13. #1363
    Reputation: alekosty's Avatar
    Slightly upgraded mine Trance X. New wheels and 2012 Revelation RLT 150mm.
  14. #1364
    gravity fighter
    Reputation: Mikecito's Avatar
    [QUOTE=alekosty;8327925]Slightly upgraded mine Trance X. New wheels and 2012 Revelation RLT 150mm.
    Is that a 650b up front? Nice set up
  15. #1365
    Quote Originally Posted by Mikecito View Post
    Nope, 26" but on a picture it looks like 650b.
  16. #1366
    Oct 2010
    trance X3
    this is my trance with some modifications
  17. #1367
    looks like you modified some 2 x 4's as well. nice.
  18. #1368
    TRANCER
    Reputation: Biohazard74's Avatar
    2009 Trance X3 with a couple of upgrades and a shower
    Attached Thumbnails Attached Thumbnails Trance X Pics Thread...-2011-08-17-17.59.34a.jpg
    Ride
  19. #1369
    Quote Originally Posted by alekosty View Post
    What pedals are those? i'm after some thin flats to combat the amazingly LOOOOOOOOW BB of this bike
  20. #1370
    Quote Originally Posted by ilostmypassword View Post
    Nukeproof Protons
  21. #1371
    wheelie king
    Reputation: 661lee's Avatar
    What year/model is this carbon TX? Love the white stickers and links.
    Edit: figured it out, 2010 frameset
  22. #1372
    Hello, i'm new member of Trance X i will post photo soon!
  23. #1373
    Reputation: krazychowmein's Avatar
    Finally made it out to Northstar, first time at the park and honestly the Trance did great!
    Attached Thumbnails Attached Thumbnails Trance X Pics Thread...-top-northstar.jpg
  24. #1374
    Nukeproof Protons
  25. #1375
    One word: beautiful.
    The XT rims and the white Fox fork look extremely good with the black X2 frame.
