Results 1 to 7 of 7
    Reputation: zack's Avatar
    Trance X / compression tune setting of Fox Float shox
    here in germany the Trance X line is coming with Fox Float RP2 / RP23 all set to "firm" in the compression tune of the shock.
    In my opinion that is much to firm and leads to limiting the travel in highspeed situations.
    My old '05 Trance with a Fox RP23 set to "light" in the compression tune was much better in those highspeed situations.
    A guy from switzerland told me that he bought a Trance X with compression tune set to "light"
    So it seems that different settings have been used in the Trance x lineup....
    What was your compression tune set to ?
    Reputation: EGF168's Avatar
    The maximum rebound and compression tune on both the Trance 1 and X2. I havenít really noticed it that much on the X but just bouncing on the Trance it feels really rubbish but again I havenít noticed it when riding because it feels so responsive. I personally believe they should be set in the middle for both rebound and compression so it wonít have problems either way.
    strange, on mine the compression tune ist set to firm, but the rebound tune to light.
    Reputation: Ziploc's Avatar
    I just picked up my Trance X1 today. I am 230lbs and am wondering if anyone could recommend a good "Starting" pressure for the rear shock. I am trying to get the 11-13mm of sag and am having some difficulty.
    Quote Originally Posted by zack
    Yeah, I beg your pardon, I rechecked the TX and it’s the same as yours and I’ll have a look at the T1 later…. I wonder what made me think the rebound was also set to firm?
    EDIT: They are both light rebound/firm compression.
    Reputation: antonio's Avatar
    Jan 2005
    On my Trance X1, the compression is set to the middle bar - is that firm?
    The rebound is light, I assume, since the first, shorter bar is highlighted.
    Ant
    the settings are light / medium / firm, starting from the shortest bar.
