Trance X 3 - 2 broken bolts
Hello!
I have trance X3. After about 2 moths after purchase when I was going down, I've noticed that there is something wrong with rear suspension. I've looked closer and saw that there is to much space between Fox's top whole and bolt (i twas 'wobbling'). The bolt was broken :/ My lbs servcice changed it realy fast, but that did not helped. I was tightening bolt every time I saw it's shaking a little. This morning i tightened it one more time, then i've heard 'crack' .... 2nd broken bolt :/ Now bike is in LBS. If it happen one more time i'll consider switch to hardtail.
Any of You had similar problem?
check your reducers too... and use a torque wrench and antiseize when tightening the bolt
Yeah, put some locktite on the bolts when you put them in and do them up real tight or get the shop to do it.
broken bolt
Currently I do not have torque wrench. I do not think that I should have one, because it's not normal situation when You have such problems with new bike. I hope that i'll not be forced to buy one. I've not used much power to tigchten bolt. Anyway, I saw that main arm of rear suspension (which holds rear damper) had damaged hole for bolt. It was missing few 'rings' inside the hole. Probably that's why bolt was unscrewing.
At the first time when the bolt was broken guys from lbs changed it to new one from trance x2. That was fine, and yes they used locktite. But after few rides bolt was still unscrewing. I think they have to replace main rear suspension arm.
There is also thread on forum about broken the same bolt in Trance Advanced
Guys thanks for suggestions!
I agree completely with you on the bolt situation...but a torque wrench is a very useful tool.... not a"requirement" to do things, but definitely useful for working around the bike
At least it seems like your LBS is on top of things, I hope things get worked out.
Cris, are you moderating the Giant forum now?
not in particular, EGF... Warp is in charge of "modding" in here, but as a supermod I can help out too.
Oh ok, I saw you had been promoted and its been ages since I saw Warp on the Giant forum and thought you may have succumbed to the best bikes in the world…
Good it’s sorted… hope it stays that way.
Finally....
After full season and many miles behind me .... everything works fine
- You may not post replies
- You may not edit your posts
Forum Rules
