Page 33 of 34 FirstFirst ... 23 29 30 31 32 33 34 LastLast
Results 801 to 825 of 826
  1. #801
    May contain nuts
    Reputation: Haggis's Avatar
    Quote Originally Posted by andy2004 View Post
    im tossing up between an x1 trance or a reign 1 2013 models.any help on this.i will be using the bike for trials and dh
    Neither bike is good for those needs...
  2. #802
    Feb 2013
    sorry i ment xc not trials.the dh will be a once off thing.just the reign is more expensive by 500 dollars here.
    is it worth it
  3. #803
    Your Best Friend
    Reputation: Silentfoe's Avatar
    Re: Trance X 29 official intro
    The Reign is definitely a lot further towards the DH side of trail riding than the Trance. I would hate to do an all day epic ride on a bike as "big" as the Reign.
    I guide and rent bikes in Northern Utah
    http://www.facebook.com/AdventureEarthRides
  4. #804
    Feb 2006
    Quote Originally Posted by LordDRIFT View Post
    Okay, so now I have a couple weeks on the bike, I think I have finally seen a weakness. The front end IS light. Every time I read this I thought they meant the front would keep lifting on climbs. While it doesnít climb as easy as my TX 26er a little change in technique keeps the front end down, so no biggie. This aspect blinded me to the effect on corner performance on. Bermed corners are fine, however there are two type of corners where the front end will laterally slide/drift to the outside of the corner.
    1.Flat high-speed corners
    2.Super low speed loose surface uphill switch backs.
    The tires may have something to do with this. Has anyone else had this kind of experience?
    Must be your riding style, I havent noticed this with a 140mm fork on the front of mine.
  5. #805
    May contain nuts
    Quote Originally Posted by Silentfoe View Post
    Reign is fine for long hauls, they pedal and climb really well. I've done 130km rides on a Reign, & 70km rides often on my RX. The TX29 obviously rolls better and is the better long distance bike but the main point of difference is the handling - big wheeler does not jump and change direction as well as the Reign. If that's not your preferred kind of riding; go for the TX29.
  6. #806
    Reputation: tonyride1's Avatar
    There is a huge difference between trails and DH. For trails I'd go with Trance X over Reign because it's much lighter. As for DH, I don't think the Reign is made for that. You may need a Glory and you definitely don't want to ride trails on that.
    2013 Giant Trance X 29er 0
    2015 Motobecane Sturgis Bullet
    2016 Diamondback Catch 2
  7. #807
    Feb 2013
    i appreciate the help guys.i will be doing trial riding most of the time but on the odd occasion i wouldn't mind popping down the dh track that is close by.the reign has alot more travel and has better running gear.im just curious is the gear setup on the tx 1 good enough for the price difference.
  8. #808
    There isn't a single bike that can do it all. Since you posted this on the Trance X 29er thread I assume you're talking about the the 29er version of the Trance X and not the 26er version. The Reign, and Glory for that matter, only come as 26er. I can't even begin to compare the Trance X 29er to any Reign because they're so different (frame design and geometry, shocks, forks, head angle, seat tube angle, speeds, gearing, BB height, etc.). A Trance X drive train is designed to be light and precise. On the Reign and Glory they're designed to be robust therefore heavy. Sorry, I can't help you with the comparison. You'll have to decide for yourself where you're going to ride the most. If you decided on a Trance X then you'll have to also decide if you want to take a risk of taking it on the DH run.
  9. #809
    May contain nuts
    TX29 with a 140mm Fox 34 would be a versatile bike
  10. #810
    Cassoulet forever !
    Reputation: 20.100 FR's Avatar
    Hello,
    Do any of you have the reach and stack values of the different sizes ? (especilally L and XL).
    I looked at giant site in several language and didn't found it.
    thanks
    Frenchspeaking 29"ers community site http://VingtNeuf.org
  11. #811
    2.3 Hans Dampf and 70 mm stem has really tightened up the front end and my traction woes. Bike feels damn near invincible now. An added benefit to the shorter stem other than quicker steering was decreased back ache and hand numbness.
    Originally had trouble tuning the RS rear shock. Tried to tune based on sag and almost dumped it until I realized large variations in pressure did not produce like changes in sag, ie there was a lot of room to play with different pressures at a fixed sag. My method was to start with 270 psi for my approx. 200lb riding weight 23% sag. I then begin to drop the pressure in 5 psi increments and when I hit 240 psi a touch under 25% sag the rear felt perfect
    -Don "LordDRIFT" Draper.
  12. #812
    Reputation: akaBrowntown's Avatar
    Nov 2012
    Does anyone know the steerer tube diameter specs?
    The the X2 1.5-1.125
    And the X1-X0 1.5-1.25
    As in a standard tapered fork will work with the X2, but not the others?
    I can measure when I get home, but for the sake of dsicussion.
  13. #813
    Quote Originally Posted by akaBrowntown View Post
    1 1/8 - 1.5 (Standard taper) save a little bit of hassel in upgrading your stem and fork.
    Standard tapered fork can work on the x0 and x1 as well by changing the upper HS assembly (reverting to 1 1/8).
  14. #814
    Nov 2012
    Gotcha. I thought as much. Although I am happy with the Recon mine came with now, I just sold a car and am toying with the idea of upgrading.
  15. #815
    The fork will most likely be the last thing I upgrade unless a banging deal comes along.
    1. Wheels
    2. Crank
    If I've got fork money burning a whole in my pocket and looking for the most performance gain from money spent.
  16. #816
    Mar 2013
    I bought a trance x1 2013 and stripped all of the groupset except i asked the LBS to spare the wheelset and replaced everything with shimano XTR groupset and replaced the handlebar with Easton haven Carbon Riser.
    Now which saddle do you recommend and which shorter stem is compatible with overdrive 2?
    Does the Shimano XT/XTR chain really makes a huge difference in shifting than using the stock KMC chain?
  17. #817
    How does the bike handle with a shorter stem and wider bars?
  18. #818
    Your Best Friend
    Why did you spare the wheelset? That is where you should focus your efforts.
  19. #819
    Just brought home a large X2 today!
    Have a 90mm stem on it now, will see how that goes. Will be screwing pedals on in the morning and getting a feel for this bad boy...
  20. #820
    Mar 2013
    What wheelset do you recommend? The stand wheelset that comes with my trance works perfectly.
  21. #821
    Is the top tube as long as it says on the web site or is it a virtual length?
    If so, what is the actual TT on the medium and large?
    I had a 2007 reign in medium some years ago but it was too small even with 100mm stem and 20mm set back on the seat. I'm 5'11" what do you think?
  22. #822
    Orderd a large, frame only.
    What kind Of cranks and bb's can i choose? Is there any adaptors so i can use My old lx HT2 crank and bb's?
  23. #823
    Aug 2015
    Are there any 2014 Trance X 29er 0s in the silver color that came out on the 2013 model, or are all 2014 X 29er 0s black?
  24. #824
    Aug 2015
    Also - do the 2014 models come with upgraded suspension internals? Any other differences?
  25. #825
    Quote Originally Posted by rsilvers View Post
    Just the black for the 2014. Go to here and enter "Trance X 29" into the search box to see the different models and years.
    Giant Bicycles | International
    If you compare the specs on the different year 0s you should see the answer to your other question. I couldn't see anything besides the Kashima factory fork and shock and the newer seatpost.
