Page 15 of 17 FirstFirst ... 511121314151617 LastLast
Results 701 to 750 of 826
  1. #701
    Feb 2006
    1st ride on my X1 yesterday. After swapping out Bars for the shorter Truvativ Stylo WC (690mm) which also have a lower rise and swapping the 90mm stem for an 80mm (I still have to 70mm on order), I hit my local trails.
    I started off riding up some steep stuff and was impressed how well the bike climbed, I managed to clean a steep technical uphill track which I sometimes ride as a quick way into the park. One thing I did notice was a bit of wheel spin having positioned my seat more forward. Once I was at the top I rode some good singletrack downhill to the bottom of the park. I wasn't initially blown away with the DH performance, the bike though did definitely feel a lot more agile than the AX29er.
    At the bottom I checked my air settings for my forks and shock, they were setup as recommended 20% sag. I removed some air and set them to 30% sag and rode that DH again. This time I was blown away, the bike absolutely railed, very fast. I can say its rare that I can jump on a new bike and feel immediately at home with it.
    Throughout yesterday's ride though I couldnt help but wonder what the bike would feel like with a 130mm for 140mm fork. I found the bike does feel a bit steep with the 120mm fork, much like my Trance 26er did (I put a 140mm fork on it). I think a Revelation 140mm reduced to 130mm might be the business and not compromise the length of the bike too much.
    The other thing I didn't like was the amount of noise the bike made from the internal cable routing rattling around in the frame
    and without a doubt the bike needs a shorter (70mm) stem
    Sent from my ASUS Transformer Pad TF700T using Tapatalk 2
  2. #702
    Your Best Friend
    Reputation: Silentfoe's Avatar
    Quote Originally Posted by rafalwspin View Post
    I found this is MBR, January issue. They tested X1. "More annoyingly, SRAM's Type-2 rear derailleur makes a loud clunking sound every time the suspension compresses, because the lower section of the chain tugs on the rear mech and causes the clutch to relese," No one mentioned this before. Can someone deflate shock and check, please?
    Interesting. I'd been hearing a muffled clunk while riding and couldn't narrow down what it was. After reading this I explored the bike a bit more and found their assertion to be accurate. It is most definitely the roller clutch on the X9 rear derailleur. Have to say I'm not very impressed.
    For what it's worth, you can't hear it on the trail. Only on pavement. Not a big deal.
    I'm a mountain bike guide in southwest Utah
  3. #703
    Dec 2009
    Is this problem only with Sram, or with Shimano plus as well?
  4. #704
    Doesnt ride Banshees
    Reputation: Banshee Rider's Avatar
    That isn't a problem with Shimano Shadow+.
  5. #705
    Got to ride an X1, albeit only in a neighborhood around the shop.
    My local shop has a medium in stock. I'm 6'1" and they said it fit fine. Of course I worry if they are just trying to get me to buy this one instead of ordering a large. I don't mind waiting at all, just want the right size.
    Gotta say it felt pretty good, but don't know which I should get. On one hand the medium has a super short wheelbase. Be great for manueverability. But am I sacrificing stability? I'd hate to get it on a downhill and fell like I'm gonna go over the bars.
    Maybe a large with a shorter stem would be better. But then the wheelbase is longer and may not be as agile.
    ARRRRGH! wish thhey had both in stock. Hate having to choose like this.
  6. #706
    DFMBA.org
    Reputation: MTBeing's Avatar
    Quote Originally Posted by richulr View Post
    I'm 6'1" as well and my lbs told me that puts me right in the middle for a large. I think a medium would be to small for you. I even demoed an XL on 5 miles of single track and it didn't feel that bad. 32" inseam, btw.
  7. #707
    Quote Originally Posted by CCMTB View Post
    thanks for the reply. Like to hear what others think since I can't demo various sizes
  8. #708
    Carbon & Ti rule
    Reputation: muzzanic's Avatar
    Hi
    I don't Ride Trances anymore, But Have owned a heap of bikes, Niners at the moment.
    I'm 6ft on the button & I ride Lge 29er's, I have had med as well.
    The med is getting small for you, I have a friend that is just over 6ft & rides a Med Trance X29, But he runs his seat much lower than me.
    His seat is arround 740mm were as I run mine at 800mm, I find with the Lge It is easyer for me to keep the front wheel on the ground on very steep climbs & don't get the going over the bars feel on steep drops.
    So IMO unless you run your seat at 740mm high of less don't even look at the Med.
    Just my 2 c
    I have a 6 Berth Motorhome that I rent out . It is based in Tauranga, New Zealand
  9. #709
    Sep 2012
    I agree with the other two responses and think a medium may be too small for you. I'm a bit taller at 6'3" and waffled between the L and X/L riding both multiple times before settling with the X/L. I really felt like I had a bit more room on the X/L and honestly could not tell any difference in handling between the two.
    That said, it a personal choice, but I would definitely ride a large before making a decision.
    Good luck
  10. #710
    Your Best Friend
    Your shop needs a reality check. You should absolutely not be on a medium frame. Tell your LBS that they shouldn't be pushing a sale just because that bike is the only one they have on the floor.
  11. #711
    carbon classic
    Before you spend your hard earned on a new bike and for your own peace of mind, I would suggest a test ride on the large first.
    I had a similar query to yourself - medium or large Trance X29?, so a few months ago I did a back to back test ride of each at a GIANT test ride day. (BTW - I'm 6' and 34" inseam) Medium was ok, but the large just felt better; it felt spot on actually.
    Do yourself a favour and get a ride on the large size. Then you will be confident which size works best for you.
  12. #712
    problem is no one has a large. Heck, this medium is the only one I've ever seen.
    On your guys advice, I'll go large. They told me they'd switch the stem for free. Maybe a large and a shorter stem is the way to go for me.
  13. #713
    Carbon & Ti rule
    Sounds good to me, that Is how I have set up my Jet9 RDO & really like it.
  14. #714
    Your Best Friend
    They could definitely order one in. They are not sold out.
  15. #715
    Anyone know how much the stock Giant Connect SL, Low Rise, 31.8 bars on the X291 weigh?
  16. #716
    DFMBA.org
    Quote Originally Posted by eruizela View Post
    Giant Connect SL Riser Handlebar (Handlebars) - Bike Gear | Giant Bicycles | United States
    This is the aftermarket link, but I'm pretty sure the bars on the stock X1 are 720s, which are not listed. If you extrapolate the weights v. lengths, though, it's probably around 275 grams.
  17. #717
    DFMBA.org
    Just ordered mine today (X1 large) from my lbs and I'm really jazzed to officially join the fray here, esp the pic thread.
  18. #718
    Reputation: tonyride1's Avatar
    Congrats
    2017 Diamondback Mason Pro
    2015 Motobecane Sturgis Bullet
    2015 Giant AnyRoad 1
    2016 Diamondback Catch 2
  19. #719
    Reputation: Kaussy's Avatar
    Dec 2012
    I also just ordered my trance 29 x1. Can't wait!!!!!!!
  20. #720
    Quote Originally Posted by Kaussy View Post
    Congrats to you, too. You guys will just love it.
  21. #721
    Sep 2012
    I have an x1 and bought a bbg bashgaurd I installed it on the outside of the big ring used stock bolts took washers off. I had to adjust the derailer up to clear the gaurd but now it's to high and rubs a little when on small ring. Is anyone running a bashgaurd on there tx29x1. Not sure if I installed it correctly or it's just made to replace big ring and I have it rigged up. I tried uploading pics but it won't let me for some reason? Any opinions thanks my first 2x10
  22. #722
    I recently purchased a Trance x29er X0 and have some questions about running the P-TRX rims tubeless.
    I got the bike shop to setup tubeless when I first got the bike, however I am loosing around 1psi of pressure each day in both tires and the front tire has already burped off the rim a couple of times.
    I'm running 25-28 psi front and 30-32 psi rear and only weigh 62kg.
    In the box with manuals / spares I got with the bike there are 2 rolls of double sided tape & 2 red DT Swiss rim strips. Do you have to use these rim strips when setting the P-TRX rims up as tubeless?
    Has anyone found they are still getting lots of punctures & leaks when running tubeless with stans sealant? I already have 3 patches on the inside of my rear nobby nic tire because the stans would not seal the puncture and just kept squirting out without sealing. All these punctures have only been a few mm long small cuts.
  23. #723
    Reputation: pharcyde's Avatar
    Quote Originally Posted by weeman View Post
    Errggggh ..... bow bow !!!
    If the LBS hasnt installed the DTSwiss tape then theres the problem. Factory fits the red tape so someone has either NOT installed it in the factory or the LBS has pulled it off.
    If the punctures arent sealing you havent got enough sealant in them. Simple as that.
    Your tyre pressures seem a bit too low. If this is your first 29er then you need to reset your thinking with regards to PSI and lift them up. All this crap about running lower PSI with TL is wrong. Low PSI will burp every time and depending on the situation that caused the burp, you WILL need to clean the rim bead before attempting a reseal.
    SCHWALBEs will "snap" up tight if seated correctly and the red tape is the only way to achieve this.
  24. #724
    For those of you w/ X0's, what kind of extras should I expect? I got a generic Giant manual, and IIRC one for the adj. post, some reflectors, and the tubeless valves. No shock pump, suspension setup guide, or anything else - is that right?
  25. #725
    Quote Originally Posted by cms_atx View Post
    Be thankful you got the Adj seatpost one. I didnt. Any chance you could scan it and post it up???
  26. #726
    My X0 came with tubes and I converted it to tubeless myself. All I needed was Stan's sealant because my bike comes with the tubeless valves. No tape needed as the rims are already set for tubeless and so are the tires. No air loss so far and it's been weeks.
  27. #727
    Quote Originally Posted by tonyride1 View Post
    Did you find the tire hard to seal on the rims? Even with an air compressor mine were hard to seat and if I let all the air out the beads fall away from the rim making it impossible to pump up a completely flat tire with a hand pump.
  28. #728
    Quote Originally Posted by pharcyde View Post
    Send me a PM reminder this weekend....I've moved to Fort Worth, and my bike is still in Austin, heading back Friday night.
  29. #729
    ~Reformed Mechanic~
    Reputation: Ace5high's Avatar
    Jan 2011
    Using an air compressor the first time you set them up is fairly normal, I normally don't NEED one but it sure does make it easier!
    It sounds like they may not have been setup properly from the LBS and from the start. If I were you id get familiar with the techniques needed to setup tubeless yourself and just re-do them properly. Just Goto Stans website as they have good tutorial videos on how to properly set them up.
    As said you shouldn't need patches at all, that would defeat the purpose of the sealant in the first place.
    I do all my own stunts, but never intentionally...
  30. #730
    Like others, I use a compressor to seat the tire to the rim. Once you hear the popping sound you know it's seated. Then you let the air escape and add the sealant (~2 ounces) and pump it up with a regular pump. I pumped it up to around 40 lbs. to keep the bead seated firmly against the rim and then did the shake and rotate of the wheel. After a day or two I let some air out and then monitor the air pressure from time to time. So far so good.
  31. #731
    DFMBA.org
    Ok, 1 by 1:
    - The 1lb loss I wouldn't be *that* worried about but the source of the air loss is what you need to find. It's either the tape job or the tire bead. Are you getting sealant weeping along the sides of the tires or are they totally dry/clean?
    - Do the tape and rim strips look like these? DT Swiss - Tubeless Kit
    The short answer to your question is YES. If Giant designed the wheels in conjunction with DT Swiss, and the tape and the rim strips are spec for a successful tubeless setup per the mfg recommendations, then your lbs needs to redo the job. My GUESS is that they used 1 layer of Stan's tape to cover the spoke holes and a couple ounces of sealant. This will seal a tire that's static but once you start riding the bead is slipping out of the hook and burping. The rim strip is designed to wedge the tire bead deeper into the hook and make it more resistant to slipping out and burping. This is a safety issue and a legal liability for the bike shop. If you paid for this I'd go back to the lbs and tell them to redo the job using the DT Swiss stuff.
    - I had a similar experience with my first go at tubeless (from a local shop) and now I only do it myself.
    - Stan's should be sealing those types of punctures. I usually run with 3 scoops in the tire here in AZ. Never had an issue, but I've never run with Schwalbe tires.
    Please donate to IMBA or your local IMBA chapter. It's trail karma.
  32. #732
    DFMBA.org
    Just read this post...
    If your beads are falling away from the rim when you deflate the tire that's a HUGE problem (and a safety problem). No wonder you're burping!! When I read your original post I thought it was very strange that you were burping at those tire pressures and your body weight. I weigh 200lbs with no gear, and regularly run my front tire (on a Stan's Arch rim) at 22 psi with zero issues. You have a setup problem.
  33. #733
    Quote Originally Posted by MTBeing View Post
    Ok, 1 by 1:
    Yes that is the rim strip I have (2 sets of the double sided tape and red rim strip). Although I also have manuals for rockshock suspension when my bike has fox so I don't know if the rim strips are for my bike or not.
    This was the first trance that the LBS setup as tubeless and I don't really trust them to know if my model needs the rim strips or not.
    I've got both rims off the bike atm so will probably install the rimstrips tonight and see how it goes.
  34. #734
    Find a new LBS .... your dealing with a bunch of kooks!!! Giant Australia would be very interested to know what isnt happening at the bike setup stage of their product.
  35. #735
    DFMBA.org
    Keep in mind that you ultimately need a strong, air-tight seal between the rim and tire.DUH, right? See, some "rim strips" are merely there to protect the inner tube from the abrasiveness of the drilled spoke holes but do no provide any tubeless functionality.
    Other "Rim Strips" (i.e Stan's) are there to (1) provide a seal between the spoke holes, and (2) provide an interfering 'ledge' whereby the tire bead is squeezed in between the rim strip and the top hook of the rim providing an interference fit to the tire bead and the rim. When you combine this interference fit and the sealant (to fill the super small imperfections) you have a great tubeless setup. It sounds like you don't have enough interference in the bead hook area. The bead just flops around.
    Keep us posted on your progress please.
    Edit: The lbs' excuse that it's their first TX29 tubeless setup is bogus. Tubeless is tubeless. They need to consult with their Giant rep and have him/her go over the procedures with them. I can guarantee you, never having set up Giant rims tubeless before, that I'll get it right first time (w/ P-XC2 rims), and post pictures/proof here on the forums of the whole process.
  36. #736
    Looking on the Giant website it doesn't mention rim strips for the P-TRX wheelset:
    FEATURES:
    Light and durable proprietary G69 alloy 29er rims
    Tubeless ready using supplied valves
    28mm wide rim for better large tire performance
    DT Aero Comp bladed stainless steel spokes - 28 front/rear (3-cross)
    DT Pro Lock alloy nipples
    Giant alloy hub shells, 6-bolt disc compatible, DT internals
    36T SL star ratchet with 10° engagement
    Compatible with SRAM XX1 1x11 drivetrain using an optional DT Swiss XD Driver body.
    1795 grams per pair
    Where as for the P-XCR it does:
    Lightweight alloy 29er rims
    Tubeless compatible using supplied rim strips and valves
    24mm wide rim for better tire performance
    DT Competition stainless steel spokes - 28 front/rear (3-cross)
    DT alloy nipples
    18T star ratchet with 20° engagement
    1750 grams per pair
  37. #737
    DFMBA.org
    Are there any spoke drill holes along the center channel of the rim? Can you take a picture of what you have here? Sounds as if you're like Post #726
  38. #738
    All the spoke holes are covered.
    Here is a pic of the rim:
    dl.dropbox.com/u/11425568/DSC00221.JPG
    And here is a pic showing how the tire bead falls away from the rim when flat. I pumped the tire up this morning without sealant to check for leaks (there were a few small ones hence why its deflated) and this is how I found the tire this afternoon. As soon as the tire looses enough pressure the bead separates from the rim:
    dl.dropbox.com/u/11425568/DSC00220.JPG
  39. #739
    DFMBA.org
    I saw the pics and it definitely looks like the rims are sealed and one would think that you'd only need valves. That said the tire falling away from the rim bothers me.
    I would tell your shop about this and ask them about the unused parts. It probably couldn't hurt to throw the rim strips in and air up the tire again (with a couple scoops of Stan's) and see if that makes a difference. That's what I would try, but of course I'm advising from afar. If you haven't been to the Stan's website and watched the videos, do that as well. There's lots of good info specifically in the "tubeless kit" video (except for drilling your rims). If you watch the "ZTR Tire Install" video, that's what it should look/feel like getting a tire off a rim.
    http://www.notubes.com/helpcenter.aspx
  40. #740
    Reputation: akaBrowntown's Avatar
    Nov 2012
    I know some of you will be a bit biased, however I am having a hard time making up my mind between TX29er and its 26" variant. Iv ridden both and like both, I seem a bit more at home on the 26" but that might be because im coming off a 28" HT. I believe I am renting a TX29 on saturday, but like ive said before im having a hard time choosing.
  41. #741
    ~Reformed Mechanic~
    Jan 2011
    Quote Originally Posted by akaBrowntown View Post
    Biased? Us? in the TX29er section? Ride it, you will love it.
  42. #742
    DFMBA.org
    If you're gonna bomb down alot and want more playfulness from the bike then a 26 may be the right call. If you're gonna do more epic XC and longer rides where you need a the benefits of the 29" wheels over a longer period of time, then maybe it's a 29. If you're a taller dude, then maybe a 29" as well. Whatever you're more comfortable with, tho.
  43. #743
    As someone with both the 26" and 29" version of the Trance X I would say that each has their own pros and cons so it all depends on where you ride and how you ride. There are lots of different places for me to ride with different trail types and conditions so I find that having both is nice. 29ers are great for going over bumps, logs, long fast stretches, and long fast descends. 26er are better on tight twisties and rock gardens as they're more agile. I thought I was going to sell my Trance X1 when I got my Trance 29er XO but then decided to keep it. Love them both.
  44. #744
    I set up my tx29er XO tubeless myself and have never had so much trouble getting a tire to seat on the bead. I have done several sets of wheels tubeless, both ghetto style and tubeless specific, and getting the nobby nics to bead was a pain! I had to use a compressor, and even then one of them took a heap of jiggery pokery before seating. And, as mentioned above, the bead falls away from the rim as soon as it is deflated.
    One of them, after having been used for a few weeks with a tube would not seal because of a tiny cut that just sprays stans everywhere. The cut is maybe 4mm long? I have never seen stans fail to seal such a small hole. I figured it was just me, but after reading through the above posts I wonder if the NN's that come with the bikes are a cheaper, nastier OEM version than those you buy individually? It is my first time running NN's though.
    I replaced the cut NN with a Racing Ralph installed tubeless on the rear and it went on easily.
  45. #745
    Sep 2012
    Not satisfied with Brakes on the x1 does anyone know what kind of pads are stock I'm going to try different pads just not sure what to change to. I'm thinking of trying organic. The stock pads are loud no modulation or power and not to mention if its wet out. Any advise would help I was also thinking of maybe different rotors too. I just really hate to have to upgrade whole brake system after dropping good coin on new bike. I'm sure others are dealing with this hope to find a cheap solution.
  46. #746
    DFMBA.org
    Quote Originally Posted by jaymx410 View Post
    Lots of info here: The Juicy brake turkey warble/vibration MEGA THREAD
  47. #747
    Sep 2012
    Thanks mtbeing lots of info in that thread after reading for hours I think my best bet is to call avids customer service and see if they'll send me some organic pads
  48. #748
    Dec 2012
    I ended up getting a pair of shimano deore M596 from my LBS for a good price, they were stripped off one of their build kits. Now just need to sell the avids to make bake some of the money... relatively cheap solution... muuuch better brakes.
  49. #749
    Sep 2012
    Craig sounds like a good choice I would feel bad selling these avids to anyone haha I'm gona try a couple cheap attempts to make they work if that don't work I will be replacing them too
  50. #750
    Reputation: three3nine's Avatar
    Dec 2012
    Had the same thing my 2012 Anthem X 29. Replaced stock pads with a set of Serfas pads from Jenson for $8 per wheel - difference between night and day. Stock pads were noisy, had grinding feel, crapped out when wet, squeaked under extended use, the Serfas pads are night/day difference. I'd suggest them as a right away replacement for all the stock Avid brakes....
Members who have read this thread: 4
