Page 12 of 17 FirstFirst ... 28910111213141516 ... LastLast
Results 551 to 600 of 826
  1. #551
    Dec 2009
    Quote Originally Posted by j__h View Post
    it is a 180mm disc.
    Were thay supposed to fit a 180mm disc for you but forgot? Still looks like a 160mm disc with a 180mm adapter to me?
  2. #552
    Quote Originally Posted by gvs_nz View Post
    Maybe this will be a little more clear?
  3. #553
    Reputation: Bludshroom's Avatar
    Oct 2012
    The bike shop did it for me but you will have to buy a olive and insert for the brake line as you will need to disconnect it to run it through the frame. Then you will need to bleed the brakes.
    Sounds hard already, I will just have mine at the BB for now.
    ****** LBS, I had to ask them if it came with the Tubeless Presta Valve for them to hand them to me.
    I'm not good yet at bike repairing,
    Can someone tell me why my front derailleur makes a LOUD click when I try to shift from the Large crankset to Small crankset?
    Also, is there any guideline on how to trim the dropper seat post cable? and how hard it is?
    I am a computer engineer, I think I can handle some cables LOL.
    Thanks in advance
  4. #554
    Sep 2012
    Quote Originally Posted by Bludshroom View Post
    Thanks in advance
    The dropper seat post cable should be trimmed to the proper length by your shop, as part of the build. My LBS ran my brake cable internally, ( I don't have dropper seat post), but I read some shops charge extra.
    Loud click when shifting? You will hear it, but have your shop look at it to be sure. Have fun riding!
  5. #555
    Quote Originally Posted by Spazdad View Post
    For those of you that have fox equipment
    There is a cool app for iPhones that calculates weight settings and also uses the camera to look at sag and makes adjustments based on how far the travel ring moved. Pretty nice if u ask me.
    Whats the app called?
  6. #556
    Sep 2012
    Fox ird
    My bike x1 has 170 front maybe the shimano stuff is 180
    The brake needs to be disconnected at the lever. Cut and reinstalled with new crush ring after the re route. Very simple.
    The seat is very easy as well.
    Take of the one and only bolt in the seat post where the saddle meets. On the drivers side of the post there is a small Allen bolt. Just loosen this and re route cable through frame. Use a different derailer cable because you will likely be shortening the cable by 10" or so. Make sure your seat functions well before cutting the line. I found that a slight amount of preload was nice as it only took minimal switch effort to engage the seat.
    Btw. I used the app. Worked really well. I redid the whole settings because on the maiden ride I felt that the small bump sensitivity was not there. Maybe a warranty claim.
    Plain and simple fact that this bike is 4+ stars out of 5 for me. I keep right up with my buddy on his anthem with full xo. I can't wait to get some nice parts on here.
  7. #557
    Oct 2012
    Quote Originally Posted by motomuppet View Post
    FOX iRD
  8. #558
    ^ thanks guys, just found it...very cool!
  9. #559
    Oct 2012
    Fox ird
    I was able to take those apart.
    Can I just cut the cable housing using a wire cutter? and Can I just use the same cable??
    Sep 2012
    U might be able to get away with the same cable if u can get the frayed ends through the tiny hole. And yes wire cutter will work. Make sure to fix the inside tube of cable after cutting.
  11. #561
    Oct 2012
    Thanks a lot.
    First I used my antique cable cutter and screwed up a lil. then I went down to tool shop to get my self a good one, and I did it.. I was able to trim it down.
    Thanks again and again and again
  12. #562
    Hi all just curious how prices here in my location compare to others.
    X1 $2525
    X0 $3100
    This for the trance 29er of course. I am helping a few friends shop for a new bike.
  13. #563
    Reputation: peanuthead's Avatar
    Where are you located?
    Quote Originally Posted by Kojie View Post
    X1 $2525
    X0 $3100
  14. #564
    X1 $2525
    X0 $3100
    I see that you are in the Philippines from your profile. If those prices are US dollars then they are the best I've seen. Pricing may have something to do with your proximity of Taiwan for shipping.
  15. #565
    Quote Originally Posted by cozzal View Post
    Yeah converted them to usd with the current usd rate. Those prices are from the local Giant Store. Just read a few pages and saw the Au and Uk prices.
    Might be shipping cost is cheaper from taiwan being close here. Shimano prices seems to be also good here, xt groupset for around $590. That includes cranks, shifters, rd, fd, chain, cogs and brakes(rotors not included)
  16. #566
    Oct 2012
    How can I tell of my trance x0 is a size medium?
    Mine doesn't come with a sticker that says the size!!
    Edit: my bad, found the sticker.
  17. #567
    Dec 2009
    [QUOTE=j__h;9828671]Maybe this will be a little more clear?
    In that case , if you still can't get it lined up, ditch the adaptor and just try the alignment washers plus a few extra avid ones as reqd. Post to post adapters are usually only for the fork and usually too high and the wrong angle for rear post mounts.
  18. #568
    It is all good now that I have it how it is supposed to be, just like in the tech doc.
    Adapter on the front 180mm rotor and no adapter on the rear 160mm rotor.
  19. #569
    Sep 2012
    Mine is setup just like yours, 180mm front, 160mm rear. Shimano stuff and it stops like a Champ
  20. #570
    Jun 2012
    Recieved me TX29 (1) this afternoon. Photo dont even come close to how good this bike looks. As with others here my LBS did not run the rear brake internally so they are going to do this next week. Also had them fit my Reverb so gave them some extra work.
    A couple of things I have come across... Firstly I ordered a XL as I am 6'4 with long legs. I have a 420mm Reverb on my TX29 but discovered the XL only has a 21" Seat tube C-T. The Giant Geometry says XL/56 but my XL measures 53cm C-T. This is very strange and only because I have a 420mm Reverb seatpost I might be in trouble with the minimum seatpost lenght. The reverb only required 80mm minimum in the frame. Need to check this does not cause problems to the warranty with my LBS.
    Also I have fitted me Schwalbe Hans Dampf (2.35) which I love for the massive grip which helps my Clyde size in the wet conditions we usually ride. The rear tyre does not seem to fit the rim correctly and has a slight hop cos the tyre is not fully seated in one part? Anyone else try 2.35+ on the Giant rims? Front tyre seems to be sitting right. Might re-fit the tyre tomorrow.
    I also has a 180mm disc up front and a 160mm disc down back.
    I only got out on the bike for a short ride but I love it already. Feels great. With all the positive reviews here I was wondering if I would feel the same, Yes I do. Love this bike.
    2 hour trail ride on some tough trail this weekend. Cant wait.
  21. #571
    Sep 2012
    ^ can u take a pic and verify that u have a 180 mm front rotor. If u do I want giant to send me one.
  22. #572
    Jun 2012
    Sorry that actually a 170 HS1 on the front. I think the 170mm dimension might be due to the profile of the disc. Its not a circle so maybe sram call this 180mm but thats a guess?
  23. #573
    Sep 2012
    In have the 170 too.
    I heard they specd the bike early and SRAM changed to the new 170.
    Btw. I have 20miles on my x1 and already have the fork sent to fox. It had bad sticktion at very top , took about 40lbs to break the first inch.
  24. #574
    see me rollin, they hatin
    Reputation: NicoleB's Avatar
    for anyone who is still "thinking"....just get this bike! mine is close to two pounds heavier than my racier bike i had before, but it somehow climbs up hills better. the extra weight comes from the bigger wheels and dropper post, but it hasnt been an issue. I have the XO by the way....
    fap
  25. #575
    Dudette
    Reputation: petey15's Avatar
    ^ Ditto! For me, this bike has been nothing short of amazing. The only modifications I've made are to swap out the saddle for a Specialized Ariel (so much more girl-friendly than the Fizik) and to trim the bars down from 720mm to 680mm (liked the wide bars but had a few too many scrapes with trees). Had an awesome ride last weekend down a trail that would give me fits on my 26" bike. The larger wheels and slacker head angle seemed to be just the ticket and I emerged with a BFG! Looking forward to giving the slightly narrower bars a try this weekend.
  26. #576
    Nov 2012
    Smile Trance 29 X 2
    I've read this whole thread - some great comments - but not a lot said about the X 2
    Unfortunately as much as i'd like to I can't afford to go for the X1 or X0 so an X2 is for me.
    However i'd be interested to hear what peoples opinions on first things to change would be? Are the Sram gears really much inferior etc?
    Thanks in advance
  27. #577
    i test rode the X2 just to get an idea of fit. Seemed decent, but i'lll never really know because i didnt take it any further than the dirt parking lot. I liked the way it looked tho! I think it's around 30-31 pounds?
    fap
  28. #578
    Quote Originally Posted by petey15 View Post
    i trimmed mine down to 660! some people laughed at me, but that's how i always run my bars. i have a small upper body and narrow shoulders. there's no point in having extra inches of bar sticking out beyond my hands. My most commonly ridden trails have SUPER narrow tree passages, and most people i ride with, have to stop and walk thru a couple spots because their bars wont fit. I can just barely squeak thru without having to get off the bike i've had some near serious spills from whacking my bars, so i'm narrow fo' life.
    fap
  29. #579
    Mar 2012
    Quote Originally Posted by Bin182 View Post
    Thanks in advance
    not having ridden the x2. I always put wheels and brakes at the top of my shopping list. i can live with crappy gears. So long as you aint racing i think low end stuff is fine as long as kept tuned. But wheels are always a great value upgrade...and brakes will save your life...generally.
    Maybe the saddle might have to be turfed? I thought the saddle was OK on the x1 myself. And not that we are talking about it, but the saddle on the XTC is horrendous.Worst saddle ever. Its like having a seatpost rammed up your arse
  30. #580
    Oct 2012
    Got a couple rides on my X2. Weighed 30.7 stock and 28.6
    after putting on Stans Crest wheelset, tubless. Like the
    bike a lot after a couple of easy rides. I have a very sore
    right thumb, from an offroad motocycle crash, and have
    a little trouble pushing the shifters. I have ridden with
    grip shifters for a long time and think I might try the new
    Sram XO 2x10 set. Kind of expensive, but I think they
    will be worth it for me,
  31. #581
    Sep 2012
    Thanks in advance
    I've had my X2 for about a month now and have had it out on the trails quite a few times now. I love it! I think the shifters are crisp, and I haven't dropped a chain or missed a gear. It is around thirty pounds. The only changes I've made so far is a shorter stem and a better saddle.
    I agree that the wheels would be the next best upgrade, but for the time being I'll go tubeless and just beat the crap out of these!
    I rode all three models, but for the level I'm at the X2 fit the bill perfectly. As things break or wear out I'll upgrade. The bike rocks, and you won't go wrong with any model you buy!
  32. #582
    Quote Originally Posted by Zaskar24 View Post
    Thank you for the reply. What model do you have? How much clearance is there in the rear for tires?
    How have the Giant branded whhels on the X0 been holding up for those who have them?
    I have the x0. I can't answered the questions about the clearance. It has hobby nics on it and they are awesome. As for the rims, I am a Clydesdale and yesterday took the bike to a more advanced trail with lots of roots, rocks, dips and small drops. Wheels have been great. They are tuneless capable and that is on my list. Other upgrades will include a carbon bar.
    Rode today on my usual trail which is not difficult but the bike just makes it more fun as it is fast and as I get used tithe bike I can be aggressive in turns and it just devours roots, rocks and other trail chatter. I find it climbs like a goat. I am by no means a high level rider and think that in the hands of someone with more skill and in better condition, this would be off the chains....
    My gut is that we over analyze thesenthingsmams just need to get a bike that works forums and go ride!
  33. #583
    Does anyone know if this crank is compatiable with this frame, SLX Shimano ?
    Product
  34. #584
    Dudette
    My gut is that we over analyze thesenthingsmams just need to get a bike that works forums and go ride![/QUOTE]
    Taking oldmanincary's suggestion - that's exactly what I did today! The weather was perfect - 61 degrees and sunny when I began my ride. I got a few shots with the self-timer and thoroughly enjoyed the ride!
    Attached Thumbnails Attached Thumbnails Trance X 29 official intro-brookside-bowl.jpg
  35. #585
    Quote Originally Posted by oldmanincary View Post
    Thank you for the reply. I got to test ride an X2 on my local trails yesterday and it was a pretty nice ride. Very plus compared to my steel hardtail. This has definitely joined my list of FS 29s that I am looking at. It will be interesting to hear how the wheelsets on the X0 hold up for those who have them.
    Anyone try a Fox 34 on one yet?
    2011 Quiring 29er Steel Hardtail
    2009 Gt Peace 9'R SS
    2009 Surly Cross Check
    1997 GT Zaskar
    1985 Raleigh Elkhorn SS
  36. #586
    Reputation: pharcyde's Avatar
    Trance X 29 - nydownhiller's Bike Check - Vital MTB
    This guy has a 34 but IMHO, that has destroyed the look of the TX290.
  37. #587
    May contain nuts
    Reputation: Haggis's Avatar
    Quote Originally Posted by pharcyde View Post
    Destroyed? Wut?? The TX29 is an ugly duckling, and that's by FAR the best looking TX29 I've seen... but who cares; how does it go with a 34, single ring guide and decent rubber?
    Attached Thumbnails Attached Thumbnails Trance X 29 official intro-s1600_trance_x_29.jpg
  38. #588
    Sep 2012
    So is the above bike back to over drive 1. The guy told me at fox they have no kashima od2
  39. #589
    DFMBA.org
    Reputation: MTBeing's Avatar
    I demoed the TX29Zero last Sunday and I've never ridden anything but a hardtail. I went to the demo to ride an Anthem X 29 but there was a line, and my time was short. Ended up demoing a size XL (because that was all that was avail) and at 6',1" I was surprised how well the bike fit. This bike was a tad heavy (Giant rep estimated 29#) but it felt very nimble on the twisty desert singletrack. Not sure if it was my favorable impression of a f/s bike, having not ridden one, or the fact that this bike was 'that' good on the trail, but I left impressed. I don't have the budget for the Zero and I'm wondering if the AX29er with a 120 fork would suffice. I'm more into XC but in Arizona sublime trail can quickly become rugged. My head spins. Could this be the perfect bike for AZ trail riding?
  40. #590
    Sep 2012
    I paid far less for mine than sticker. Far less !
  41. #591
    Sep 2012
    Quote Originally Posted by CCMTB View Post
    Wow, I'm coming from the same background in that I rode a hardtail before getting the X2 29er. I absolutely love this bike, and it has not let me down yet. I just finished the Desert classic this morning and each time I go out it just puts a smile on my face. The F/S has allowed me to ride more technical portions and at the end of the ride I don't feel beat up at all, like I did on my hardtail. I am an older rider so I'm sure that's part of it.
    Were did they have the Demo? I know Specialized had one last weekend at Mcdowell mtn.
    And yes you can get this ride below list.
  42. #592
    OK, so I gave the bastard fizik Gobi saddle a good go, and it is the only saddle that ever gave me saddle sores! The stiching on the sides that attaches the slippery material rubs me the wrong way and takes the skin off after long rides! I like how firm it is, but hate the chaffing from the stitching!
    What saddles do you guys reccomend!?! Have had good luck with a few WTB saddles in the past...may head that way...
  43. #593
    Feb 2006
    ...Sorry wrong post
  44. #594
    Feb 2006
    Couple questions for X2 owners
    Does this frame have a standard 1 1/8" - 1.5" taper fork? (and not Overdrive 2)
    And what letter is the blue and red letter on the shock?
  45. #595
    Sep 2012
    Quote Originally Posted by VERT1 View Post
    Yes, the X2 has the standard 1 1/8" - 1.5".
    Red L Blue M
  46. #596
    Dec 2009
    Does anyone know is the frame in Trance X2 the same what you can buy alone? I know that the shock and colour is different, but is weight the same? I want to buy Trance X2 and upgrade in future, but I don't want discover that the frame is heavier. I have photo X0 on scale and weight in medium is 2670g, but what is Trance X2 frame weight?
  47. #597
    Reputation: EGF168's Avatar
    Picked up my frameset today, looks stunning! 6.53lbs in XL with seat clamp, headset cups and chainstay protector.
    Can someone measure the seat tube length on their XL frame? Measured from centre of BB to top of seat tube I'm getting 520mm-ish, so a lot less than the 560mm/22in listed in Giantís geometry.
  48. #598
    Dec 2009
    EGF168, could you post pictures your frame, please? Do you have bolts on the bottom side down tube?
  49. #599
    You said you got a great deal spazdad? Which modwl did you get?
  50. #600
    Quote Originally Posted by rafalwspin View Post
    Iíll see if I can take some pictures tomorrow. There are bolts used for running the rear brake line under the down tube rather than internally. The bolts squeeze the cable with a little wraparound clamp.
