Results 1 to 10 of 10
    Dec 2012
    Trance X 29 Knocking suspension
    When the rear suspension compresses I'm hearing/feeling a knock...I removed the shock to isolate it, seems to be the rear derailleur...when i take the chain tension off of it, knock is gone...is this normal? abnormal? anyone else experience this?
    Oct 2012
    Does it have a 'clutch' derailleur? If so, it would have to slip to accommodate chain growth as the suspension compresses. If the cage resists twisting in the counterclockwise direction more than just spring tension then there is a clutch inside. Could be what you're noticing.
    Your Best Friend
    Reputation: Silentfoe's Avatar
    Quote Originally Posted by bulerias View Post
    +1
    For most people, riding with a clutch type rear derailleur is a new experience. As the suspension cycles, you may or may not notice the r.d. doing it's thing. If it really drives you crazy, you could put a regular r.d. on the bike to see if you like the change.
    I'm a mountain bike guide in southwest Utah
    I bet its the sram X9. That's it. I'm either skippin gthis gen or going over to shimano
    -Don "LordDRIFT" Draper.
    Dec 2012
    yes...must be what it is...i noticed it in a quiet garage....I'm sure it does it all the time...when riding I'm more concentrated on the trail ahead...
    So that knock is normal operation?
    Dec 2012
    I'm gonna run it by the LBS that I got it from...see what they say...
    Dec 2012
    LBS basically said its not broken...I can't see how its normal though...when i bought the bike it didn't "knock"...Doesn't seem to be any adjustment for the clutch either...
    May contain nuts
    Reputation: Haggis's Avatar
    How long is the cage? (Measure jockey wheels centre-centre, 100mm=long, 75mm=short). Should be long with 39T capacity requirement.
    Edit: It's long cage, so the Type 2 clutch knock can't be related to insufficient cage length as some people have suggested in other threads...
