Results 1 to 5 of 5
    Giant Anthem
    Reputation: 2fst4u's Avatar
    trance headset bearings any ideas?
    Me again-another fricken bearing problem on my 06 trance. As well as the destroyed suspension bearings and bottom bracket my headset is pretty rough as well. I don't even know how to take them out. Can I replace just the bearings or do I need a whole new headset? It's an fsa 45 degree. Not even sure what kind of headset it is-much differnt than my old hardtail-can anyone give me the lowdown on how these work? Thanks
    Friendly Neighborhood MTBer
    Reputation: kabayan's Avatar
    Giant uses a Zero Stack headset on the Trance. Cane Creek and FSA make zero stack models.
    If you can't play, display.
    Giant Anthem
    press?
    Quote Originally Posted by kabayan
    Do I need a press to remove old ones?
    Bearing cups press into the frame. The cartridge bearings themselves are a slip fit into the cups. You should be able to take them out by hand. If the grease etc, has dried a little you might need to pry a little, with a screw driver.
    The bearings can be replaced by themselves. I am not sure what the easiest place to get bearings is/are. Both FSA and Cane creek seem to use the same bearing supplier.
    You can order replacement bearings online from Enduro bearings ~$15 each, and have some new ones. Their bearings and seals are usually a little nicer than stock offerings.
    Giant Anthem
    yeppers
    Quote Originally Posted by the.vault
    Thank you-thats exactly what I needed to know-I'm probably going to order headset,BB and rear susp. bearings from enduro. I'm going out right now to try a little harder to pop out the headset bearings.
