Results 1 to 34 of 34
    Reputation: SupahG33K's Avatar
    Aug 2013
    Trance 27.5 - Broken Hanger, Mangled Derailleur
    Bunny hopped off a curb today and was greeted with a horrible grinding, banging, awful sound. The rear derailleur hanger had snapped and inertia threw the assembly into the spokes...nearly went OTB just trying to stop before causing more damage!!
    So...couple questions...
    1. Now seems like a good time to convert from the 135x5mm QR to the 12x142mm axle as found on the SX and higher trim bikes. How do I get those dropout parts from Giant?
    2. Obviously I need a new rear derailleur and hanger (perhaps a stronger hanger?). Any suggestions on rear derailleurs?
    Obligatory pictures attached.
    As always, TIA!
    Cheerz!
    Trance 27.5 - Broken Hanger, Mangled Derailleur-brokenhanger.jpgTrance 27.5 - Broken Hanger, Mangled Derailleur-mangledderailleur.jpg
    Reputation: pablobell's Avatar
    Oct 2013
    The dropouts are the hanger, to upgrade you will need to order 142X12 dropouts from your LBS part number: 1280gs834609b1
    The 142X12 DT Swiss Giant QR axle is part number: 1529gdtrws402
    Crucially, you will also need a new hub to fit the wider axle through.
    Aug 2013
    Wow, I was sooooo not expecting actual part numbers!! Thanks for that!!
    I'm running Hope Pro II already, just have to swap the end caps.
    I'm looking at replacing the derailleur with a Shimano SLX M675...thoughts? I don't really want to shell out money for a higher end derailleur; especially seeing as I'll prolly just break it too...
    Reputation: Kiwiplague's Avatar
    If your worried about the cost then you could also look at the Deore shadow+ derailleur RD-M615 as well.
    I don't crash, I just have slightly uncontrolled dismounts!
    Oct 2013
    Good choice, XT will only be no better, just lighter.
    If you want an upgrade, better to get the XT shifter, slightly better shifting, smaller, lighter. Best of all, it can upshift two gears with one pull. Also, you are unlikely to break it!
    Aug 2013
    Quote Originally Posted by Kiwiplague View Post
    Say...that looks exactly the one I just munged. Price-wise it looks the same as the 675 from Jenson (it's on sale right now...maybe I should get two!)
    Oct 2013
    No clutch on the 615.
    EDIT: not true, there is now, see below.
    2010 Glory custom FR
    Reputation: frango's Avatar
    Quote Originally Posted by pablobell View Post
    I am afraid these service parts numbers. They are not meant to be sold, actually. These two items are also available as aftersales parts. I will try to find their numbers when I get to the office tomorrow.
    pozdro
    frango
    Aug 2013
    As usual, thanks for the superb replies. It's folks like you all who make this forum so great.
    So, these are
    270000000 DERAILLEUR HANGER 142/12 UPGRADE KIT
    300000003 RWS REAR SKEWER FOR 5 X 135MM DROPOUTS
    pozdro
    frango
    Aug 2013
    Thank you very much, all of you. For the part numbers, the suggestions, all of it. My new derailleur just arrived too! Gotta love living in AZ...standard shipping from Jenson gets here overnight!!
    Cheerz!!
    Which one did you go for in the end?
    Aug 2013
    I got the M675-SGS.
    ETA: $65USD+Free shipping over $50, ordered at 4PM yesterday, in my hands by 10AM. Tough to beat that...
    Awesome deal!
    Just try not to mangle it as quickly this time
    Aug 2013
    Right!!!
    San Miguel Beer Drinker
    to the OP:
    yours didn't have a spare derailleur hanger in the box?
    Aug 2013
    Quote Originally Posted by IstongKowldPaRin View Post
    to the OP:
    Oh sure it did...
    This is the third one I've broken...
    Did I mention I have trouble recognizing my limitations as they flash past me?
    Oh. Carry on then!
    I might do the same conversion too. Hunting down a converter for my hope rear hub.
    Dec 2011
    Quote Originally Posted by SupahG33K View Post
    Oh sure it did...
    Sounds more like the limitations of physics Quit crashing into things
    Aug 2013
    Very true I suppose...the other two broke due to impacts, as evidenced by the heavily customized chainstays (first pic). Admittedly, I'm thoroughly impressed with the amount of beating this bike has withstood.
    This last one was a bit of a baffler though. It was nothing more than a "sideways" bunny hop off the sidewalk...standard size curb height. Only thing I can imagine is a bit of wheel-flex and the <strike>inertia</strike> momentum of the derailleur caused a brief, but catastrophic, interfacing of the cage or derailleur body and spokes. I wonder if the doing the same kind of "hip" on dirt would have allowed enough tire slippage to prevent the wheel-flex...but the added traction of pavement was too much.
    Oct 2014
    New question here.
    Hi.... I need these for a 2015 Trance.
    No stock in South Africa, so is there a good bike store I can purchase them from online? No luck anywhere... would also need DHL, Fedex or UPS shipping.
    Thanks!!!
    Aug 2013
    I was finally able to complete the conversion last week. My LBS had to get them direct from Giant; I think the parts came out of Chicago. It's definitely a worthy upgrade.
    Oct 2014
    Jealous to hear!
    New wheelset is here waiting and Giant South Africa says another month to get the parts. I really just want to order and overnight them to SA. Anyone know any good online bike shops that could? Struggling with Google.
    Thanks.
    Oct 2013
    Quote Originally Posted by SimonZA View Post
    Jealous to hear!
    Thanks.
    Try Home - www.mcconveycycles.com
    Aug 2014
    For what it's worth I landed a pretty sideways bunny hop into a berm with the stock derailleur and nothing happens. It sounded like the tire almost peeled off but no damage. I'd guess yours was about to fail from previous impacts.
    This issue normally caused by the impact before the one that broke your RD. I once took a close-call hit, rd stretched,chain dropped. Managed to ride down and go back. But broke it at my housing area on a tarmac.
    Reputation: teK--'s Avatar
    Dec 2011
    Just be careful with the new thru axle check it before (and during the first few rides).
    You might find that it slowly unwinds itself. It has been suggested due to braking torque forces.
    I ended up using some blue loctite on mine and now it stays in place rock solid. Not really practically if you regularly take your rear wheel off for transport or other reasons though as Loctite takes a few hours to cure.
    Aug 2013
    Thanks for the tip. It's usually part of my preflight checklist, but I'll make sure to keep it in mind.
    Reputation: DeArman's Avatar
    Jun 2014
    I did this conversion to my 2015 Trance with Hope Pro hubs. Just ordered the dropouts and axle and swapped them out. I haven't had any issues with mine coming loose though. I don't say this very often about stock bikes because I understand companies have to keep certain bikes in a certain price point to move them, but all Trances should've came with them from the factory.
    Rocks belong
    I've got about 5 brand new Giant 27.5 12x142 hangers if anyone wants one.
    $10 shipped
    I like 'em long, low, slack and playful
    Jun 2015
    I have the same issue as OP but with Roval Traverse fattie wheels that are 135/142
    My question is if my bike is 135 QR in the rear how will the 142x12 fit if the frame is only 135mm wide in the rear
    Will I have to have the new 142 caps made and 12mm thru axle machined with more threads to allow it to fully tighten or will it just work if I order the thru axle and hanger mentioned?
    I didn't see OP say he had any problems with this conversion or machine work so any help or guidance would be greatly appreciated
    Oct 2013
    Quote Originally Posted by SUBARUGUY123 View Post
    As long as you are installing on a Trance 27.5 frame you only need the dropouts/hanger and the Giant axle.
    The dropouts are two pieces that bolt into the frame with tiny bolts and have holes for the larger axle. You have to get the Giant axle as although it's made by DT Swiss it has a custom thread pitch.
    Jun 2015
    Awesome thank you very much for the info. I was so lost... I really appreciate the fast response and help!!!!!!
  1. Broken SB66C Mech Hanger
    By Chriswilk@gmail.com in forum Yeti
    Last Post: 04-16-2013, 03:54 AM
  2. Replies: 10
    Last Post: 03-19-2012, 04:50 AM
  3. Snapped Hanger, Broken Spoke, SS to get home
    By MREGAN in forum All Mountain
    Last Post: 12-19-2011, 10:22 AM
  4. Trance Hanger
    By jim graham in forum Giant
    Last Post: 07-30-2011, 06:58 PM
  5. Blur LT2 broken derailleur hanger
    By JD Parker in forum Santa Cruz
    Last Post: 06-08-2011, 10:47 PM
