Results 1 to 5 of 5
    Reputation: bosbik's Avatar
    Talon 2 29er BB size type
    Hi,
    Just wondering what type/size of BB i would get if I were to change the stock cranks to a shimano or SRAM?
    Fat Is Where It's At Moderator
    Reputation: DiRt DeViL's Avatar
    It will depend on the cranks, specially if they're 3 piece; the bb shell is 73mm btw.
    For 2 piece cranks with external bearings just follow the instructions regarding how many and where to put the bearing spacers for a 73mm shell.
    ah ok..so basically the BB should be a 73mm BB?
    Quote Originally Posted by bosbik View Post
    Yeap if you'll be using 2 piece cranks, if you plan on using 3 piece cranks the bb will be 73 x spindle lenght for the crank set, usual length is 113 but varies depending on the brand and or model.
    thanks!
