Results 1 to 10 of 10
    Switching from Overdrive 2 to standard taper - What do I need?
    Getting a replacement fork from Fox for my Anthem X1 29er. Much better fork than my oem one, it's Float Factory Kashima fork coming to me.
    However, the steerer is a standard taper, so I'll need a stem and headset. Stem is easy, but in terms of headset pieces, what do I need to buy? Recommendations?
    Reputation: pablobell's Avatar
    Oct 2013
    Just the top half, stick with FSA I reckon, good value, reliable. Or go Cane Creek. Make a $10 bearing press with 1/2 inch threaded rod as below
    Sep 2013
    I am also interested in this. I have a Reign SX. What FSA headset would you suggest?
    Rocks belong
    Quote Originally Posted by pablobell View Post
    Where do you get the press pieces in the pic?
    Thanks for the responses! I spoke to FSA, and this is what they said: FSA Orbit 1.5 ZS No.57 Tapered Headset. I couldn't find a separate upper, so I got the whole thing.
    It fits a top tube inner diameter of 44 and 56 mm which is what my Anthem has, I presume that's the normal top tube inner dimensions on most tapered headset bikes?
    I also ordered a stem and spacers. Only difference is that my old stem was 8 degree +/-, new one is 6. I had it flipped to negative rise, which means to get the bar equally low I'll go a small spacer lower on stack height. So I should be all sorted. Now waiting for my fork and parts to arrive so I can ride.
    Oct 2013
    Quote Originally Posted by hokiebrett View Post
    Those are from this toolset: Park Tool Co. BBT-90.3 : PressFit Bottom Bracket Bearing Tool Set : Bottom Bracket
    What specific model fork did you get? What year, length travel? CTD Trail Adjust? An older NOS RL or RLC? Let us know how you like it.
    Did you have the bouncy feel in rough terrain at speed with the Evo fork?
    Sep 2013
    Hi again. When changing from OD2 to a standard tapered fork do I need to change only the headset bearing or also the upper cup?
    Quote Originally Posted by Paris Galanis View Post
    You need to change the top cup, along with the top bearings. This is why you need a bearing press or need to ask your LBS to press in the top cup.
    Sep 2013
    Hi. Thank you very much.
  1. standard tires - standard rims - ghetto tubeless
    By eddieruko in forum Wheels and Tires
    Last Post: 09-12-2013, 04:45 PM
  2. Replies: 4
    Last Post: 05-31-2013, 06:49 PM
  3. 2011 reign 2 overdrive or overdrive 2?
    By chef7734 in forum Giant
    Last Post: 01-12-2013, 11:12 AM
  4. Dirt Rag article on Giant Overdrive 2 Headset standard
    By BritOnTour in forum Bike and Frame discussion
    Last Post: 04-05-2012, 04:21 AM
  5. 2011 HIFI BB standard and frnt derall standard?
    By MTBRT in forum Gary Fisher
    Last Post: 05-13-2011, 12:56 PM
