Results 1 to 2 of 2
    Reputation: ls1geezer's Avatar
    New question here. Swapping out P-XC to ???
    I have the urge to swap out the 26" P-XC wheels on my 2011 Trance X2. 70% of my riding takes place on dry hard-pack trails and logging roads, the other 30% is normally on the road riding to and from the trails. I weigh about 180 with gear and backpack. No jumps bigger than a few inches. I'm probably going to switch my tires to Kenda SB8 or something similar.
    My question is for folks that have already switched wheels/tires. Did you find and noticeable difference good or bad and what wheel tire combo did you go with.
    This is what the guys at ProWheelBuilder.com suggested when I told them I wanted to pay about $1000 :-
    FRONT WHEEL SUMMARY
    Drillings
    32
    Rim
    STANS NO TUBES ZTR CREST DISK BRAKE BLACK FRONT RIM $88.00
    26in
    Stans Tape and Valve Tubeless Converstion Kit for 1 wheel Installed + $11.00
    Hub
    CHRIS KING ISO BLUE DISC 15MM HUB $213.00
    Thru 15mm
    Spokes
    DT SWISS COMPETITION 14/15/14 GAUGE BLACK SPOKES $1.72
    Lacing Pattern
    Three Cross
    Nipples
    DT SWISS BLACK 14G 12MM BRASS NIPPLE $0.20
    Weight
    767.16 grams
    Price
    $373.44
    REAR WHEEL SUMMARY
    Drillings
    32
    Rim
    STANS NO TUBES ZTR CREST DISK BRAKE BLACK REAR RIM $88.00
    26in
    Hub
    CHRIS KING ISO BLUE DISC REAR HUB $404.00
    *QR 135mm MTB
    *Shimano/SRAM 8,9 or 10spd
    *No Skewer
    Spokes
    Lacing Pattern
    Three Cross
    Nipples
    Weight
    896.16 grams
    Price
    $564.44
    Thank you in advance for any suggestions or advice.
    DFMBA.org
    Reputation: MTBeing's Avatar
    IMO, the quoted wheels are more than you would need. If I were buying based on your situation I would go the the Stan's website and order a set of these:
    ZTR Arch EX 26" Stock Wheelset
    I ride with Arch 29" wheels and I weigh 20lbs more than you do (without gear). You probably don't need the CK hubs as the Stan's-branded hubs are very good. With your riding style, I'd pick this in a heartbeat.
    Edit: I did notice a difference when I switched from the oem wheels on my bike, but they weren't Giant wheels.
    Please donate to IMBA or your local IMBA chapter. It's trail karma.
