Results 1 to 6 of 6
    swap everything from 05 reign 2 to 2011 reign 0 frame?
    my 05 reign 2 has been a slow upgrading process over the years and recently the frame has been sadly damaged.
    can I simply swap everything from it (except rear shock) over to a 2011 frame?
    bottom bracket is press fit on the 11, so i am guessing my crank will not fit? it is the raceface x type
    kneecap
    your straight 1&1/8" steerer tube fork will need an adapter for the tapered head tube on the new bike.
    &, you're correct in assuming the crank won't fit the new bike as well, although maybe just a new bearing set might suffice.
    Both those issues has dampened my enthusiasm to dump my 08 reign.
    thanks, i love my 05, but the rear frame needs replacing and its just getting old.
    kneecap
    well, good thing is the new frames are lighter, even my 08 dropped somewhere between 1/2 to 3/4 of a pound from my 05
    where do I find a correct adapter for the headset? not sure what i'm looking for
