Results 1 to 21 of 21
    Oct 2010
    Stem lengths on your REIGN
    I just picked up my reign 2 this week and I had a bunch of new stuff to throw on it. The bike is awsome it is so smooth and even with the pro-pedal off and fork lockout off when you climb out of the saddle it doesn't bob to much. This bike is way better (so far) then fuel ex.
    My question is what stem length are you guys running on your reign if you changed it out. I have a Large size and it came with a 90mm it felt good but I think I was going to try a 70mm truvativ aka white.
    SLX crank
    x9 shifters and rear D.
    Elixir CR brakes
    Bontrager Big Earl bars
    KS i900r seat post
    Waiting for BWW to convert my old Pure Hub to a convertible hub so I can put my white wheels on the bike. The XCR wheels are way lighters then the DT Swiss.
    2011 Giant Reign
    Stu
    Stu is online now
    Renthal 50mm on mine
    IMG_3494 by StuE1, on Flickr" width="549">
    Reputation: krispy@go-ride.com's Avatar
    Giant Contact 70mm. Super light, black/white scheme, reasonablty priced and comes with Ti bolts!
    Giant Reign Advanced 27.5/Rockshox Pike/Sram XX1
    Giant STP/ Rockshox Revelation
    Salsa Mukluk/Rockshox Bluto/Sram X1
    24v
    24v is offline
    Scratch That Itch
    I have a 0 rise 70mm Thomson on my med. Reign. It came with a 90mm, but the 70mm definitely feels better to me.
    Huffy Rider
    Reputation: motochick's Avatar
    Jun 2010
    Small frame, changed mine to a 50mm, perfect!
    Stray Bullet
    Reputation: Nagaredama's Avatar
    Renthal stem is sick. I have one my slalom bike, super stiff.
    Im still on the 90mm (old habits die hard)
    ordered a haven stem at 85mm, might try a 70 too to see how it feels.
    The mountains are calling and I must go
    Just tossed a 70mm AKA on my Medium Frame......had a 90mm.
    I have a 0 rise 70mm Thomson Elite stem on a medium 2010 Reign 0. The 90 was a tad on the long side and the 70mm way better.
    Dec 2008
    50mm, though I used to race DH and still set a bike up for the stem rather than the climb.
    I think climbing is more to do with fitness anyway, but it is very hard to descend technical terrain with a long stem. And falling off your bike while ascending is generally a lot less painful than on a descent.
    6"+ frame begs for a 70 or less.
    Oct 2010
    I ended up sticking a 70mm aka white stem along with 780mm Answer Protaper bars on. Its a really good combo so far.
    2011 Giant Reign
    Going from a 90 to a 70 stem actually felt wierd to me. Amazing what 2cm's makes.
    Are stem changes something you need to get used to? Or should it feel good right away?
    Give it a ride or two...
    I gave it a 2.5 hour long ride last night. Up and down, didn't feel all that good. Maybe I will try flipping the stem for a -6 deg angle to lower the bar a bit. I prefer a more laid over body position on my bike.
    Quote Originally Posted by canuck_tacoma
    Did you couple the stem change with a wider bar?
    If not, you might end up too upright for your preferences. There is a reason that people switch up stems/bars together sometimes...
    So tried the 70mm inverted which lowered the bar a bit, felt pretty good. Cured the front end wash out and climbed well. Will have to give it some more rides before I stick with it. Definetly noticed the steering being more responsive. Hard to beleive what a difference 2cm's can make.
    May 2014
    Hello, Im new on this forum stuff, I need some help because I really want to change the 90mm stem for something like 50mm, I use my bike 80 % of the time for descent. As you guys should know the Giant Reign 1, 2013 comes with overdrive 2, which is for 1-1/4 steering tube diameter... that is what I understand.
    So the question is what options do I have to get a shorter stem, different brands than giant stems...
    Reputation: tiltedworld's Avatar
    Medium '13 Reign - I went with a 50mm Answer stem, coupled with the 720 AM carbon bars
    DJ Stem | Answer Products
    ProTAPER® Carbon 720 AM | Answer Products
    Love the change and the handling changes.
    Reputation: Iboated's Avatar
    May 2010
    Large '13 Reign and I switched out to a Race Face 50mm and Deity D30 bars.. Made a world of a difference..
    Feb 2015
    Hi guys, someone knows the original stem length of the Reign 1 2012 in a small frame?
