    Reputation: DerrickT's Avatar
    SRAM BB86 for Trance X (89.5mm shell)?
    Hi, guys.
    What SRAM pressfit can I use on the 2011 Trance X frame which has a shell of 89.5mm? Can I use the BB86 "Road" with spacers?
    According to SRAM's manual, BB86 should be used on 86.5mm shells only (road) while BB92 is used on 89.5mm/92mm shells.
    http://cdn.sram.com/cdn/farfuture/iJ..._cranksets.pdf
    http://cdn.sram.com/cdn/farfuture/jK...ranksets_3.pdf
    Reputation: dynamic161's Avatar
    Jan 2011
    I just used a BB86 with spacers on a 2012 Anthem X 29 that has the same shell width. No issues.
    '12 Anthem X29 Custom Build
    '11 Masi Evolution Custom Build
    So you put (1) 1.5mm spacers on each side?
