Results 1 to 9 of 9
    Squeeky seatpost
    So .... I take it that the consensus is to ditch the Easton and go with the Thomson to get rid of that annoying shim squeek?
    XC rider/racer
    Reputation: Andy 's Avatar
    It worked fine for me, once I did the swap not a single creak since
    Not so much the Easton as it is the shim
    The Easton post isn't the problem, its the shim. My VT will take a 30.9 Easton EA50 post and is quiet as can be; you can actually adjust the height without jacking around with the shim, which is another plus
    Clean and grease seat post
    Quote Originally Posted by bob5702
    and seat tube, works for a little while.
    Reviewer/Tester
    Reputation: Rainman's Avatar
    Get the Thomson..you wont be sorry...ever.
    R.
    Niner EMD
    Reputation: nygeo's Avatar
    WHY is the shim there in the first place? Ive never seen this on a factory frame as stock parts. Is it to keep the weight down by using a smaller diameter post? Maybe to protect the frame?
    Also, What is the seat tube diameter of the '03 NRS?
    thanks
    "Drinking and driving is wrong, but hey, the kids gotta get to school right?"
    -Dave Attell
    Niner EMD 1X10
    Combat Wombat
    Reputation: BrianU's Avatar
    I switched to a Thomson on my VT-1.....
    About every three rides, I had to pull the shim and regrease it to keep it quite. I could see small bright shiny spots in two places on it where it was working around no matter how much I tightened the clamp. I replaced the 27.2 post and shim with a 30.8 seatpost so that I do not have to use the shim. I do not think a 30.9 would fit because the 30.8 fits pretty snug.
    I read somewhere that the seatpost is used as part of the structural integrity of the seat tube. The shim ensures that not having the seatpost in far enough to maintain this integrity is not an issue. Looking closely at this part of the bike, I can believe this. I replaced my seatpost with a 30.8 X 410mm and it actually sticks out of the bottom of the seattube about an inch.
    Brian
    The squeeky shim on my new NRS really bugged me so I replaced the shim/post with a 30.9 Easton Carbon post. My LBS ran a quick hone through the seat tube to clean it up to a 30.9mm dia. and it works great. Don't worry about taking the seat tube up to 30.9mm from the stock 30.8. That's only .004" and it won't cause a problem. My bike is now squeek free and a 1/4lb. lighter.
    [paste title here]
    Reputation: mtnbikerdude87's Avatar
    Another vote for the Thomsons. A lot better than the titec x-wing I had before. Its solid and I dont feel any flex.
    Keep Pedaling
  1. Skewers and seatpost clamps
    By Rangernoot in forum Wheels and Tires
    Last Post: 06-23-2004, 07:36 AM
  2. Ti seatpost vs. Carbon seatpost
    By psOption3 in forum Weight Weenies
    Last Post: 04-12-2004, 09:00 AM
  3. My seatpost slips
    By dgangi in forum Giant
    Last Post: 03-15-2004, 07:05 PM
  4. hey guys, 29.2 seatpost woes....
    By carbnjunkie in forum Weight Weenies
    Last Post: 03-04-2004, 05:06 PM
  5. thomson seatpost help
    By dompedro3 in forum General Discussion
    Last Post: 02-17-2004, 08:10 PM
