Results 1 to 6 of 6
    Reputation: Rainier Boy's Avatar
    Upset Squeaky seat post on Rainier
    I have a stock standard 03 Rainier which i ride mainly on bike tracks and some road. After a while in the saddle an annoying (read REAL annoying) squeaking comes from the seat/post... Any solutions on how to fix this??
    Cheers
    ... and if we just ... Here is a tip
    Quote Originally Posted by Rainier Boy
    Cheers
    Why not try KY gel, after extensive testing, I am convinced this will do the trick, hell it fixes all my problems.
    XC rider/racer
    Reputation: Andy 's Avatar
    Seatpost & Shim
    I`m not sure if the Rainier uses the seatpost shim as the Giant VT, NRS and XTC do, but if it does heres a temporary fix i used on my VT---
    Remove seatpost, then remove shim.
    Thoroughly clean seatpost and shim and make sure all grease and dirt etc is removed.
    Clean inside seattube with a rag.
    Relube shim and seatpost with grease, then re-assemble.
    I found this seemed to help for a few rides before the creak returned.
    Permanent fix---
    Ditch the seatpost shim and fit the appropriate sized Thomson seatpost.....works a dream on a VT and after this fix i havent heard a creak
    Not to mention the nice weight saving
    Cheers
    Quote Originally Posted by Andy
    Permanent fix---
    Cheers
    ok....thanx 4 the advice ...the Rainier doesn't use a seatpost shim but i'll do the greasing up bit anyway and see what happens. After that i suppose I'll try an increased sized diameter seat post, though i was warned that if i did this i might split the tubing where the seat pole is inserted
    cheers
    XC rider/racer
    Try another seat collar....
    cheers
    I`d be very wary about going to a larger diameter seatpost....it certainly may well end up splitting the tubing......another possibility would be to try an alternative seat collar and see how this goes.
    The Salsa Liplocks are around 16mm wide and provide a very good grip.
    Cheers
    Cheers
    thanx for tip...
    cheers
  1. squeaky seat
    By Jorgemonkey in forum Tooltime
    Last Post: 04-22-2004, 07:31 AM
  2. How much exposed seat post?
    By Larsey in forum Turner
    Last Post: 04-16-2004, 04:43 PM
  3. Blur seat post shim (30.9mm OD) Anyone make one?
    By CraigH in forum Santa Cruz
    Last Post: 04-15-2004, 09:11 AM
  4. NRS seat post quick release clamp
    By nrsair_dpm in forum Giant
    Last Post: 04-09-2004, 08:04 AM
  5. Yo Eddy seat post clamp size??????
    By SS Jerry in forum Vintage, Retro, Classic
    Last Post: 02-24-2004, 07:15 PM
