Results 1 to 3 of 3
    Feb 2012
    SPEC PRO-SET II MTB STEM for OD2?
    Looking for a (budget) short stem to replace the stock on a Large AX29. Google-fu found a few references to the Specialized PRO-SET II
    MTB STEM which as far as I can tell has 1.25" bore (to allow for the shims). Unfortunately, the specs don't list the bore diameter
    Obviously, I 'd want to use it sans shims and was curious if anyone had real world experience with this stem. I'm figuring $40 would be a steel to experiment with a shorter stem.
    2012 Diamondback Podium 3
    2013 Specialized Stumpjumper EVO 29 - MIA
    2013 Giant Anthem X Advanced 2
    Reputation: Whitedog's Avatar
    No, the Specialized comp-set stems won't work. I just bought a '14 Trance 27.5 1 and wanted taller stem and had LBS order the Giant 100mm 20 deg rise for OD2 ($100 ouch!). When I went to put it on, I realized I had a bunch of Spec stems, so I took out the shim and tried it...nope, the inner diameter of the Spec stem is LARGER than 1.25" and the stem just flopped around. Measuring now with a caliper, the Spec stem ID without the shim is 1.297"
    Feb 2012
    Thanks, Whitedog. Saved me time and money.
  1. Replies: 7
    Last Post: 03-11-2013, 08:06 AM
  2. Scott Scale vs Spec Carve vs Spec SJ Comp/Evo
    By Bowfish in forum 29er Bikes
    Last Post: 01-29-2013, 07:44 PM
  3. Replies: 9
    Last Post: 08-24-2012, 09:06 PM
  4. Blur LT - High spec Al or lower spec carbon?
    By eldiablo in forum Santa Cruz
    Last Post: 09-21-2011, 03:58 PM
  5. Questions re: Spec Hardrock fork and stem
    By bikedreamer in forum General Discussion
    Last Post: 09-11-2011, 09:29 PM
