Results 1 to 6 of 6
    Sep 2013
    Seatpost minimum insertion point
    Hi everyone. From where exactly do you measure the minimum insertion? From the top of the seat tube (where where the seat clamp is) or from the small "viewing" hole (some cm below)?
    May contain nuts
    Reputation: Haggis's Avatar
    Top of clamp. 80mm is min but I'd err on 100mm
    Sep 2013
    OK. Thank you. I thought that since there was this little hole I should be using it as my limit point instead of the top of the seat tube.
    By the way what is the use of this little hole?
    May contain nuts
    It's there to prevent any cracks forming from the slot. If there is room; it's better when manufacturers put the slot on the front side - surprising how much water off the back wheel gets down the seat tube
    Sep 2013
    Thank you!
    Workin for the weekend!
    Reputation: -Todd-'s Avatar
    I would use the 1" below the top tube lower weld for your kin insertion point. The post and the frame may have different specs, the frame is much more critical.
    Todd
  1. Minimum insertion for KS Dropzone?
    By fongster in forum General Discussion
    Last Post: 12-05-2012, 01:31 AM
  2. Safire: Minimum post insertion point
    By rzozaya1969 in forum Specialized
    Last Post: 03-20-2012, 08:08 AM
  3. Helius CC minimum post insertion
    By steve_b77 in forum Nicolai
    Last Post: 04-06-2011, 03:25 AM
  4. Minimum Seatpost Insertion for ML/FTM
    By MootsRider in forum Titus
    Last Post: 03-19-2011, 08:19 PM
  5. Covert V2 minimum seatpost insertion?
    By Neily03 in forum Transition Bikes
    Last Post: 01-24-2011, 12:47 PM
