Results 1 to 34 of 34
    tardcore
    Reputation: pjlama's Avatar
    RP23 on a Reign 0?
    I just got an 08' Reign 0 and am loving it. Every other FS bike I've had recently has had an RP23 so I'm used to a lot more platform out of the Propedal. I love the way the stock DHX feels but I'd like more from the propedal. Would I be crazy to swap on an RP23? I have one on another frame with a high volume air sleeve that's the right length so I could do it easily.
    I'm posting this on the suspension board too to see the various responses.
    2 minutes turkish
    Reputation: locustfist's Avatar
    if you have the shock already, try it and see if you dig it.
    tardcore
    That's what I'm thinking but is the RP a down grade to the DHX? My only concern is that if I like I have to buy another shock because I'd feel inclined to have the option of swapping on the DHX for downhill rides.
    Reputation: fixbikeguy's Avatar
    I feel that the RP23 is the better shock for that bike. We swapped one out for a guy at our shop and the suspension works way better. I'm not sure why it comes with the DHX in the first place. The RP23 is better suited to what the Reign is for. I don't consider it a downgrade if the performance is enhanced.
    tardcore
    Cool, thanks for the input. I have a high volume air sleeve on the one I'm thinking of pilfering so that should be a nice little upgrade over a stock one. Does anybody know if the 09' and 08' 23's are different or the same?
    M070R-M0U7H FR3NCHI3
    Reputation: Acadian's Avatar
    RP23 with high volume sleeve will blow through the travel too easily. in order to prevent the shock from easily bottoming out, you'll have to run more air - thus adversely affecting small bump compliance. run less and it feels great on small bumps, but start riding aggressively and it blow through the travel. I tried both an RP23 with regular and high volume sleeve on that bike - I've never felt an RP23 bottom out hard until I tried the high volume sleeve.
    the regular air sleeve feels pretty good - its a great shock for trail riding, but for more aggressive riding, I still prefer the feel of the DHX-a (mine is a 5.0 tho). I run full BO and just enough air in the boost valve so there is a tad of compression damping. In the main chamber I run just enough to I can get full travel on hard hits.
    the DHX-a 4.0 wasn't cutting it for me...I was always bottoming it hard.
    next...I would love to try on coil shock on that bike.
    Dec 2005
    I was running the RP23 with a low volume sleeve, but found it did not have good small bump compliance, was a quite firm on trail, but not quite enough for the decents.
    I swapped out to the RP2 with high volume and found it very nice, but with only the two positions it was lacking a little. With the PP off it was very plush but didn't find it bottomed out, however for climbing it was a little too soft. The PP on setting was good for most climbing on smoother trails, but a little too harsh for the enough for technical climbs.
    I will be getting my RP23 back with a high volume sleeve so hopefully it should work to fill in the gaps noticed on the RP2. I am hoping to be able to run the RP23 in setting #1 for technical climbing, #2 or #3 or fire road climbs, and #1 or open for bombing down.
    I might have an option on the coil arriving soon and will keep you posted on the outcome.
    Cheers
    Jeff
    kneecap
    Quote Originally Posted by pjlama
    I was under the impression that more air in the boost valve adds more to the propedal function, that's from the fox manual. I just built up a reign 0 frame as well, & am quite pleased with the DHX 4 so far. I prefir the just enough platform with the boost valve at min. safe PSI. However, I'm a feather weight dude compared to most on these forms I think.
    tardcore
    I don't think the second chamber really functions as a propedal adjustment. When I put more air in it seem to firm up the mid and bottom stroke.
    Acadian, are you a pretty aggressive rider? I'm not so I may have better luck, I just feel more comfortable with lots of travel. I've typically had good luck with the RP23 but don't want to give up too much for a firmer platform.
    The whole reason I'm asking about his is because on steep loose climbs the rear is squatting heavily making the front wander, the front wanders into a nice rock and I'm on my a$$. I can hardly walk this morning after my fall yesterday
    I never set up my bikes for climbing efficiency - it's all about the downhills. so the RP23 might be the ticket for you.
    tardcore
    I'm not concerned about pedal efficiency either I just want the bike to go where I point it on climbs. I guess a bike with 6" travel is on the bubble as much of a climber anyway buy hey I'm as unrealistic as anyone. I'm going to give it a shot since I have the RP and if I like it I'll pick-up another. The only problem is I was going to sell the bike with the RP on it this week.
    I have a Reign X1 (with DHX 3 coil) and it does not squat while climbing, even with the Van36 fork the front wheel tracks pretty well.
    Have you tried increasing the shock air pressure? (not the boost chamber)
    Dec 2005
    Quote Originally Posted by Acadian
    When setting up for bombing downhill, how much sag are you running. Are you running a 2 inch stroke or a 2.25?.
    With the HV RP2 I find that I can run 170-175lbs and still have just over 1/2 sag. I weight about 180-185 before riding gear on. The LV RP23 160-165psi and I was a little under 1/2 inch sag.
    Quote Originally Posted by rideitall
    I can't quite remember how much air I was running ...
    I'm about 155 lbs and run a 7.875" X 2.0 RP23. this weekend with the LV I was running about 155psi's and was soft bottoming. I think I was getting around 15mm or sag with that.
    the HV just didn't feel right....the bike wallowed in the mid stroke and I was bottoming HARD.
    the other issue I have with the RP23 is that the rebound is inconsistent. at some point during a descent I had to stop and slow down the rebound because it was feeling way too fast. Then I get home and the rebound was crazy slow..
    if I was forced to ride one setup, I would ride the RP23 with the LV - but now I re-mounted the DHX-a
    tardcore
    I set the sag to exactly 1/2" and played with the boost chamber a bit but like that lower as it feels more compliant. I really need to try cranking the Talas all the way down to 100mm but leaving the fork pretty wide open to see how that works. I'm tempted to do the swap but really want to get rid of that bike that has it.
    here is an option..
    DW 5 Spot RP23 mod
    Dec 2005
    Got my RP23 back, dampening slightly dropped from the 3bars compression and added a high volume can. The small sleeve was replaced with one off of a DHX A.
    Sag was set at approx 1/2 inch, with PP off it is plush, could be used for techincal climbs, but best for bombing down and soaking up the bumps. With PP on setting 1, it is good for technical climbs or singletrack. Setting #2 is good for climbs or singletrack as well obviously a little firmer. Setting #3 is best for fireroad climbs, with the large sleeve it still moves okay when pushed but is quite firm.
    So far I am liking this, only one ride on the shore on some fairly technical trails, single track, and some climbs.
    tardcore
    Interesting thread on the shim idea. I'm going to experiment this weekend with both shocks.
    slamma
    Reputation: SPRAG's Avatar
    Nov 2008
    Rp23?
    I just ordered a Reign 0 it should be here on Friday....
    anyway, i don't think i would want to change the DHX for an RP....I kind of defeats the purpose of buying that bike....on long downhills the smaller air chamber will start to heat up and effect the way it rides....im 511 215....so i may be more harsh on it, and as already noted it will blow through its mid stroke way to fast for me, i think the platform will be just fine DHX 4 the maestro does pretty good without any platform.
    Ride with timeless creed
    tardcore
    Well I put on the RP tonight, going for a big ride tomorrow. What a PIA removing the lower inner bushing was though. A ten minute job turned out to be over an hour with bushing madness. On a side note I had my Reign by the LBS for a rear derailuer (sp?) adjustment and one of the guys asked what it weighed to which I responded "I have no idea" they said well we gotta weigh it. Any way with the DHX still on it was barely over 27lbs. ! I know its not a weight weenie bike but I was impressed. It has a Joplin and Mallets on it too. Must be the Crossmax ST's but damn the thing never ceases to amaze me. Anyway, I'll report back tomorrow night on my findings with the RP
    Reputation: wormvine's Avatar
    Don't sneeze on it or the paint will rub off!
    Just got a 09 Reign 2 (parted out) for the wife. It came stock with a high volume rp2. High volume is good for her. I am a little concerned about long term durability though. I don't like the aluminum pivot pins. Or the lack of a bush in the lower shock eyelet. But we'll see.
    tardcore
    Yeah, I was surprised that there was no bushing in the lower shock eye too, what a beeoch to get that bushing out though. I'm sure occasionally replacing the pins will be needed but that's easy enough.
    Quote Originally Posted by wormvine
    I've been riding mine pretty hard and so far so good.
    I actually like the fact that the bottom shock mount only has a through pin with no DU bushing, makes it almost impossible to develop play.
    Well that's good to hear. But only time will tell on the aluminum pivot pins. I'll be keeping my eye on it. Maybe the paint quality on the R0 frame is better than the R2. Also the color on your frame is a lot lighter than the red on the R2. But so far my wife is liking the bike.
    tardcore
    Just got back, there's something about the Maestro that minimizes the PP. Basically the PP on the RP23 had about as much effect as the PP on the DHX. Even with lots of air and the PP on 3 it was so easy for the Maestro to blow through the first bit of travel. I took a shock pump and did lots of tweaking just to make sure it was a fair evaluation. I'm putting the DHX back on. The DHX feels more plush and linear. Lesson learned. As far as getting it to track really well on steep loose climbs I just would flick the Talas down to 100mm and leave it nearly full soft and it climbed beautifully. I just needed more time on the bike to learn how to ride it and this morning's ride was a perfect situation. Rode from 6700ft to 7700ft on very technical single track while it somehow managed to snow 3" during the ride, it was about twelve miles. I just gotta say I'm in love with this bike, it's slack geometry and long travel is very confidence inspiring.
    tardcore
    Just an update only for the sake of information. I called Push just to get some feedback after noticing that on Sprag's "new reign tread" they said the DHX air was junk. Anyway, they explained to me that the compression valving has to travel up in an unconventional manner making it easy to service but poor functioning. So they recommended staying with the RP23 and going to a low volume air sleeve which I have. I'll try this tomorrow but just to exhaust all options I'm having the guys at Push build me a DHX 5.0 coil for my weight, it should be ready in a few weeks. I'm a sucker, but I like this bike so much I want to pimp it out. So look for an update in a few weeks with my thoughts on the coil but I will post up about the RP with the LVAS later this week.
    slamma
    Nov 2008
    Hey pjlama,
    I finally got to take her out on a real ride Sat, and i noticed a few things about the DHX 4that i did not like, I think the biggest thing is lack of the low speed compression dampening would make a huge difference on climbs. Here is why, I'm use to a 3 inch bike ( big difference in trail manors) and i noticed that trying to climb over a log pile or some type of obstacle or if there is a dip in the trail and then an obstacle, even though the BB is higher than my NRS, the Reign sags a lot more without dampening, and i find myself bashing my BB a lot....maybe its rider error, do you have the same issue....im thinking about trying a DHX coil or Cane Creek Double Barrel, how do you think these two compare,. ..they suggested the DHX (obviously) at PUSH for the Reign
    i also noticed it doest feel as plush as it should over high speed square edged bumps, I am running 250 psi to keep the bike at about 27-30% sag, the max is 300, im currently 200lbs, it seems it should be around 220psi, again, not sure if its the shock or what? what are you running in yours?
    I also find as far as the PP goes, i don't notice a huge difference in how efficient the bike is just how it sits in its travel, with the PP on it sits higher in the travel and feels firm with slightly less bob, but not as plush and not worth using unless the terrain is mild,
    this bike can definitely not sprint, its kind of funny, im use to standing and hammering up hills but this bike just say "FU sit down and spin" I reply "Fine"...... yes i talk to my bike
    i also notice that it gets more traction without PP on.
    Dec 2005
    Quote Originally Posted by SPRAG
    Hey pjlama,
    SPRAG
    Interesting comments on the bike and hte DHX. I am finding that I can climb better on my 08 Reign with 6 inches travel than I could on a similarly spec'd 05 Trance with 4.2 inches travel. I have a RP23 on the bike with an air can off of a DHX Air, I am around 185lbs and run about 160psi to get the 1/2 inch sag on the 2 inch stroke shock (I eyeball it, at 1/2" it's 25% sag, so I am somewhere in that range.)
    The RP23 was retuned and has less compression dampening that the stock high (3 bars) and again slightly less rebound dampening than the mid (2 bars). The nitrogen charge was reset to the normal range.
    I seldom use setting 3 from compression unless I am on a road, even then #2 is fine. As noted by SPRAG it is quite a bit firmer and sits higher in the travel. I can overwhelm the dampening with a hard push.
    I typically use setting 1 for technical climbs or single track. I the climb is extremely loose and bumpy I will turn propedal off for the best traction. I find myself making short steep technical climbs on my Reign that I would often loose traction on my Trance. If you can sit and spin the Reign will have almost unlimited traction, I actually broke a chain pushing really hard up a steep climb. That said if you can keep a good front back balance standing climbing is almost as good.
    Not certain as to why the DHX seems to funciton so poorly, but I have run DHX5 Air shocks on other multi-link bikes (Nomad, IH 6-Point, IH 7-Point) and found they don't work for me. I have been somewhat surprised at how well the RP23 works on this bike setup as it is.
    One quick test for you on the RP2, RP3, or RP23 to check how well the nitrogen charge is doing, is to seem how the propedal lever moves from one setting to another. If it moves with little resistance or no distinct click from one setting to another it usually indicates you charge is too low. There should be some resistance in moving from one setting to another almost like click from a detent.
    Good luck on your fine tuning and keep us posted if you run a DHX Coil or CCDB. My 2c is that the DHX Coil will be better but not that much, the CCDB could be quite interested as it is supposed to be so tuneable but is costly. I would still consider a RP23 with a larger can on it.
    Yeah, I've seen posts by Nomad riders complaining about their DHX airs also.
    At your weight, you might like the feel of a DHX coil better. I'm only 150lb but I still like the firm midstroke of the coil.
    slamma
    Nov 2008
    Dont get me wrong the bike climbs like a tractor, all the traction i could ask for in the rear, not including the worthless an slow, 2.35 Kenda on the rear, the ramped nobs slip on all the wet stuff pretty easy, got a Mountain king comming.
    The biggest problem i find is the low speed compression dampening, it tends to squat pretty easy do to lack of CD, i smack my pedals on more things than i ever did with my NRS, Is this somthing i have to get use to with more travel or am i correct in thinking is the low speed CD?
    i would so far rate the shock 7 out of 10 for feel and performance,,,,,,it may still need some break in time......dont know that much about it yes, not verry many setting to play with just air pressure and rebound. not sure how boost effects is, i just lift 30psi in it.
    slamma
    Nov 2008
    Some more thoughts
    I have realized that the pro pedal actually makes this bike pedal worse on the trail. when it is off, the suspension always feels active, always feels like my strokes are pushing fwd, not like a hard tail, but I im getting more traction. With it on, it feels like im pedaling in mud and I feel myself getting tired quicker, like the shock and suspension are having and argument and this is the biggest problem i have with the shock, because when i have the PP on, i don't get as much squat and my pedals don't hit all the time. maybe its rider error, i don't know. but i would like to get some type of Low speed compression dampening without. *i dont hit my pedals going down its only gonig up, or if im going slow.
    I'm not sure what to think about the shock performance, i don't have anything to compare it to really, just what i have read and how i would expect it to perform, but im pretty happy with it otherwise, it could probably be a bit more plush on square edged hits, and again i read that it is a problem with the shock.
    How am i suppose to fix this problem, as in my previous post i assumed that it was Low speed compression Dampening. but the DHX coil has PP as well, and i don't see how its gonna help me in the pedaling department, does it work different, maybe i should fork over the $ for a CCDB.
    any thoughts on this, i need some opinions from the "been there don't that crowd".
    slamma
    Nov 2008
    LVAS ???
    many people like the Marzocchi Rocco shock (air or coil) on VP-type bikes. Apparently it has tunable compression, but no platform.
    slamma
    Nov 2008
    Do they make the Coil that will fit a Reign (7.875 x 200)
