Results 1 to 2 of 2
    Professional Bad Ass
    Feb 2007
    Reign rear end more progressive
    I have a 2011 Reign with a Float RP2 with Boost Valve and a large air can. The pressure I normally run is perfect for most trail obstacles, but when I hit the occasional big drop it bottoms pretty badly.
    I'm wondering if anyone has had luck with swapping out to a smaller air can or just added some oil to the chamber to reduce the air volume and make the spring rate a little more progressive.
    Sep 2012
    Quote Originally Posted by dthomp325 View Post
    I had the same issue running a float RP23 XV with the 2nd aircan on my Reign X , found a thread on here about fitting a thin shim into the extern air can, I used a CD case cut to fit into the external can and it no longer blows through all its travel on minor trail whoops , its also allowed me to drop about 20Psi of the shock pressure and still get 25% sag .
    the shim is basically cut from thin flexible plastic of about 1 mm or so thick around 135mmx23mm square (ideally to fit into the air can without overlap)
    ps this is the thread DW 5 Spot RP23 mod
  1. New rear shock for Giant Reign?
    By golfduke in forum Giant
    Last Post: 01-13-2015, 03:41 PM
  2. Different Rear shock For My Reign X
    By e-luder in forum Giant
    Last Post: 02-20-2012, 06:03 PM
  3. 08 Reign Rear Shock
    By geek81 in forum Giant
    Last Post: 12-24-2011, 10:40 AM
  4. Reign X rear shock on a Reign..
    By killrdanasurfer in forum Giant
    Last Post: 09-05-2011, 12:07 PM
  5. Rear Mech Reign X1
    By rondet in forum Giant
    Last Post: 02-01-2011, 08:10 PM
