Page 48 of 51 FirstFirst ... 38 44 45 46 47 48 49 50 51 LastLast
Results 1,176 to 1,200 of 1257
  1. #1176
    24v
    24v is offline
    Scratch That Itch
    Midnight, that is a nice ride. It appears as if you are really trying to prevent scratches and chips in your frame. You might want to protect the areas I highlighted in green. The chain will wear a bunch on those parts of the rear triangle.
  2. #1177
    Reputation: MidNight_Rider's Avatar
    Mar 2011
    Nice dude thanks. When I get to Japan that'll be first on my list of thing to work out on the bike.
  3. #1178
    DenverDH'er
    Reputation: rep_1969's Avatar
    OLD SCHOOL.
    This is my wife's park bike and I "pimped" it out last winter. (Custom power coat and decals, Gravity stem and bars, Code brakes, 8 inch front rotor, 6 inch rear) I never posted any pixs till today on another thread so I thought I'd post here too.
    I put an old 7" Boxxer with the black-box internals on front. She doesn't ride that hard so I'm sure it's fine for her, I'm not worried about her snapping the head tube or anything like that. Putting that front fork on really made it a much more capable park bike for her. Also kept a front derailer on it, running two rings in front so she can climb if need be. Her trail bike is a Trance so keeping her in the "Giant family" of bikes just kinda made sense.
    Attached Thumbnails Attached Thumbnails Reign photos (merged thread)-reign2.jpg
  4. #1179
    May contain nuts
    Reputation: Haggis's Avatar
    Looks great in burgundy. The original Reign are ox-strong, so it should cope fine... Maybe put a BB Stinger on it as the final touch
  5. #1180
    DenverDH'er
    Quote Originally Posted by Haggis
    The color is actually transparent rasbery, the color really doesn't come across in the photo though. I would if I knew what that was?? It does have a raceface bash-ring on it though.
  6. #1181
    a pic to wrap up the blast from the past mrs. motochick has initiated.
    Attached Thumbnails Attached Thumbnails Reign photos (merged thread)-reign_mtbrsize.jpg
  7. #1182
    Reputation: ratty2k's Avatar
    Oct 2007
    Few small updates in this pic (mines posted somewhere here!) Not shown in the pic is the new Sunline V1 745mm bar thats so much better than the 700mm it replaced. Much better feel as I dont have my hands hanging over the ends of the grips anymore.
    70mm Thomson stem, Fox VanR coil rear shock, Lyrik upfront from new... XT wheels and running tubeless as I got pissed off with pinch flatting all the time. XT centre lock discs and the obligatory dropper post.
    DSCF0184 by rathbonepeter, on Flickr
  8. #1183
    New fork and wheelset update! Fitted a tapered Talas onto the straight headtube with the EC44 headset. New headtube angles are awesome!
  9. #1184
  10. #1185
    Jan 2011
    Reign photos (merged thread)-rimg0015.jpg[QUOTE=motochick]
    Quote Originally Posted by sandhman
    Same size, color and year, from same dealer.
    I would like to know the final weight when you get the rest of the goodies on her! She is pretty! (you need wider bars tho!)
    Brenda
    Hi, sorry for the extremely late reply!
    Been caught up in a move, amongst other things.
    Mine is heavier than Yours
    I'm a bit surprised she is that heavy, but she still is pure joy to ride.
    Switched out the narrow scandium bar for a longer Answer Carbon, handles so different now(for the better)
    Believe the tires is a culprit, weight-wise. Wider tires is hardly possible with the frame.
    Rolling resistance is decent and I am really pleased with the grip in the muddy, early spring conditions.
    Added a pic from after I gave her a dip in the sea
    On my way to construct a BB mount chain device, from straitline parts.
    Adjustable seatpost will soon replace the scandium post, pushing the weight over 26 lbs :/
    Regards,
    Isak
  11. #1186
    fraid of heights
    Reputation: stiingya's Avatar
    25 pounds, what a tank...
    Quote Originally Posted by the_owl
    Everytime you ride in mud, god kills a kitten.
  12. #1187
    light that fuse...
    Reputation: msamusick's Avatar
    Here's mine.
  13. #1188
    Reputation: antonio's Avatar
    Jan 2005
    msamusick - great pic!
  14. #1189
    light that fuse...
    Addicted
    I built this bike with the intention of making it the go to bike if I had no idea what type of bike would suit a trail I'd never ridden best.
    The goals: efficient, sturdy/durable/reliable, lightweight.
    The weight goal was really a challenge as well as a priority. I work in a shop and I want all of my customers to walk through the door and be able to get the exact parts I run. This takes all those uber-light european parts off the table. Everything I have on my bike is something that can be purchased through one of my major distributors.
    I was also really trying to keep to a strict budget throughout the build so of course you won't see everything top end on this build, but most parts were chosen for value, weight and quality.
    I ended up at 26.8lbs right now without anything titanium or carbon(except the bar). I have a headset, pedals, derailleur, and bashguard on their way that will drop another 180ish grams.
    Next year when I'm back up to health and don't have so much on my plate I plan to swap the brakes for R1's. The shifting will be replaced by a full XX group. I think I can get close to the 26lbs range, while keeping a full 150mm travel, 2.4 tires, and a height adjust post. I might try to switch to a carbon crank as well. I just blew up my FSA K-Force so for now the E13 will do at 755g+the 99g BB.
    Anyway, here she is:
    Going up! Drop the fork, raise the post. Yes, the post looks tall. I'm 5'11 with a 36" inseam. My torso is super short so I ride mediums with tall posts. Proper leg extension requires a full foot a exposed seatpost.
    Going down! Drop the seat, raise the fork. I'm not 100% satisfied with the cable routing. I know I can clean it up a touch. I'm doing a shake down run tomorrow so I'll make changes with what I find.
    Specs:
    Frame: Giant Reign 2, medium
    Rear shock: Fox Float RP2(will be replaced by a Monarch)
    Fork: Maverick DUC32. SusEx seal heads, IFP, tuned for me
    Stem: Maverick Adjustable
    Bar: Answer AM carbon 720mm
    Grips: ODI Ruffian lock on
    Shifters: Sram XO gripshift
    Front derailleur: Sram XX
    Rear derailleur: Sram XO(5 years old, no carbon cage)
    Chain: KMC X9SL
    Cassette: Shimano XT 11-34
    Cranks: E13 XC 22/32/Shimano bash
    Pedals: Tioga platform
    Saddle: WTB Devo Carbon Ti
    Post: RockShox Reverb(stright out of the box, uncut/no bleed)
    Clamp: Woodman Deathgrip Ti
    Brakes: Shimano XT(not the servowave version)
    Rotors: Avid Cleansweep X(185/165)
    Wheels:
    Front: King ISO 24mm, Revolution spokes, Blunt rims
    Rear: King ISO 135, Revolution spokes, Blunt rims
    Tubes: Specialized regular ol' presta 2.2
    Tires: Schwalbe RocketRon 2.4's
    Computer: Trek Incite 11i
    Chainstay protection: Hacked old tube
    Enjoy!
    -Kevin
  16. #1191
    Aficionated Member
    Reputation: ZePequeno's Avatar
    Dec 2005
    Let me show you my brand new bike, the Giant Reign 2.
    Size M (17"9), i'm 1,78 mtrs tall.
    Upgraded from the original one:
    - Shimano XT (165mm) crancks (24-36T) and Gamut cover
    - Avid Elixir Cr brakes
    - Renthal FatBar cutted at 750mm
    - Thomson 4x stem
    - RockShox Reverb seatpost
    Weight: 14,5 kg
    Attached Thumbnails Attached Thumbnails Reign photos (merged thread)-my-giant-reign.jpg
    Enjoy your rides
  17. #1192
    This weight without pedal, after I added a pair of wellgo ti axle pedal and a maverick speedball seat post, it`s 27.65lb
  18. #1193
    Quote Originally Posted by bmxconvert View Post
    Specs:
    You are probably aware, but dual crown forks voids the Reign frame warranty. They must have their reasons.
  19. #1194
    fraid of heights
    Quote Originally Posted by rep_1969 View Post
    You know that dual crown fork is gonna void your warranty...
  20. #1195
    Dec 2010
    2011 Reign frame set build
    MY Bike! 2011 Reign Frameset, Fox rp23, 2012 Fox 36 Talas 160, 2.35 Kenda Nevegals tubless, 2011 crossmax sx, Sram X9 2x10 Group, XO brakes 180f 160r, Fizik seat (dont remember which.. the dog decided to naw on it at the LBS so i had to buy it... expensive taste though!!), Easton post, Easton Havoc Bars (nice and wide!!), Shimano Spd's..
    2011 Reign, Fox rp23, 2012 Fox 36 Talas 160, Crossmax Sx, Sram X9 2x10 Group, XO brakes, Easton Havoc Bars (nice and wide!!)
  21. #1196
    Well you don't really see the bike, but I will post a picture of it tomorrow. Some little upgrades were done in the last months.
  22. #1197
    Reputation: HeadCase NZ's Avatar
    Here is my 2011 R2. Upgrades from stock:
    White Flow rims with red Pro 2 hubs & red spoke nipples,
    Maxis Advantage tires running tubeless, 2.4 front & 2.25 rear,
    Rock Shox Reverb seat post,
    XT brakes with white Goodridge lines,
    Braking 185mm front rotor,
    XT cranks with 24-36 & Blackspire Lite God bash guard,
    XT cluster (the stock one was like an anchor!!) & XT chain,
    Kore Chain Reactor chain tensioner,
    white shimano M520 pedals,
    Red ODI Ruffian MX grips,
    Red Hope seat collar.
    Attached Thumbnails Attached Thumbnails Reign photos (merged thread)-p2260018.jpg
    Reign photos (merged thread)-183292_10150156526007018_565632017_8152191_1847703_n.jpg
    Check out the Mountain Biking Otago Website:
    www.mountainbikingotago.co.nz
  23. #1198
    fraid of heights
    IMO, one of the few times that us big guys get the better looking bike/frame then the smaller guys.
    (seems like the small/medium frames always look awesome in the magazines/reviews, and then when I go buy my L/XL it looks all lanky... )
  24. #1199
    I'm right with ya there, totally agree
    The proportions just look better with the large frame in this case, less cluttered...
  25. #1200
    Ricky
    Nov 2008
    You need an anthem frame for those components
    Really Crest? and KNCN goodies on a 6" travel frame?? What is next?? a SID??
  1. finally, some action shots
    By jacksonpt in forum Yeti
    Last Post: 05-26-2005, 06:43 PM
  2. The Greatest Bike in the World Action Shots!
    By FatTireMike in forum Downhill - Freeride
    Last Post: 01-09-2005, 07:55 PM
  3. Glendale Action Shots
    By Korrupt in forum Downhill - Freeride
    Last Post: 09-27-2004, 11:55 AM
  4. Show off ur HTs (action shots if desired)
    By Chikity China in forum Downhill - Freeride
    Last Post: 08-25-2004, 08:18 PM
  5. Action Alert: Help Reopen Reynolds Park!
    By IRIDEANDIVOTE in forum Colorado - Front Range
    Last Post: 05-01-2004, 09:28 AM
