Results 1 to 11 of 11
    reign O 2011 chain guide
    a potential fix to the reign chain dropping issue
    Pinkbike Product Picks - Pinkbike.com
    see
    Bionicon C-Guide V.02 Chainguide
    what do you think will it work?
    so hows it working out?
    2010 Glory custom FR
    Reputation: frango's Avatar
    amun, chłopie where did you buy this guide?
    pozdro
    frango
    Quote Originally Posted by frango View Post
    I buy that on ebay :-)
    cost a lot
    I will write more after couples rides in the mountains when winter will be over in Poland
    for now works very good, no problem at all even in snow, no sound from it, you mount and forgot
    BLAH BLAH
    Here is a link to buy them in the US. They are back ordered but you can get on a preorder list.
    Bionicon USA C-Guide Chainguide
    I have also seen this modified to fit.
    Whats this line for?
    I will wait till Megasport has it on stock and try to get some "industry" discount
    pozdro
    frango
    $50 for a small piece of aluminun and some plastic....what a joke
    Mine broke this past weekend. Think I may may have hit the guide with a rock.. can't say for sure.
    I'll take photos later, but basically the plastic piece that the zip ties go through snapped. The zip ties were untouched and still on the chainstay, but the guide was dangling.
    Te mortuo heres tibi sim?
    Quote Originally Posted by e-luder View Post
    Press-fit BB, no ISCG tabs? Here you go! [o]
    Yep. I picked on up. Works quite well. Easily could mount a stinger or bash-ring using single ring guide (what I did - Straitline Silent Guide) I'm just using a single upper XCX guide now though, cut down to fit the bash ring. I find I really don't need more than that on my Trance-X.
    With the greater Reign travel, or running two rings, something like a Stinger guide on the bottom would work well. The rest would depend on if you wanted to have a bash guard or not.
    I'd not run any of the built in bash guard guides though - to make this thing fit your frame, there isn't a lot of material to spread the load if you nail something hard - the guide will more than likely rotate. At the least you'd have to stop and fix it, at the worst it would end up screwing up you lower link if it rotated up enough to hit.
    Quote Originally Posted by JHANguyen View Post
    <img src= "http://farm8.staticflickr.com/7059/6945442339_58c7f2c1da_z.jpg">
