Results 1 to 3 of 3
    Reputation: jaybirdp's Avatar
    Dec 2005
    Reign Cable Routing
    How the hell do I keep my brake cable from pinching and breaking on my frame from suspension movement. The cables have also worn deep grooves in the frames main pivot. I've had to spend close to 150 bucks just replacing hydrolic cables.
    Thanks for all the input..........hopefully a few of you have had this problem and found a way to fix it.
    spinner
    Reputation: Pinky's Avatar
    Mine bow out around the main pivot. Only the front der. cable rubs on the rocker and with a minor adjustment of the housing , I stopped this from being a major problem.
    So your brake line runs between the rocker and the frame ? Got some pics ?
    Dec 2005
    Wow it was that simple............I'm an Idiot. I guess I didn't have enough slack. I guess I need to start letting the bike shop do the work. As far as a pic.........nope. Don't have a digital yet.......but hopefully the wife got the hint and I'll get it for Christmas.
