Results 1 to 9 of 9
    2010 Glory custom FR
    Reputation: frango's Avatar
    Reign 2 Nixon fork - what max pressure?
    Hi, what is the max pressure you can put in the main chamber of Nixon fork on R2?
    thanx in advance, guys
    pozdro
    frango
    Scuffed
    Reputation: Amber's Avatar
    30psi minimum and 150psi maximum
    Quote Originally Posted by Amber
    Oooppp's,Ive been running 180#.I weigh 185 and it seemed good to me,never got the manual with it so I was guessing at the pressure.Had no problems as of now.
    In exile
    Reputation: loco-gringo's Avatar
    I would think the pressures that Amber posted are for SPV. those numbers sound right for what I have seen for that.
    Quote Originally Posted by loco-gringo
    There isnt SPV on the 06 R2's Nixon,just the main air chamber for positive spring.
    In exile
    Quote Originally Posted by tkrutis
    I know - I was just saying those pressures sound like SPV pressures to me. Just making sure it's the right thing. Not that it matters, since I ride a Z1.
    thank you guys, everything is clear, now
    I also got answer from Manitou
    pozdro
    frango
    In exile
    Quote Originally Posted by frango
    So was the min 30 lbs max 150 lbs right???
    this was Nixon SuperAir 06, I think some kind of OEM
    it has main chamber, another chamber for Platform or samething, rebound and compression adjustment. They told me to put max 200psi into main chamber.
    pozdro
    frango
