These might come in handy for some.....
Disc Brake Rotor Size Application for Manitou Forks
All Luxe and South forks: 165mm rotors only
All Axel and SIX forks: 165mm rotors only
All Skareb forks: 165mm rotors only
All Black forks: 165mm and 205mm rotors
2004 Black and Minute: 165mm and 205mm rotors
All Sherman forks: 165mm and 205mm rotors
All Dorado forks: 165mm and 205mm rotors
Not forgetting 185mm rotors then...
RockShox Recommended Disc Brake Rotor Sizes
Date: 2004-01-29 14:11:32
Source: Luc 'Acadian' Albert
SRAM has received a number of inquiries lately regarding RockShox fork and disc brake rotor sizes. Following is a list of all RockShox fork platforms and the maximum recommended disc brake rotor size.
Fork Platform Maximum Recommended Rotor Size
GPS 165mm
Judy 165mm
Pilot 165mm
SID 165mm
Duke 210mm
Psylo 210mm
Boxxer 210mm
SRAM tests the structural integrity of all RockShox forks to that of the 210mm disc brake rotor size. However, other factors, including fork stiffness, bushing design, and intended use are considered when determining maximum rotor size.
