Results 1 to 3 of 3
    Aug 2013
    Rebuilding 2009 Boulder SE And Need Advice
    So I bought this Boulder SE off this old man for $170 locally. He bought it new and put some miles on it and didn't store it well. By the time I bought it there was a serious need for an overhaul or replacement of just about every bearing and cable, replaced a bad RD and replaced the back wheel instead of trying to mess with it; but it's true, it works, and it's there as backup though I need to get it overhauled.
    Anyways, this XCMv2 fork was always worth its weight in scrap and am looking for a new fork. I'm wondering what the max suspension fork travel the 2009 Boulder SE can handle before it becomes destructive to the headtube? I know that the longer the travel the more it will shift the geometry.
    I'm not going to ride the longer travel fork very hard, or often, while on the Boulder SE as the fork will be moving to a 20" **** hardtail with a 67degree HT-Angle that can take 120mm to 150mm of travel, and winter is coming so not much riding will be had. After I move the fork to he new frame in early spring, I'll get a 120mm travel fork for the Boulder,
    All help is greatly appreciated, thanks for reading!
    Goodbye '95 ZJ. Just so you know, transfering box of left behind womens panties to next truck. Thank you ZJ!
    Your Best Friend
    Reputation: Silentfoe's Avatar
    I would NOT put a 120mm fork on that bike. Definitely a 100mm though.
    I'm a mountain bike guide in southwest Utah
    Aug 2013
    Quote Originally Posted by Silentfoe View Post
    A 120mm would chew that up, yeah? Alright, I'll just get this bike it's own 100mm fork now.
    Edit: Found the Rockshox Recon Gold RL new for $370, has adjustable rebound like I want... Think this is good for this bike?
  1. Advice Needed Rebuilding Bike
    By punchy187 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-11-2013, 07:33 AM
  2. Advice Needed - Rebuilding A Rear Shock
    By blown240 in forum Shocks and Suspension
    Last Post: 01-30-2013, 07:42 PM
  3. Advice for rebuilding Super V
    By OleMan Glade in forum Cannondale
    Last Post: 03-17-2012, 11:05 AM
  4. Stolen in Boulder: 2009 Green/Grey Giant Trance X1
    By toweringhouse in forum Colorado - Front Range
    Last Post: 05-16-2011, 04:27 PM
  5. 2010 Giant Boulder SE or 2009 Felt Q520?
    By majorsotano in forum Felt
    Last Post: 01-24-2011, 11:10 PM
