Results 1 to 6 of 6
    New question here. Which rear shock, Fox float X ctd or float ctd. Giant Reign 1 2013
    I am replacing my rear shock on my giant reign 1
    I am stuck between these two, both Kashima coated
    Fox Float X CTD Remote Shock 2014
    Fox Float CTD ADJ Boost Valve Shock 2014
    The current float ctd has never been right for me, I am 90kg with my gear. Now it is damaged I want to get the right tune
    It is currently
    Velocity tune M
    Rebound tune M
    Boost valve 175psi
    So, two questions here
    Which shock have people tried or recommend out of the two?
    And what tune do people recommend?
    Dec 2005
    Look outside the box and go with something other than Fox. RS Monarch Plus RC3 or X-Fusion Vector Air HLR or even a CC Db Air. All would work really nice if you are looking to get a better performing shock.
    Thanks for the info
    i am a bit of a Fox fan,
    ill check out the RS Monarch now
    Dec 2005
    Me too as a Fox fan. Ran RP2, RP3, RP23, RP23 tuned ... The Monarch on the Reign feels better (more controlled) than the tuned RP23 did. I also have a Vector Air that I should try out more but the Monarch just works, and it will likely take a ride or two to get the Vector tuned to my liking.
    The DB Air or coil for that matter would also likely feel very nice from the comments I have read from others.
    I still run a couple of Fox forks that overall I am happy with but sometimes wish my 36 160 felt a little more plush.
    I have just got the 2014 fox 34s and the float X, will keep you posted
    Seem nice out of the box
    first ride soon
    The 2014 float 34s and float x have arrived
    first ride was awesome, so much better
  1. Replies: 0
    Last Post: 04-23-2013, 01:22 PM
  2. 2013 Fox Float CTD shock
    By the mayor in forum Shocks and Suspension
    Last Post: 10-25-2012, 03:10 PM
  3. 2011 Giant Reign with 180 fox float (pics)
    By Largextracheese in forum Giant
    Last Post: 07-10-2012, 04:09 AM
  4. Fox 2013 CDT float shock on 05/08 Flux
    By CragRat in forum Turner
    Last Post: 06-25-2012, 11:18 PM
  5. SPAM: Giant Reign, Fox Float, Mavic 823 Wheelset
    By ncfisherman in forum All Mountain
    Last Post: 03-13-2012, 07:24 PM
