I have a 2001 NRS Air that have riden hard and long for the past 3.5 years. It is flawless in my opinion, but recent I think my SID XC Rear Shock is kaput.
I will not hold air in the positive chamber after you put air in the negative chamber. I set it up to about 190 in the POS and 50 in the NEG, but after I put the air in the NEG the POS pressure will immediately fall all the way to 100 or so. It I put the NEG air in first then the POS it holds a bit better but still drops pretty fast down to 100 – a few rides.
Has anyone else had this problem? I have never really had any service done on the rear shock. Is it worth it to get it service (will new seals or something fix it) or should I just junk it for a new shock? I'd like to repair it if possible because I see the frame only having one season left in it until it is time for a new NRS.
