Results 1 to 2 of 2
    Sep 2004
    Putting new shock on 2012 Giant TranceX4
    I picked up the above listed bike the other day and then found a 2012 Fox Fit RLC with 120 and 150 mm settings.
    I put it on and still have a little movement in the shock when I hold the front brake and rock the bike forward and back. I tightened it up and got the majority of it to go away but it's a bit stiff to turn so obviously too tight.
    It is a 1.5 to 1 1/8th taper. Is that all that's needed or do I need to put some Giant specific piece on the shock steer tube to get this to go away?
    Before
    After
    Reputation: iamtylerdurden's Avatar
    Did you also swap the headset to a standard or still have the ODII? That may cause some issues.
  1. Replies: 0
    Last Post: 06-09-2014, 11:52 AM
  2. giant trancex4 2012 fork upgrade
    By nickfree in forum Shocks and Suspension
    Last Post: 07-05-2013, 05:20 AM
  3. Replies: 35
    Last Post: 11-16-2011, 07:41 PM
  4. Putting Air in Fox Float RL Shock?
    By maxxdout in forum Shocks and Suspension
    Last Post: 07-28-2011, 08:01 PM
  5. What would you do? (Giant TranceX4)
    By Ell Tell in forum Bike and Frame discussion
    Last Post: 06-13-2011, 03:57 PM
