    Feb 2007
    Press-fit BB questions
    Hey guys ... these question may be better on a different forum, but since I am considering buying a Giant frame I thought I'd ask here. If you have links to other forums with more info on the subject feel free to post them.
    (1) What has been your experience with pressed-fit BB's compared to the threaded X-Type BB? (For example: is it a better design, are there any reliability issues, etc?)
    (2) What make/model is the current press-fit BB being used on the Trance X?
    (3) Any indication if Giant will be sticking with this design, or will be reverting to the threaded BB shell for 2013?
    Thanks,
    M.
    KC Weekend Warrior
    Reputation: the.rebot's Avatar
    Jun 2010
    I have had my Trance for about a month, got about a 100 miles on it and the thing is creaking like an old rocking chair - taking it to my LBS (Epic Bike & Sport in KC - shout out) to have them de-creakify it.
    '12 Giant Trance X1, Mavic Crossride Wheels, StansTubeless, SPD Pedals
    They seem to last around the same amountof time as a normal bb and are lighter, plus you can gain some stiffness in the frame due to wider bb shell. On the downside, you can't remove them to drain water from a frame without risking damage, unless there are iscg tabs on the frame you can't fit any 2 by guide and you need a press to install them.
    KC Weekend Warrior
    Jun 2010
    Turns out my creaking was loose linkage NOT the BB...
