Results 1 to 49 of 49
    Your Best Friend
    Reputation: Silentfoe's Avatar
    Post your carbon Anthem X29ers
    Please include pictures, weights, any mods and what you are plannning to use it for.
    2013 Anthem Advanced X29er 0:
    XL
    23lbs, 6oz
    Tubeless
    Xpedo Ti/Ti pedals
    Ergon GS1 Leichtbau grips
    Ergon SM3-L Pro Carbon saddle
    Garmin mount
    Contour HD mount
    Giant carbon bottle cages x2
    Cut the handle bar to 690mm
    Cut the steerer to flush with HT/stem and 1x.5mm spacer
    Bell
    (I should add that my bike came with the 2012 Rock Shox Sid RCT3 dual air. I am thrilled with this because, if you know how to use it, dual air rocks)
    I got this to use as an all day bike. I used to race a lot but not really anymore. I still like to go out and do epic rides of at least 5-10 hours. I've had several different 29ers from long travel to carbon HT. This bike fits right in the middle and is perfect so far.
    Attached Thumbnails Attached Thumbnails Post your carbon Anthem X29ers-her-first-20-feet.jpg
    I'm a mountain bike guide in southwest Utah
    davidcarson48
    Guest
    I like the idea of this thread...
    I have about 100 miles on it and love it so far. I had a warranty issue with the XT brakes (sticky piston), but that was quickly resolved with a replacement caliper. It definitely rides firmer than my 2010 HiFi Pro with Fox suspension bits and is about 2+ pounds lighter. I'm pleasantly surprised by the P-XCR 1 wheelset so far. Other than the loud graphics (which I removed with some laquer thinner), they have very little flex, are reasonably light, and set up tubeless easily. I'm thinking about going with a NN in the rear as the RR isn't great in the wet rocks and mud here in the winter.
    This is my only MTB, so it is going to do everything from XC racing to a few endurance races to everyday trail riding.
    I had been considering a high-end wheelset for it, but I may just beat on the stock wheelset for now and grab up a carbon bar and seatpsot.
    2013 Giant Anthem X Advanced 29er 1
    Large frame
    26.2 pounds as pictured; 25.4 pounds without pedals
    Nobby Nic 2.25 TLR/EVO/SS front tire (running 21-22 psi)
    Racing Ralph 2.25 TLR/EVO/SS rear tire (running 24-25 psi)
    Tires set up tubeless with included rim strip, valve, and Stan's sealant
    Inner chainring changed from 26T to 24T
    Shimano XT Shadow Plus rear derailleur
    SRAM XX 11-34 cassette
    36T DT Swiss star ratchet upgrade in the rear hub
    WTB Pure V Pro saddle
    ODI Rogue lock on grips
    Shimano XT Race pedals
    Barfly Garmin Mount
    Cantitoe Road Shelter protection tape on downtube and BB
    Edit; I can't post pics yet. Sorry.
    Here is mine. 11.9kg completely stock with xtr race pedals. Still running tubes.
    Very happy so far. I've only had it about 11 days and done 300km on it. The XT gear is great. The brakes are brilliant. I don't think I would buy another bike with Avids again.
    I find the suspension very plush. I've been messing around with pressures a bit and now have about 30% rear sag and its great on the trail. Very comfy.
    I have a set of Ness carbon wheels to go on. They are only around 250grams lighter if the giant wheels really weigh 1750g. But I will also loose about 400 grams of tubes.
    Your Best Friend
    Only 3 of these on here? Hell, there are 3 riding out of our shop.
    2013 Anthem X Advanced 29'r - Early Release!
    I'll have to send some pics up later; but I've had mine since Dec 27th and after 100+ miles on it, I think I may have finally got it dialed in to me. Mine wasn't nearly as light out of the box as in earlier posts, (26 lbs 15 oz) so I went to work on making it lighter.
    I replaced the stock:
    SXC-2 wheels with Stans ZTR ArchEX with Industry 9 hubs (obviously tubeless)
    SRAM 1071 12/36 Cassette
    KMC X10L Chain
    Handlebar with Easton Haven Carbon
    Pedals with Crank Brothers Eggbeaters Titanium 11's
    Seat tube with Thompson Elite
    Rotors with Ashima AiRotors 160 mm
    and so far I've gotten it down to 25 lbs 8 oz, alot of money to get it just below what it was suppose to be, out of the box! Not sure how mine was almost a pound heavier that what some others have said. Maybe a difference in SRAM componants instead of the Shimano ???
    This is the link to my bike:
    2013 Anthem X Advanced 29er 2 (2012) - Bikes | Giant Bicycles | United States
    Quote Originally Posted by Amazed View Post
    It's probably a combination of a few things. The fork is about 200g lighter on the 1 vs the 2 (SID RL vs RL), so that's a half pound or so. The 1 comes with an X0 crankset, which is listed as 780g w/ BB. The S1000 that comes on the 2 is listed as 930g, so that's about .3 lbs. The component group will probably make up the rest as it's X5/7 vs X9/0.
    Your Best Friend
    @Amazed, you got the same frame as the higher two X29er Advanced models so work out from there.
    I just added a Giant Contact Switch dropper post to my bike and I'm still under 24lbs. Can't wait to get out on some dry dirt. Summer can't come fast enough.
    BTW. If any of you are ever out in Utah, look me up and I'll take you for a ride.
    Here is mine. 22lbs 8oz on the shop scale without pedals. It is a medium, all stock except for enve 700mm bar and tubeless.
    Attached Thumbnails Attached Thumbnails Post your carbon Anthem X29ers-giant-anthem.jpg
    davidcarson48
    Guest
    The early releases got screwed on the wheelset. The P-XCR-1 wheelset is under 1800 grams. Your stock is over 2000 grams.
    Your Best Friend
    Quote Originally Posted by davidcarson48 View Post
    He has an Advanced 2, they've always come with that wheelset. The 1 comes with the P-XCR1 wheelset.
    Unfortunately the wheels are tanks. I'd highly recommend looking at a set of Stans ArchEXs or even Crests. Serious weight loss to be had. If you have $1K, look into the American Classic Race 29ers. Really strong and uber light.
    Reputation: ha-evolution's Avatar
    2013 Giant Anthem X Advanced 29er 1 (early release)
    Weighs 24.8 pounds
    Small Frame
    Mavic SLR Rims tubeless
    Race Face Carbon Bar
    XT Brakes
    XTR Pedals
    rest is stock
    The original shock Monarch RT failed after two months. Local bike shop replaced it with a Monarch RL which was fine with me.
    This is my trail bike probably won't race it but it is a great ride. I agree on the dual air fork - it is awesome if it's setup right. Probably won't do much more to the bike just ride and enjoy as soon as the weather allows. Picked up a Fat bike to ride until then...
    Attached Thumbnails Attached Thumbnails Post your carbon Anthem X29ers-giantaxa29er-v2.jpg
    Quote Originally Posted by Silentfoe View Post
    Yepper, same frame. I just read several reviews prior to purchase that said Giant spec'd the 2 at 26lbs, the 1 at 24 lbs and the 0 at 22 lbs, my 2 was about a pound heavier than what I read.. Still got my eyes peeled for a good deal on a XX crankset and cassette; surely that should get me under 25 lbs.
    Of'course it would be much cheaper if I would lose the 20 lbs of body fat to really lighten the load... LOL!
    Your Best Friend
    Pretty sure the weights you read were from media releases. I haven't seen one yet that was close. My 0 (XL) was a hair over 23lbs out of the box. By going tubeless, foam grips, cutting down the handlebar/steerer and adding my Xpedo Ti/ti pedals I was at 22lbs 11oz.
    I've since added plenty of little things to include a dropper post and it brought me up to 23lbs 15oz.
    I love a light bike because it takes less out of you physically over a long trail but I like the comfort of the Ergon grips and saddle and the post will help over the difficult stuff. You build a bike for how you know YOU are going to ride it.
    davidcarson48
    Guest
    Blah, I missed that. Sorry.
    davidcarson48
    Guest
    I don't know if I'd go AC Race or the new Roval $1200 carbon rim wheelset. Decisions...
    Reputation: tosa's Avatar
    Just got my '13 Anthem X Advanced 1 29er Sat and took it to a local rock garden Sun. Short ride, but had a big grin on my face up and down the trails! Sorry, no pics, but it looks like the one on the Giant Web site, except I put on a 'new' 10 year old pair of carbon Time ATACs (I like those older ones better ), changed the seat to a Terry Fly and added a bottle cage. I'll go tubeless next and those will be only mods. My bike's mainly for me to get out and have fun while getting some exercise
    davidcarson48
    Guest
    Re: Post your carbon Anthem X29ers
    Quote Originally Posted by tosa View Post
    Nice! Enjoy the ride.
    2013 Anthem Advanced 1
    10.98kg
    Ness carbon wheels
    Easton EC70 flat bar 685mm
    ESI chunky grips
    XT cassette 11-36
    Selle Italia SLR gel flow saddle
    XTR race pedals
    Your Best Friend
    @Pistonbroke, you need to do us all a huge favor and make sure to do a good review of those wheels. Not much information for them online. From what I gather they are pretty much an Aussie exclusive, run $1334.85 US dollars and weigh in at a claimed 1470. The only unknowns are how they ride and if they'll hold up.
    Thanks in advance!
    Jun 2012
    I've seen that wheelset on the torpedo7 website. Great for the price. Don't they ship to USA also?
    They are heaps cheaper than the giant carbon 29 er wheelset. I like you silentfoe are interested in the flex, actual weight and longevity.
    Are they made in Italy?
    Yes I got them from Torpedo 7 and paid $750 plus $30 for the 15mm adapters. I have never seen them anywhere else. I didn't really know anything about them but figured someone had to try them first.
    Initial impressions unpacking the box is good. They are a great looking wheel set with bright red anodized hubs and nipples, black bladed spokes and of course the carbon rims. They came with some spare spokes and nipples and some nice red quick release skewers.
    I would give them a 7 out of 10 for the build and engineering quality. It would be an 8 but the bearings in the free hub were a little notchy from new. They don't quite have that absolute high end finish than you would expect from something like Cris King but you're also not paying those high end prices.
    The rear hub comes apart for servicing in seconds and has 24 points of engagement and 3 pawls(from memory). All bearing were Enduro branded. I had a little trouble putting a cassette on as the axle spacer seemed to have quite a large diameter. I had to modify my cheap cassette tool to fit. Maybe a better quality tool would fit straight on???
    I weighed them at 1490 grams with the pre installed rim tape but no valves. This is pretty close to their claimed 1470. I fitted Stan's universal tubeless valves. I used no other tapes or rim strips.
    I fitted 2.25 Racing Ralph Evos easily. They inflated pretty easily but I was using a compressor. Tyres seem to be quite secure and I've had no issues with burping or loosing air once I got the valves to seal.
    I first used these wheels on my 2012 Giant XTC Composite. They replaced the heavy stock Giant pxc2 wheels. Now this is a super stiff, responsive hard tail. And fitting these wheels didn't change that. Everything still felt super stiff and responsive. But the whole bike felt lighter and accelerated and climbed like never before. I have not noticed any loss of torsional stiffness in the steering as this is one area I am a little picky in. I have also not really noticed and great improvements in ride quality or some magical damping effect of carbon. They just feel like light fast wheels.
    I am now running them on my 2013 Giant Anthem Advanced 1. Nothing really changed. Still light, fast and more than stiff enough.
    Durability? I've only had them a few months but so far so good. I've done two 3 hour xc races on fast flowing fairly flat course with a few small logs. I've also done a 12 hour xc endurance race with a bit of everything. It had a few rocks, logs, g-outs, small dips and some good climbs. Everything is still straight and true. So with a few training rides I've probably done around 800km or 500 miles on them.
    I weigh about 80kg with gear on and was considering Stan's Race Gold wheel set. I was a little too fat for those but think I made the right choice. I'm not an aggressive rider and no pro. These are only the opinions of a weekend hack C grade rider. But my racing results do seem to have improved which really does prove these wheels have magical powers.
    Reputation: biketango's Avatar
    Silentfoe, you seem to know a lot about the Giant 29ers and it also sounds like you had some racing in your history too so I value your opinion here.
    I'm trying to decide between building up the new carbon Anthem or the XtC hardtail for this year's race machine. Currently on an Orbea carbon Alma. It is fast and handles quick with the short stays but I want something a touch more compliant and lighter. The Giant HT frame is almost 300 grams less and they went back to a 27.2 seatpost for a little compliance too, so on paper it seems I can get both wishes. But I keep reading good stuff about the Anthem and now with the Carbon I could get pretty light.
    Anyway, What are your thoughts?
    R U living to ride or riding to live?
    Your Best Friend
    Sorry for the late reply, I've been riding in 60* weather in St. George, Ut. :beer:
    Ok. The new carbon advanced sl xtc has "flexible" stays. The standard carbon xtc doesn't. Keep in mind they don't flex much and a hard tail is a hard tail. On longer rides it will still beat you up.
    I had my Anthem Advanced 0 down to 22lbs 11oz w/pedals. I've since made it my all around endurance bike and even put a dropper post on it. It now weighs exactly 24lbs. I've done over 75 miles in three days (more to come today) and I still feel great.
    If you can afford to lighten up an Anthem, I feel it will be a much more versatile bike than an XTC. If you were only going to be doing short XC races, then go for the HT.
    Silentfoe: which dropper post are you using?
    Edit: Just saw that you're using the Giant Contact dropper post. It's pretty light then I suppose?
    Your Best Friend
    Not really sure. I think it is just over a pound or so? I could find out someday.
    Sep 2012
    Would a Large frame be suitable for me? I am 6' 2 with a 35 inch inseam. I think there used to be a sizing chart but i can't find it?
    Your Best Friend
    Ha, unfortunately you are the same size as me. I went for the XL but then went down to a 100mm stem and turned the seat mounts around the other way (it's designed to do that to make 0 offset, not 25mm). I'd try the XL first.
    Dec 2011
    What he said. I'm 6' with a 32-33" inseam and have my seatpost on my L jacked pretty high up. I've got the 'full size' kronolog post (dropper) extended out an extra 1-1.5" from the min insertion... which looks "tall".
    Your inseam is a full 3" longer than mine, you'd be in the clouds on a large and probably blow out your back reaching for the bars.
    davidcarson48
    Guest
    Quote Originally Posted by Hauffy View Post
    I'm 6' 1.5" and a 35 inch riding inseam. I'm on a Large and it's perfect for me. With the stem at +8 degrees mounted at the top of the steerer tube and the riser bar, I'm very comfortable on the Large. I have about 1 inch of drop to the bars and the 400mm stock seatpost is plenty long, too.
    So my point is...ride both the L and XL.
    You can see my setup in post #2. My saddle was a touch high on initial setup, so it's about 5mm lower than pictured now.
    Enjoy!
    Your Best Friend
    This was my bike on Gooseberry a couple of weekends ago. XL. You can see how high my seatpost is with your same measurements.
    Attached Thumbnails Attached Thumbnails Post your carbon Anthem X29ers-uploadfromtaptalk1362096620137.jpg
    Sep 2012
    MMM i have a dilemma by the looks of it I picked up a Large carbon frame a few weeks ago,was a ripper price, and according to the sizing chart i saw it would have been ok. . It's about an inch shorter in the top tube than the bike i'm currently riding which fits me quite well. As the frame is practically brand new it would be better to sell it as is than build the bike, find out it's too small, then sell it for less. Decision time :/
    Your Best Friend
    You do have a dilemma! I'd sell it honestly. Tough call but I can tell you straight up that the frame is too small for you. Shouldn't be too hard to unload it.
    Epic rider
    Reputation: rapsac's Avatar
    Sep 2004
    Size chart giant uk. However, real life test or comparison with your current bike it's horizontal top tube length is probably a better method.
    Attached Thumbnails Attached Thumbnails Post your carbon Anthem X29ers-uploadfromtaptalk1362208164245.jpg
    12 Anthem X29
    13 XTC 29
    07 Epic Marathon carbon
    04 Stumpjumper FSR Anniversary
    03 Stumpjumper FSR Pro
    00 Rockhopper Pro
    My ride, still waiting for some upgrades to arrive and more time on the saddle to setup the cockpit, still snow over here.
    (Euro-version + Rotor cranks, Mount Zoom handlebar, xt-pedals and carbon bottle cage.
    Reputation: dpastore22's Avatar
    Interesting read on the bike size recommendations. I'm 6'1" with 35 inch natural inseam (competitive cyclist method for measuring inseam). I was fortunate enough to see the Giant demo fleet at my local trails here in GA. I'm on the cusp of riding either a Large or XL. The guys working the demo recommended the XL. The XL fit me really well, I think I would just swap out for a shorter stem. I wanted to throw a leg over the Large but it kept getting snatched up every time I arrived back to the demo trailer. Local shop has a Large in stock, I'm going to throw a leg over it with my measurements and see how it feels.
    davidcarson48
    Guest
    I'm 6'1.5" with a 35 inseam (same method). I also demo'd the L and XL Anthems and ended up on the Large. Stock stem (100mm), stock bar (19mm rise), and stock seatpost. Uncut fork and I'm running the spacers under the stem and the stem angled up (positive). I'm nowhere near the minimum insertion line on the seatpost.
    After two back surgeries, I can tolerate only a slight drop from saddle to bars (about an inch or so).
    Interesting... I'm definitely looking forward to riding the Large now and see how it feels.
    Reputation: BacDoc's Avatar
    Another comment on sizing, I'm 6'2" with 34/35 (true) inseam and have been on an Anthem X 29 2011 size large for almost 2 yrs. this was my first 29 and thought that the jump to big wheels in the large size would be right since my riding is mostly tight tech single track. My fear was the bike would feel too big in XL and hard to navigate tight trails. Reality was different, as I tuned the cockpit and seat post I found myself running a lot of post and spacers under the stem. It worked but I personally think these bikes handle better with shorter stem and less seat post than I was using. The large came with the stock 110mm stem and I tried a 90mm which felt perfect as far as handling but cockpit felt short. I was running a set back post and seat was way back on the rails to get my KOP.
    This was a 2011 aluminum frame but I think the geo is the same. Now I have my large for sale and just bought an advanced frame size XL and can't wait to get it. At my height I don't have excessively long arms or legs and the large just felt small.
    Hope this helps with those making the size decision.
    Sorry for all the photos but I am very excited to have to have this build finished. The bike started last October as a neglected Anthem Advanced 2. I bought it from a person who thought it was a downhill bike and maybe did not have the best skills. I almost feel that I rescued this bike. Stock the bike came in at 27.5 lb. I have swapped out every thing except the shocks, headset, stem & bottom bracket. Currently the bike is 23.17 lb with 270g pedals. I feel that I have built this bike with the best "bang for a buck" and reliable components. The seat my look scary but is amazingly comfortable and feels like an SLR if you are accustomed to that style of seat.
    This bike is set up for northern Utah (Park City, Corner Canyon) classic single track, long climbs followed by long descents. I have a Spec Stumpy Evo for my down south (Moab, St. George) road trips.
    Post your carbon Anthem X29ers-img_1719.jpgPost your carbon Anthem X29ers-img_1743.jpgPost your carbon Anthem X29ers-img_1602.jpgPost your carbon Anthem X29ers-img_1741.jpgPost your carbon Anthem X29ers-img_1737.jpgPost your carbon Anthem X29ers-img_1736.jpgPost your carbon Anthem X29ers-img_1732.jpgPost your carbon Anthem X29ers-img_1731.jpgPost your carbon Anthem X29ers-img_1729.jpgPost your carbon Anthem X29ers-img_1728.jpgPost your carbon Anthem X29ers-img_1726.jpgPost your carbon Anthem X29ers-img_1723.jpgPost your carbon Anthem X29ers-img_1722.jpgPost your carbon Anthem X29ers-img_1720.jpg
    For those of you who are weight weenies below is a complete breakdown of components and weights.
    Anthem AdvanceX 29er
    Frame Long Der Cable, Replaceable Dropout 2,443
    Headset 67
    Shock RockShox Monarch RL
    Fork RockShox Reba 29 RL w/ 15QR thru-axle, OverDrive 2, 100mm Travel 1,568
    Thru-Axle 73
    Headset Spacers 32
    Headset Cap 11
    Headset Cap Bolt 7
    Grips ESI grips MTB Chunky silicone grips, black 55
    Handlebar Loaded X-Lite 141
    Stem Giant Connect SL, OverDrive 2 90mm 145
    Seat Post Woodman Carbo EL 30.9 400mm 147
    Seat Clamp Giant 26
    Saddle Tioga Spyder Twin Tail 145
    Pedals Crank Brothers Candy 270
    DRIVETRAIN
    Shifters XT Rear 143
    Rear Derailleur Shimano Zee Shadow + 270
    Cable Housing 10
    Disk Brake Front Magura MT-2 250
    Disk Brake Bolts Magura 12
    Brake Adapter Brake Adapter 24
    Adapter Bolts Brake Adapter Bolts 9
    Rear Brake Magura MT-2 266
    Brake Bolt Brake Bolts 12
    Roters Magura Storm SL 180 119
    Roters Magura Storm SL 160 96
    Disk Bolts Steel 8
    Disk Bolts Alloy 8
    Cassette Shimano XT 11-36T 339
    Chain Sram 266
    Crankset SRAM XX1 175 156q 562
    Bottom Bracket Sram Press Fit GXP 90
    Crank Boot RaceFace 16
    F Wheel Stan's Crest F 726
    R Wheel Stan's Crest R 858
    Rear Skewer DT-Swiss Thru Bolt RWS skewer 66
    Chainstay Proctor 15
    Downtube Protector 6
    Frame Savers 3
    Tubeless Valve Stem 16
    Notubes Latex 110
    Tires Schwalbe Racing Ralph, 29x2.25 Performance Folding 529
    Tires Schwalbe Racing Ralph, 29x2.25 Performance Folding 551
    10,510g 23.17lb
    Your Best Friend
    Hey! That's the Peak View trailhead. I was there each of the last three days on my Anthem. Maybe we'll run into each other sometime.
    I would love to meet up some time and pick your brain on suspension set up. I have read your other posts on set up and I think I am on the right track, but suspension set up has always been a black art to me. The floodgate on the R shock has too many positions (like 14).
    Redbird1998
    Here is my Giant Anthem X Advanced 1. It's an early release 2013 which I like because the production was limited and I've yet to run in to anyone with this same bike. Changed the wheelset, of course, with Stan's Crest laced to the new I9 torch hubs. Thomson seatpost, Fizik Antares carbon rail saddle, Crank Brothers Cobalt 11 carbon bars and Ergon GX-1 grips. Weighs in at 24 with no pedals.
    Attached Thumbnails Attached Thumbnails Post your carbon Anthem X29ers-image.jpg
    davidcarson48
    Guest
    Great looking bike. Love the frame colorway.
    Reputation: ejreyes6's Avatar
    Dec 2010
    Just finished this extra small Anthem x29 4 for my wife. Started at 30 lbs.
    upgraded to:
    Stans Crest ztr wheel set( tubeless)
    2013 Reba tapered
    Sram 1x xo drank with 32t Wolftooth XX1 style
    Deore brakes with RT66 160 mm rotor
    Syntace carbon flat bars
    Slx medium cage shadow + derailluer
    Xt cassette
    Fizik vesta saddle
    Saved 2220 grams (4.89 lbs.)
    Your Best Friend
    Got bored yesterday and rebuilt the entire back end of my Anthem X 0. It needed some love after 1300+ miles. I also pulled and rebuilt the bottom bracket. Pretty straight forward and easy to do.
    Attached Thumbnails Attached Thumbnails Post your carbon Anthem X29ers-uploadfromtaptalk1374070065096.jpg
    Reputation: OperatorBo's Avatar
    Mar 2011
    Here's mine. Just got it last Thursday. Love it. Best bike I have ever owned. Raced it last night and knocked 6 min off my race time.
    All stock right now. Going to do some upgrades over the winter.
    Vassago VerHauen SS
    Salsa Horsethief
    davidcarson48
    Guest
    Did you have any play/roughness in the pivot bearings? So far, I've only had to change out the DU bushing in the shock after about 500 miles.
    Your Best Friend
    No, it was just really dirty and I was getting some creaks from the BB. I figured while I was in there...why not. I greased up the faces of each bearing and it runs really smooth right now. Better than new.
    davidcarson48
    Guest
    Good deal.
