Results 1 to 6 of 6
Thread: Overdrive 2
    Overdrive 2
    I'm trying to understand Giant's Overdrive 2 system. Can the fork be swapped on to another mtb other than Giant? If not, can I send the fork back to Fox and them install a different size steer tube?
    2014 Giant Anthem X Advanced 1 29er
    2012 Specialized Stumpjumper EVO HT 29er
    Reputation: socalrider77's Avatar
    Pretty sure no and no. Specifically made for the od2, and as far as I know steerer tubes cannot be swapped
    2014 Giant Trance 27.5 3
    Reputation: MTB_ZA's Avatar
    Oct 2014
    to use a standard fork you can replace with a standard bearing, so I would assume that you could use an OD2 fork on another bike as well if you used the correct bearing. my understanding is that the headtubes are the same... someone correct me if im wrong im just going on what ive read in the past
    Nov 2012
    ^that's my understanding as well.
    As long as you have the (upper) OD2 headset (and stem!) you're good to go.
    2016 SC 5010
    2017 Norco Torrent
    2014 Giant Trance (the boy's)
    2014 Kona Process 134a (the other boy's)
    Your Best Friend
    Reputation: Silentfoe's Avatar
    The replies are correct. It all comes down to the upper bearing of the headset.
    I'm a mountain bike guide in southwest Utah
    Sep 2012
    yep, dropped the OD2 fox 32 talas that came on my trance for a standard F34 Factory. Just had to replace the upper bearing and cup to standard, as well as stem.
  1. Overdrive on 27.5+
    By gregers05 in forum Diamondback
    Last Post: 10-14-2015, 09:03 AM
  2. Replies: 4
    Last Post: 05-31-2013, 06:49 PM
  3. 2011 reign 2 overdrive or overdrive 2?
    By chef7734 in forum Giant
    Last Post: 01-12-2013, 11:12 AM
  4. Overdrive Pro
    By 45ronin in forum Diamondback
    Last Post: 09-28-2012, 08:48 PM
  5. Overdrive XC!
    By stop619 in forum Diamondback
    Last Post: 04-20-2012, 07:45 PM
