Results 1 to 3 of 3
    Reputation: madsedan's Avatar
    Aug 2010
    OK, question about Giant's Anthem rear hub before I order new wheels, I'm stupid...
    OK, the specs for the 2014 Anthem 27.5 I bought say its convertible rear between 10x135 and 12x142. The rear skewer is a screw in DT Swiss that appears as thing as a normal skewer.
    Is the rear wheel a 10x135 but the bike will accept either size? Just trying to determine if a friend can run these wheels on his normal QR rear bike.
    Hardrock 29er, Niner EMD9, Cannondale F29, Camber Expert, 650b Nickel all gone.
    2014 Giant Anthem 27.5 here.
    Mar 2011
    I believe normal QR is 9mm, I've ran 10mm bolt on hubs (hope pro 2) in regular 9mm dropouts. Shouldn't be an issue.
    Fat-tired Roadie
    Nov 2007
    Take your rear wheel off. If you're still not sure, post a pic of the wheel and whatever you pulled out to be able to remove it.
    Rear QR axles are 10mm in diameter. The QR itself is maybe 3mm, give or take. If you're using a through-axle, you'll actually be removing the axle itself, which is 12mm in diameter. So as soon as you start removing stuff, I think you'll know the answer.
  1. Replies: 7
    Last Post: 11-29-2013, 09:02 PM
  2. Replies: 8
    Last Post: 07-22-2013, 04:32 AM
  3. Giant Anthem X29er - rear derailleur question
    By jkirkpatri in forum Giant
    Last Post: 11-14-2012, 05:11 PM
  4. Replies: 1
    Last Post: 06-20-2012, 06:36 AM
  5. Giant Anthem rear triangle differences?
    By Hedge72 in forum Bike and Frame discussion
    Last Post: 03-17-2011, 07:13 AM
