    Niner EMD
    Reputation: nygeo's Avatar
    NRS Rock Shox bushings...
    I recently had my TOP bushing replaced with a newer MUCH more stable and sturdy bushing set. I was wondering...what about the bottom? Is there a need to replace the bottom bushing as well? Its not clunking at all...so is there a reason I should replace it?
    thanks
    "Drinking and driving is wrong, but hey, the kids gotta get to school right?"
    -Dave Attell
    Niner EMD 1X10
    [paste title here]
    Reputation: mtnbikerdude87's Avatar
    Well most NRS' had problems with the top bushings and I think it was solved with the sturdy bushings you speak of. I dont think anyone had problems with the bottom bushings. So you should be fine.
    Keep Pedaling
    Quote Originally Posted by mtnbikerdude87
    My 2003 NRS2 had the same bushing problem and they were replaced under warranty but not with the heavy duty replacements and now they are knocking again and this time it is the bottom bushings that is causing the trouble. Does anyone know if I can deal with ROck Shox direct or do I have to go to a dealer?
    [paste title here]
    Quote Originally Posted by VaNRS2
    I would go back to your LBS and tell them that the bushing problem is back. Its weird thats its happening to your bottom one now. Try giving RS a call and tell them the problem, maybe they can help you out. Giant CS is pretty good so dont give up. Maybe youll end up with a new frame! Good luck and I hope your bike gets fixed!
    Keep Pedaling
  1. judy rock shox TT 2004 model $ 110-Good?
    By zach in forum Downhill - Freeride
    Last Post: 05-25-2004, 06:45 PM
  2. 2003 Rock Shox Psylo Race
    By NRSAirDriver in forum Shocks and Suspension
    Last Post: 03-22-2004, 08:48 PM
  3. Rock Shox Discs?
    By Threesticks in forum Brake Time
    Last Post: 03-18-2004, 08:00 PM
  4. Rock Shox disc rotor with different calipers?
    By bhutata in forum Brake Time
    Last Post: 03-15-2004, 04:18 AM
  5. Rock Shox '05 info
    By angryasian in forum Shocks and Suspension
    Last Post: 03-03-2004, 02:08 PM
