Results 1 to 11 of 11
    NRS replacement rear shock
    A friend's 2002 NRS SID blew out this weekend. I see that the new NRS's come with a Fox AVA Air. What have others replaced their rear shocks with after the SID's?
    Reputation: bertt's Avatar
    Some people have went with a Cane Creek. I myself went with a Cloud Nine. Cane Creek is running a upgrade offer where you get $100 off either a Cloud Nine or AD-12. Here is a link.
    http://www.canecreek.com/site/home/index_c.html
    Do a search on this board the question has bent brought up alot.
    Al.
    Al. is offline
    Hooligan
    Reputation: Al.'s Avatar
    choices...
    I looked into this when my SID died about a year ago. I ultimately went with the Cane Creek Cloud 9 as well, but there are a few other choices. If your friend does not want to have the SID rebuilt (Rock Shox can do it, or hipi-tech), the choices I remember include the Fox you mentioned, cane creek, Risse (they can make one to fit, just call or email them), and Manitou. The Manitou swinger 3 way was not available when I was looking, but it might be a good choice now, although I don't know much about that one.
    The Fox AVA on my '04 NRS works pretty darned well. If you can get one from Fox with the NRS valving then that is the way I would go.
    Does he like the SID XC?
    Quote Originally Posted by jdcowboy
    If he liked how it rode, I say get it rebuilt by Rock Shox. My LBS could not do it. It cost $175 (I thought that was STEEP!!) but basically Rock Shox gave my a NEW shock. Everything was new. The rebound adjuster was different as well, that's how I know they just replaced it instead of rebuilding it.(and I had secrect marks I made on it which weren't on the new one.)
    I have tried the CC AD-12. Didn't care at all for it. The rebound and compression settings were very very finicky.
    I don't know how the Fox AVA is, but it may be nicer than the SID.
    Sep 2004
    Quote Originally Posted by Wheelie
    The geometry and setup is different on the '04 than the earlier models. I'd double check that the AVA would give you the right performance on a pre-04 model.
    mtbr remember
    Reputation: BikeSATORI's Avatar
    I'm running the SGF rockers and my SID seems to be leaking air too. Haven't decided what to do, as I hear the Cloud9 is too soft to combine w/ the SGF's. Might start looking for a cheap used SID?
    Schralp it Heavy.
    Reputation: mtbcyclist's Avatar
    I got the leaky shock issue to with the SGF rockers. Much over 200 PSI and I have to refill it all the time. I am however going to eventually buy the Cloud 9 shock and run the SGF rockers. I figure it is to soft, I just add a little more air pressure to it just like I do with the SID.
    \|/Home of the Braves\|/
    Reputation: RedRocker's Avatar
    Go with a Cane Creek shock, you'll definitley see lots of posts on here from happy owners. I don't think I have seen any posts from people who have tried a Fox on a pre-'04 NRS. I don't know that an NRS needs a stable platform shock like a ProPedal or a Swinger. If I had any other XC bike I'd go with a 3-way...
    Man, $175 is STEEP. I had a Cloud 9 serviced by Cane Creek for $75.
    Big hoopy.
    Turner Sultan / On One Inbred
    Upgrade Addict
    Reputation: johnmre's Avatar
    Go with the Cloud Nine...
    I have one and love it. I bought it under that $100 off promo directly from CC for just a bit more than your rebuild will cost. I used my SID for about 6 months before I replaced it to try to get a bit more small bump compliance with the CC Cloud 9. I'll sell you my old SID if you want it. I was going to hang on to it in case I ever wanted to go back. I don't.
    I still have my SID too. I was planning on keeping it around for the day my Cloud 9 needs some service and I still want to ride the NRS. Agree with you about never going back!
    Big hoopy.
  1. Service Tip for all Cane Creek rear shock owners
    By TeamTwentyFour in forum Shocks and Suspension
    Last Post: 06-13-2006, 01:23 PM
  2. If you need to know this.
    By KevinVokeyJ24 in forum General Discussion
    Last Post: 12-24-2004, 09:40 AM
  3. Replies: 45
    Last Post: 10-12-2004, 12:04 PM
  4. NRS SID rear shock rebound setting?
    By ekin in forum Giant
    Last Post: 06-09-2004, 08:10 PM
