Thread: NRS Question
    Bianchimtb
    NRS Question
    I have an NRS and got a 120mm fork for it.
    IS this a problem?
    Whatever hurts you, can only make you stronger
    bi-winning
    Reputation: rkj__'s Avatar
    Other people have done it, though many balanced it out with after market rear rockers to increase the rear travel as well.
    It will make your bike handle differently.
    Some people will tell you the longer fork puts extra stress on the headtube. As long as you have some sag, i wouldn't think that you are putting the frame at a high risk of failure.
    The Notorious S.L.O
    Reputation: btadlock's Avatar
    without increasing the travel on the via extended rockers, not sure how raising the front end, thereby moving the weight bias more towards the rear would affect the handling and the performance of the rear shock.
    I would like to increase the travel on my 05 NRS as well, but apparently, there is no one making the extended rockers.
    BT
    11 Trek Hifi Delux 23in
    05 Giant NRS 22.5in
    Evergreen Co.
    "All I need is.......two wheels and the truth."
    i have set up my NRS G with a FOX Float 130
    i ride the bike very hard both on and of road and so far it seems to be fine with no signs of damage
