Here's a pic of my NRS-SS from not long ago .. a well scratched 2004 Frame - not many original parts left, and some being replaced soon!
The chain was shortened to an appropriate length after taking the pics. The wheels have since been replaced by an XT M775 wheelset with XT (RT78) rotors and Maxxis Monorail eXCeptions with tubes. Weight must be approximately 11.5kgs (25 pounds.)
A Monorail LUST is going on the rear soon and both wheels will lose their tubes. I've ordered a pivot bearing kit from BETD to replace the still-original squeaky bushings and bearings missing their seals. I wouldn't mind more chain-wrap around the rear cog. I need to fix the bottle-cage bolt mounts, and shorten brake hoses .. I'm sure there's more I could plan! Anyway, parts list:
Factory:
frame - Giant NRS2 2004
shock - Fox Float Vanilla R AVA
cranks - Race Face Ride XC
stem - Easton EA50 120mm (6 deg?)
bars - Easton EA50 630mm low riser
seatpost collar - Giant
Changed:
Fork - Rock Shox SID Race 2008 Black @ 100mm
Brakes - Avid Juicy 7 2007
Wheelset - Shimano XT M775
Rotors - Shimano XT Centrelock RT78 160mm
Tyre Front - Maxxis Monorail eXCeption 2.1 62A
Tyre Rear - Maxxis Monorail eXCeption 2.1 62A
Chainring - E-Thirteen G-Ring 32t Red
Derailleur - Shimano Alfine Dual-pulley Chain Tensioner CT-S500 Silver
Cassette - Fire Eye FE-SSK Single Speed Spacer Kit - Red - 16t
Chain - SRAM PC890 8sp
Headset - Ritchey WCS semi-integrated
Bottom Bracket - Token (model unknown) ISIS
Seatpost - Easton EA70 350mm*30.9
Saddle - Selle Italia SL XC, White/Black
Grips - DMR LOCDD Black (Without Flange)
Pedals - Shimano SPD M520 Silver (the factory ones were black!)
Coming soon:
Grips - DMR LOCDD 2009 - White/Black (Without Flange)
Bars - FSA K-Force Carbon XC 30.8mm, 660mm wide, 18mm Riser Bar 2008
Stem - FSA OS150 100mm/6deg
Tyre Rear - Maxxis Monorail LUST 2.1 70A
