Results 1 to 31 of 31
    NRS Bushing Bearing kits
    Well, I thought that based on the general response last month to having the kits available that I would easily sell 8 (it was all I could get complete parts for). Turns out only 6 people needed the kits.
    I was quite mistaken that this is something that NRS riders wanted. I will be parting out the remaining bearings (552) and bushings (465) that I have. I won't bother with the sleeves they are just to expensive for me to stock any amount.
    See my ad in MTBR classifieds, with the link to eBay.
    Later.
    Got the Backordered polymer bushings. Rebuilt the NRS too.
    460 to be exact. And the 600 bearing, well, actually 552 since I sold 8 kits. Seems the local manufacturers are doing decent business. I am having a difficult time getting the quotes for the spacer sleeves. The only supplier that has an equivalent part is overkill. I'll keep pestering the manufacturers , as I can lower the kit cost by $10 if they can be made for close to $1.00 each.
    I also rebuilt the NRS. Rides like new.
    Al.
    Al. is offline
    Hooligan
    Reputation: Al.'s Avatar
    I also rebuilt my NRS (2002) with your kit - and it does ride like new. The bearings behind the bottom bracket are a PIA to install though.
    Thanks.
    Quote Originally Posted by Al.
    Thanks.
    Very good to hear about the results! And yes, if the bearing starts slightly crooked into the bore, they can be difficult to press in. Especially the larger main pivot bearings. It's not impossible though. A little patience. Did you find the pictorial manual was OK? If you can recommend any changes, I would be glad to hear them.
    John
    Al.
    Al. is offline
    Hooligan
    I have replaced the rocker arm bearings previously, and cleaned the rear bushings, so I only referenced your manual for the bottom bracket bearings, which I had no experience with. The C clamp and a socket did the trick for those. I did not disassemble the entire rear end to do this, but worked on one part at a time.
    First, I removed the swingarms (by the way, the SGF rocker arms use the same size bearings as the stock rocker arms) and replaced those bearings; I added new seals to my canecreek cloud nine while I was at it, then reinstalled the swingarms and the shock. Second, I replaced the bushings and sleeves in the back and reassembled. Finally, I disconnected the lower swingarm at the bottom bracket pivot and replaced the last bearings. Then tightened everything back up. I did not have to remove the rear derailleur this way.
    Your manual was precise and complete. No complaints form me.
    Al.
    Al. is offline
    Hooligan
    Paging John...
    Hey John,
    I need some new bearings for the rocker arms, (2002 NRS, 2 pair) not a whole kit, do you still have those to sell, or could you list the size bearings I should order? thanks in advance.
    Response sent
    Hey John,
    I sent you a reply Al. No problem. Plenty left.
    Reputation: bertt's Avatar
    complete kit
    Quote Originally Posted by John
    Do you still have any of the complete kit's available?
    Yes, some lft
    Quote Originally Posted by bertt
    Send me a PM and I will get back yo you ASAP Bertt
    Reputation: NRSguy's Avatar
    will these bearings fit the '01 or are they for the newer NRS
    also how much for the complete kit?
    Quote Originally Posted by NRSguy
    They fit 00-03 . The 04 went full cartridge bearing in the dropout pivots.
    Semd me a PM for pricing tables and payment methods.
    John
    Feb 2005
    need bushings
    John,
    I need a full set of bushings and bearings for a 2002-3 Giant NRS 2. How can I order and or pay for same?
    David
    They'll need to be shipped to Baltimore
    Sent an eMail
    Quote Originally Posted by idratherride
    John,
    David
    I sent you an email. There are kits available.
    No Brakes
    Reputation: No Brakes's Avatar
    New question here. Need set of bushings for '01 NRS
    John,
    Could you let me know the cost (kit + shipping to CA) and payment method? Thanks very much.
    Al
    Quote Originally Posted by No Brakes
    John,
    Al
    Contact me at ( johndoiron at sbcglobal dot net ) . You can figure out my email address, I did it that way to fool spambots. Replace "at" with @ ect.
    Payment usually through PayPal. One kit is $23.75, but two is only $30.54. I have a price list for up to 10 kits. Prices above are mailed First Class USPS.
    Trail Sanitizer
    Reputation: Bulldozer's Avatar
    John -
    Please forgive the newb question but how do you change out the bearings? I have an '03 NRS and I'm switching out the rear shock (Cloud Nine) and rocker arm (SGF) so I thought I may as well swap out all the bearings while I'm at. However, I have no idea how to do it. What tools do you need? Assuming it's easy, I'll probably buy a couple of kits from you.
    Posted this somewhere else but I forget where.
    Quote Originally Posted by Bulldozer
    John -
    I think I posted this somewhere already. But here it is again. 2 ways to do it, the fast brutal way, and the slow careful way.
    1) Fast way. Use a tapered punch through the center of the bearing and smack it out with a hammer. First Picture shows the teapered punch through the center of a rocker bearing.
    2) Use a couple sockets and a large C-Clamp to press the bearing out slowly.
    Fake Athlete
    Reputation: tumblindice's Avatar
    NRS pivot kit
    John, I hope you have kits leftover, I need one for my '03 NRS2?
    I like ham sandwiches
    May 2005
    Bushing kits
    I have a 02 NRS 1 and am needing an entire bushing kit, do you have any left? If no,t do you have a good source to go to for bushing kits?
    Yes, some left
    Quote Originally Posted by maxout
    Send me an email at jpd_06010no-spam@yahoo.com . Remove the "no-spam" from the emaill address.
    John do you have anymore of these kits
    I am looking for this kit and how much is it?
    I have a 2003 NRS and I think my bearing are bad. I have replaced the bushings.
    Specialized Fatboy
    Reputation: NRS1FREAK's Avatar
    S***... I should get a couple of these kits since I'll probably need them and since the NRS is being phased out it might be harder to find.
    Mar 2005
    Nrs bearing bushing kit
    Dear John
    I have got Giant nrs frame I think it is 2000 model (disc model)
    I want to change rear pivot
    could you help me
    nboran@ttnet.net.tr
    thanks
    Bonking ... not feelin' well
    Hello,
    can anyone help me source an upgrade kit or bushing replacement kit for my 2003 NRS?I prefer an online store.
    Thanx.
    Reputation: Smidge's Avatar
    If your in the UK BETD (Gold Tech) do a bearing kit for the NRS. http://www.betd.co.uk (i think they will send to anywhere in the world though)
    Also Johns post regarding fitting the bearings (photos and all) can be found here:
    Changing Bearings: What tools are needed?
    Regards
    Smile
    Quote Originally Posted by Smidge
    Regards
    Thank you very much, i already bought and install a kit from BETD and it is brilliant except for the price, as you need 2 sets of GBP 70 each to replace all the teflon bearings from the NRS frame. Even they were not certain, so i ordered only one kit and i stayed with the teflons in the upper ligament.
    Cheers!
    Fotis
    I purchased the complete kit to replace all bearings in my NRS for £55 from BETD
    Reputation: laackund's Avatar
    Sep 2004
    John- do you still have any of these kits available
    do you still have any of these kits sitting around? how much is it if you do, and if not do you plan on getting any more?
    anyone who has used it, whats the durability like?? ive seen only good things on here, but no reposts after using it for a while.. shoul di assume good???
    Mar 2005
    bushing kit
    Hello
    Where can I find bishing and bearing kit for my nrs giant 2000 model frame
    thanks
    Dec 2010
    I see no action has been on this post, but taking a chance. Do you have any kits left? If not, any suggestions?
    Sorry, it's all over
    Quote Originally Posted by clydezjr View Post
    It's been quite some time since I made kits, and I don't even own the NRS anymore. I never bought another Giant bike, never will. They give up on their older frames and don't support after only a few years. I loved that bike but Giant really pissed me off. I waited 2 months for parts. They never came through. So that's why I initially built the kits. I had 100's of aluminum sleeves with teflon hardcoat made, but all the kit's are sold.
    The major wear items were the rear horst pivot aluminum sleeves and the flange bushings. It is possible to make the sleeves if you have a friend in the machine tool trade, not very difficult to make. The flange bushings can still be bought from a company called IGUS. They were in Rhode Island, not sure anymore.
    Remember when measiuring the parts, everything is metric in millimeters. Don't try and find parts in english dimensions. I used to have prints for all of it but it's all gone.
  1. NRS Bearing and Bushing Kits- Finally
    By John in forum Giant
    Last Post: 07-13-2004, 07:59 AM
  2. NRS Suspension Kits -SOON!!
    Last Post: 06-30-2004, 07:42 PM
  3. GIANT NRS suspension kits... REAL SOON
    By John in forum General Discussion
    Last Post: 06-25-2004, 05:43 PM
  4. NRS bushing kits?
    By paqrat in forum Giant
    Last Post: 06-09-2004, 04:31 PM
  5. WTB/amclassic disk hubs..
    By bike_freak in forum Weight Weenies
    Last Post: 02-05-2004, 06:30 AM
