Results 1 to 30 of 30
    New XTC owner and a question?
    Just picked up this composite beauty yesterday. I am looking for a suggestion for a 2 X 10 bashguard . I ride a lot of rocky terrain with a lot of logs and know the outer ring will be toast in a hurry if I don't do something quickly. It is possible that this has been covered, but if so, I could not find the thread.
    Suggestions, or pics would be much appreciated!
    Attached Thumbnails Attached Thumbnails New XTC owner and a question?-giant.jpg
    Mar 2011
    Nice bike !
    Fat Is Where It's At Moderator
    Reputation: DiRt DeViL's Avatar
    Check the BCD and hole pattern of your big ring (prolly 4/104) and get the according bashguard of your linking.
    Are you considering a chain guide too?
    Mar 2011
    uhm don't understand bikes still looking.
    I want to buy a mtb for myself to
    sorry i can't help you .
    Can't buy a bash guard for this bike because of the spider setup which is a 120 BCD. Also no chain guide available because the bottom bracket is a press fit therefore nowhere to mount the guide. Not the end of the world I guess, but a pretty dumb design if you ask me... Thanks John, I love the bike so far.
    Once you get your first one, you will be hooked!
    Mar 2011
    one guy is selling one for 1900
    but i only have 1500 damn it!!
    Mar 2011
    i am a little bit mad that i don't have the 400 extra
    If you can get one for $1,900.00, that is a great deal, especially for a 2012 model
    Mar 2011
    i know how many did you for yours ?
    i don't know if you have ridden xtc 1 or 2 29er
    does it feel the same ?
    Just did a few mods...
    New Stan's Arch Wheels with Geax Saguaro TNT's(tubeless), DT Swiss 240s rear hub. Loaded Stem and Seatpost... Carbon Bontrager Bars, Ergon Grips.
    Still haven't ridden it, but soon!
    Attached Thumbnails Attached Thumbnails New XTC owner and a question?-bike-012.jpg
    Mar 2011
    nice racey looking bike beat up the streets drive drive it like you stole it :P
    Quote Originally Posted by A-Ray View Post
    The MRP 2X or Truvativ X-Guide which are both essentially the same thing will get you both a bash guard and a chain guide that will fit that bike
    Reputation: weeksy950's Avatar
    Quote Originally Posted by weeksy950 View Post
    I think the OP wants to keep his 2x10
    Quote Originally Posted by pamt View Post
    Yes I would like to keep the 2x10 if I can. Still a cool chainguide, Thanks.
    Maybe I could find a used outer ring, and grind it into a bashguard, then just go1x10.
    You've got me thinking!
    Reputation: ha-evolution's Avatar
    Have you weighed it yet? I want to get this bike and like the look of the 1 but want the components of the 0.
    Mar 2011
    what is the frame size of your bike might i know 16 or 18?
    got my mind set on a xtc composite 0! standing beside you with me bike :d
    Feb 2012
    Really nice bike...Like that hub....
    I am a brand new rider and just ordered a xtc 29er1.........I think that is a 3X....Would that take standard guarding.....???
    Has not been weighed yet, but this thing is light. Hoping to weigh it next week, will let you know when I know.
    If I were to guess, I would say somewhere in the 23-ish range? Also, even though it is X-7, and the brakes are Shimano, everything works extremely well. I was actually shocked how well the brakes work. Was going to put new Avid Elixir R SL's on it, but may not now...Also ditched the Ergon grips today and bought some bright yellow Specialized Lockons.
    Thanks for the info - I'm thinking I'll get the 1, replace the wheels with Stan's, and maybe upgrade the brakes to the new XT and call it good.
    Oct 2011
    hey well
    i just weighed my xtc is between 12-13kg
    i don't have one one of those more accurate scales but it is a lot lighter than my old bike that weighed 19kgs
    so i suppose i don't mind it being that i suppose some people think that is heavy but consider it light enough for me
    Quote Originally Posted by ha-evolution View Post
    You should consider a Stem and post too. The stock stem is pretty heavy. Carbon low rize bars are also a must when funds allow. If you do not ride super hard, I would also suggest Crest wheels over the Arch's. They are lighter, but not quite as bombproof...
    Good ideas thanks. I have a carbon race face bar that I never got around to putting on my AX1. Any ideas on stem and post? Not sure about the Crests as I weigh 180 and don't want to have to worry about fragile wheels.
    Well, I have a Loaded Precision X-Lite Stem and Post. I am a huge fan of their components, light and very strong, and in a lot of different colors. Stem weight is only 100 grams! The only thing is that the Giant Stem angle is 8", so, unless you have a low rise carbon bar, you may feel a bit leaned over with the Loaded Stem, as it is only a 5 degree angle at 100mm length. I am right around the same weight as you and the Arch's are perfect, I am a pretty aggressive rider so I thought the Crests would be a little too light...Good luck with your bike!
    Brought my bike over to my LBS and weighed it. Exactly 24lbs., 8oz (EDIT) .
    With some drivetrain mods like a lighter crankset, lighter tires, and lighter brakes I should be able to lose quite a bit more if I want to......
    Then we weighed the exact same bike bone stock without pedals and it was exactly 25 lbs. 7 ounces...
    Brought my bike over to my LBS and weighed it. It was teetering
    between 23lbs.-15 ouces and 24lbs., so I will say 24lbs. even. If I took my computer off, it may have gone the other way....
    Sounds light enough. I ended up going with the 1 even though I liked the color/finish of the 2 better because I got such a good deal on it.
    A-Ray what size is your bike? Do you know how much of weight difference in the allux version and the carbon?
    Picked up my Comp 0 last week and it weighed in at 23 lbs 3oz with XTR pedals and Mavic C29ssmax wheels. I have a carbon fiber handlebar coming so it should shave a bit more off the weight.
    The dealer told me the weight difference between the aluminum and carbon frames was half a pound.
    Mine is a medium. Stock the bike was in the 25-1/2 to 26 lb. range. Unfortunately I do not know what the Aluminum version weighs, but I would guess at least 8-10oz. more with the same components???
    Aug 2010
    I have a large 2010 XTC1 (aluxx). Weighed 26.7 at local shop
  1. Replies: 7
    Last Post: 02-16-2012, 12:29 AM
  2. New Kona Unit owner
    By Dictatorsaurus in forum Kona
    Last Post: 01-30-2012, 12:13 PM
  3. New RDO owner questions
    By tws_andrew in forum Niner Bikes
    Last Post: 01-18-2012, 06:11 PM
