    Need help far a friend with NRS
    hi there, my riding buddy has an NRS comp 04 with an alloy rear end. Recently, when he has been moving it around, he has noticed some play in the rear end, ie when picked up by the seat post there is a noticable drop from the rear triangle. He has not noticed this before but does not mean it is not normaly there. He is worried that there might be wear in the bearings. He does tighten every thing about every 2 weeks so there is nothing loose. Any ideas will be appreciated. Thanks, bat.
    Get your freak on!
    Chances are something is worn.
    Look at enduro seals - http://www.enduroforkseals.com/id62.html
    This kit is great value, much cheaper then giant own bearing kits, and this one is higher quality.
    You will have to check and see if his frame has bushings or bearings in the chainstay pivot. The newer frames have bearings.).
    Get your freak on!
    Double post
    Thanks freak
    Thanks for that will let him know and will have to email to see if they will post to the uk.
    bat
