Results 1 to 5 of 5
    RZK
    RZK is offline
    Need 100mm+ fork suggestions
    I am in the process of upgrading my 02 NRS. I wanted to go with something more cush without getting a 4 inch+ travel freeride rig. I decided to go with a set of 4.5 rockers and need a longer travel fork to go with it.
    I haven't kept up much with the parts scene, so I am a bit out of it. Can someone suggest a nice 100mm+ fork to go along with my rockers?
    psylo w/ uTurn
    I have the 4.5 rocker and I installed a RS Psylo w/ uTurn to fine tune the geometry. I run the shock at 85mm most of the time, XC type terrain. For some downhills, I will crank it up to 130mm. I chose the uTurn feature because I was not sure what the longer rockers would do to the handling of the bike. I really like the setup.
    I have a 2003 NRS-2. I just ordered the 4.5 inch rocker arms and a Marzoochi MX Comp fork 105 mm travel with ETA (extension travel adjustment). When you turn the ETA knob on it lowers the fork to 30 mm travel for climbing. You can turn on the ETA while you are riding, you don't have to stop and get off the bike like other adjustable travel forks. The lower travel setting will be great for steep climbs as it shifts your weight forward.
    ekin
    RZK
    RZK is offline
    Thanks for the advice guys. I did some research of my own and bought myself a Manitou Minute One. Like both of you, I like the fact that I can adjust the fork to any travel between 100-130mm. I wasn't sure what the rocker would do to the geometry, so I went with a fork with adjustable travel. I also liked the fact that it has the SPV no bounce thing going for it. Maybe, it will balance out the "no-bob" thing in the back. I even got a pretty good price to boot through "Flee-bay". Hopefully, it will work out well.
    Anything fox or Marzocchi
    Quote Originally Posted by RZK
    You won't be disappointed
  1. 100mm fork too much for Schwinn Homegrown?
    By Haggis in forum Shocks and Suspension
    Last Post: 02-03-2006, 12:54 PM
  2. 100mm fork on a Surly 1x1?
    By Earthpig in forum Singlespeed
    Last Post: 04-22-2004, 12:46 PM
  3. Replies: 5
    Last Post: 04-14-2004, 08:19 AM
  4. Good deal on a 100mm fork
    By DiRt DeViL in forum Where are the Best Deals?
    Last Post: 01-20-2004, 02:14 PM
  5. Options for a light weight 100mm fork?
    By KMan in forum Weight Weenies
    Last Post: 01-19-2004, 02:22 PM
