Results 1 to 12 of 12
    Reputation: cardnation's Avatar
    Jul 2014
    Maestro pivot service intervals?
    What are your habits/methods? Clean only, clean and grease? What kind of grease...etc?
    Was is the norm for a full bushing replacement? What bushing kit is the go to?
    Thanks for your input!
    I bike with tires.
    Reputation: Steel Calf's Avatar
    Feb 2010
    Normally I do buy a new bike before the pivots are completely shot (and leave the headache to the 2nd owner) but this time I may actually live out the bearings on my Trance SX so interested in some first hand reports too.
    I only flooded them with grease once last year (they came stock pretty empty, same with the headset) to prolong their lifespan but haven't changed out any of them so far.
    WillWorkForTrail
    Jun 2012
    I've had the pivot bearings on my Anthem changed out once. If there's a lot of water involved and you have to clean things out, just a couple drops of light oil should be fine, really. The gold standard for when it needs maintenance is to let all the air out of the shock or unmount the shock on one end so the linkage can move freely - then it should, in fact, move freely. If it has notchiness to it or the movement isn't smooth, then I'd have the bearings replaced.
    And here's a thought on replacing bearings. Yes, Giant makes a special tool kit with a special press set for Maestro stuff. Yes, it's expensive. In fact, my LBS had to buy one when my bearings were replaced the first time. And they ARE a Giant dealer. I've seen a couple people say they've done the work themselves using bolts and washers and such to press the bearings in - that's all well and good, but if you have a frame problem later, and Giant denies a warranty claim because the bearings were pressed in wrong - well, let's just say I'd rather have the LBS on the line for that rather than me being cheap. In other words, if you care about the warranty on your frame, get the LBS to replace the bearings for you when the time comes.
    Aug 2015
    I replaced the pivot bearings on my '10 Trance X3 this year. Threaded rod, washers and nuts of various sizes. Went pretty smooth. One of the bearings was in very stiff and took some paint off the recess as it came out. I had some Honda white touchup paint that matched okay. Job went well and got rid of a creak I had.
    MTB B'dos
    Reputation: LyNx's Avatar
    If they're still working fine, then just clean out and repack them, if you want to extend the life, when you have the linkages apart, rotate them, change when notchy.
    Putting in aftermarket bearings was a huge upgrade to my bike. I highly recommend replacing all the suspension bearings. I did mine after a year ~2000 miles
    Much improved ride and smoother overall.
    Dec 2005
    My 2014 Trance SX is in need of new bearings. Replaced the DU bushing, which was not that bad, but still a bit of play. Seems to be coming from the bearings that are on the seat tube where the shock mount is attached. Everything is tightened properly, so it must be bearings.
    Will take it apart and see what is worn. Not too bad in my opinion in getting almost a full 2 years on them.
    Will report back on how much fun it was.
    Jan 2017
    I suggeat using the Giant Maestro bearing extractor/replacement tool kit. Last thing you want to do is damage the bearing housings on your frame (or scratch your paint work) Rather difficult to come by in Aus. (Comes in a handy presentation box so looks good at home on the mantle piece -not)
    Giant Reign 27.5 2 LTD
    Reputation: ka81ua's Avatar
    Oct 2014
    Delete
    OK
    Jan 2017
    Oct 2014
    Better video while using them..
    OK
    Reputation: minimusprime's Avatar
    I just had the pivots replaced on my 2015 trance. A few things to note:
    1) Mileage was some where around 1300 miles
    2) Most of my bearings were in ok shape, however two of the larger ones that make up the front lower pivot (goes in the shaft side eyelet of the shock) were completely seized. I think this is due to the little water/sand/dirt catcher that is located on the bottom of the down tube and that the lower shock eyelet sits in. The other bearings spun freely but a few were a bit crunchy.
    3) I had a bit of creeking in the frame that I was chasing. I was convinced it was the bottom bracket, or seatpost or something, the creeking went away after I had serviced the bearings.
    4) I had some strange wear marks and wear grooves on a few of the pivot bolts. Namely the two shock pivot bolts and the two seat stay to rocker link pivot bolts. The Giant kit included all new pivot bolts, spacers and all associated hardware.
    5) Even with the two seized bearings in the lower eyelet, the suspension performance seemed completely fine. However, after doing a before/after ride I can tell that some small bump compliance was suffering. I didn't notice this because the degredation was so slow.
    I perform quite a bit of maintenance to my bike. Most of my buddies would tell you that I'm way over the top. I do hose down my bike when it's really muddy, but other then that it usually gets a wet rag wipe down from a bucket that has a few drops of dish soap in it. I always keep the bearings clean and I keep a thin layer of grease on them. I typically tear the pivots down and wipe them off once a month (or once every 6-8 rides).
    This winter in socal has meant a lot of mud, but typically my bike lives in dry and arid conditions. I ride the crap out of this bike from everything to shuttles, bike parks and all day XC/Trail Epics. I treat and ride it like an AM bike, so I'm guessing I'm wearing out parts faster then most trance owners.
  1. RS Monarch RT3 - Service Intervals, Air Can Only?
    By bopApocalypse in forum Shocks and Suspension
    Last Post: 02-23-2016, 12:27 PM
  2. VPP grease port service intervals
    By yeahdog31 in forum Santa Cruz
    Last Post: 03-07-2014, 11:19 PM
  3. Fox CTD Shock Service Intervals
    By fakemind in forum Shocks and Suspension
    Last Post: 08-26-2013, 05:55 PM
  4. New Fox service intervals
    By bad mechanic in forum Shocks and Suspension
    Last Post: 04-28-2012, 11:28 AM
  5. Question on service intervals
    By straycatkid in forum Shocks and Suspension
    Last Post: 01-24-2012, 01:18 PM
Members who have read this thread: 4
