Results 1 to 3 of 3
    Maestro - does it use chain torque
    Just wondering if maestro uses chain tension to prevent bob. I have an anthem 27.5 and am trying to tune the suspension, it feels a little stiff on the small roots and rocks. Wondering if I can tune that out with a revalved shock or is that just a characteristic of maestro.
    Aug 2013
    It definitely does, if you look at it from the side, the chainstays lengthen, particularly during the initial travel. However, i've never felt it was detrimental to small bump sensitivity (i'm on a coil sprung ReignX), so i think you should be able to improve your suspension by tweaking the air pressure and compression damping.
    WillWorkForTrail
    Jun 2012
    I doubt you need a revalved shock to turn out the stiffness in the small bump compliance. Increase your sag a little (lower air pressure) or dial back a little damping, but it should be able to deal very easily with plushness on small bumps without bottoming out on "big hits" (remember, it's an XC bike, it's not like you should be hitting big drops on it, a larger G-out should be the biggest compression you get).
  1. Maestro Torque specs?
    By nm_gunslinger in forum Giant
    Last Post: 01-08-2016, 06:16 PM
  2. Torque Spec for Chain Guide
    By maw77712 in forum General Discussion
    Last Post: 05-26-2013, 09:15 AM
  3. Replies: 14
    Last Post: 01-23-2013, 11:41 AM
  4. Help! New chain, grinding sounds under torque ...
    By OldSkoolMark in forum Singlespeed
    Last Post: 08-15-2012, 01:22 PM
  5. Chain drops off under high torque MB
    By BÁdn@ked in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-19-2011, 05:38 PM
