Results 1 to 3 of 3
    Loud "whack" sound on G-outs on my Trance XO 29'er
    A couple of times now when I hit some deep ditches and "g-out" the suspension, I hear a loud "whack" that sounds like metal on metal. The first time I thought it was a rock thrown up to the frame, but now I've heard it a few times. I released all the air and collapsed the suspension and can't see any areas where there's metal to metal if it was bottoming out. When I compress it, it goes well below the level the rubber o-ring has been pushed, so I don't think I'm bottoming out the suspension.
    Anybody else experience this?
    I have had the same thing a few times. I assumed it was the suspension but have not taken the time to investigate further. I suppose it is possible that on a square edge input it could be that the fluid cannot flow through the orifices in the damper fast enough causing an almost solid reaction. This could be what we feel.
    Dec 2012
    check rear derailleur? mine was making a similar sound which I thought was suspension...ended up being a sticky clutch on rear derailleur...
  1. XX1 "shifts loud"?
    By trhoppe in forum SRAM
    Last Post: 03-27-2013, 05:58 AM
  2. Replies: 4
    Last Post: 02-24-2013, 12:09 PM
  3. Replies: 0
    Last Post: 08-28-2012, 07:14 AM
  4. "Click" sound when applying brakes (disc)
    By jsilva in forum Brake Time
    Last Post: 09-22-2011, 05:56 AM
  5. I have a "Ticking" sound coming from my crank
    By SAVAGESAM in forum General Discussion
    Last Post: 07-07-2011, 12:12 PM
