Results 1 to 6 of 6
    I want the VT, but am worried about the saris car carriers.
    I have the saris bones two, and am slightly concerned that when I buy the VT, I wont be able to put it on the carrier. Does anyone have any experience with this???
    thanks
    ryan
    Reputation: Spongedog's Avatar
    the telescoping tube...
    The rack I have barely fits my VT inner triangle. If you have a bottlecage in there, the saris rack does not work. I have seen a product, but I can't remember the manufacturer, that is a telescoping bar which locks on to the bike just under the stem on one end, and to the seatpost on the other. I believe that will make the VT work with any rack.
    Reputation: WotFun's Avatar
    Yep this works.
    Quote Originally Posted by Spongedog
    I think this is the worst thing about the VT - getting it on a rack - but with one of these telescopic tube adapters - no problem. Just make sure you get one that will fit around the aheadset. Dont let this put you off getting a VT !!!
    Cheers.
    Saris makes a bar that will work, It's called teh Graber(Saris) bike beam. Almost any LBS shoyld be able to order it for you. Retail on bike beam is $29.99.
    Reputation: bikeCOLORADO's Avatar
    Sep 2003
    Quote Originally Posted by ILxcMTNbiker
    Umm...ditto. My buddy rides a Gemini, his wife a super small Jekyll. Both frames are impossible to load without a conversion bar. It's super simple and quick to use.
    http://www.sarisproducts.com/products/bikebeam.htm
    http://www.rackattack.com/prod/Yakim..._Bike_Rack.htm
    "I may be old and fat, but at least I'm slow." - Me
    Smile I have a post in New Products and Inovations
    [This adapter will work on a NRS & VT. I have both and have and it works. Just get a seat post piece the correct size and attach it to either a piece of steering tube (with a star nut) or any piece of tubing and use a long bolt, washer and double nut. It will require a bit of cutting with a rat tail file or dremel to make the pieces of tubing fit together.
