Results 1 to 6 of 6
    I ordered an XTC2 but should I switch to an NRS2?
    I ordered an XTC2 cause i found a great price for it but then found out later that I could get an NRS2 w/o disc brakes for $50 more. Should I cancel the order and make the switch? I havent tried out the NRS2 yet and I will but i just wanted to get peoples opinion first . I am a total newbie to mountain biking and i plan to ride easy trails for now since i am totally out of shape. What would you guys get?
    Quote Originally Posted by abmw
    I say go for the NRS if it's only $50 more. I started off with Giant Boulder SE... a month later I went to a NRS. Look at it this way in the long run you wouldnt have to upgrade to a full suspension later on when you get better.
    Reputation: 1-bar's Avatar
    hell yeah for $50 its well worth it... Is this for an 04 NRS?
    yeah its a 2004 w/o disc brakes
    the 2004.5 is like 140 more
    i just weighed my 04.5 and its 27lbs even in stock trim minus reflectors. For the $140 in price, you are getting a solid frame that is light weight with a great anti bob suspension design. You can easily spend more then $140 just trying to lighten up a heavier bike. Good luck with your decision.
    Reputation: borregokid's Avatar
    I think it depends on if you race or not or just plan on riding around town quite a bit. If thats in your plans then I would stick with the XTC. If you plan on hitting some rougher type trails then maybe the NRS
  1. I ordered an XTC2 but should I switch to an NRS2?
    By abmw in forum Beginner's Corner
    Last Post: 05-26-2015, 02:38 PM
  2. I ordered an XTC2 but should I switch to an NRS2?
    By abmw in forum Bike and Frame discussion
    Last Post: 07-16-2004, 09:05 AM
  3. bighit comp vs. switch
    By rockymountainbiker69 in forum Downhill - Freeride
    Last Post: 06-29-2004, 11:28 AM
  4. Fuel 90 vs NRS2
    By wolfmansbro in forum Bike and Frame discussion
    Last Post: 05-25-2004, 09:17 PM
  5. Anyone out there switch to SRAM from XTR?
    By thatguy in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-20-2004, 11:20 AM
