Results 1 to 20 of 20
    29er and 26er
    Mar 2012
    Caution;  Merge;  Workers Ahead! Thru axle fork / hub assembly on a '11 Talon 1 stock fork
    To make a long story short I took off my front wheel for the first time to replace the tire. I wasn't paying that much attention and all of the parts and spring(s) fell apart from the axle and its housing.
    I *think* I have all the parts, and I think they are put together properly.
    Can someone tell me how I can tell if I got it put back together properly?
    Thanks in advance. I feel like such a noob!
    Fat Is Where It's At Moderator
    Reputation: DiRt DeViL's Avatar
    You accidentally disassembled the axle, can't help because I no longer have that fork but have you emailed or visited the manufacturer website?
    29er and 26er
    Mar 2012
    Quote Originally Posted by DiRt DeViL View Post
    The da*n web site has no usable information on that fork. I may have to visit my LBS and talk to the mechanics there.
    Click Click Click
    Reputation: dirtbyte's Avatar
    I am sitting here wondering how that is even possible? Do you mean the fork? That fork is a 15mm thru axle hub. Do you mean you disassembled the hub? Not sure how you could "accidentally" do that just to change a tire.
    29er and 26er
    Mar 2012
    Quote Originally Posted by mtbdennis View Post
    The fork does not have a drop out. So to remove the wheel from the fork I unscrewed the quick release all of the way and pulled it out along with a tube with various springs and parts. Thus my problem.
    I'm gone for the weekend so I will take a photo when I return.
    29er and 26er
    Mar 2012
    Here are a few pics
    Any help would be appreciated. Thanks!
    Reputation: cigarlover's Avatar
    Oct 2011
    I have the same fork- so I would love some info on this also ???
    29er and 26er
    Mar 2012
    Quote Originally Posted by cigarlover View Post
    Can you take a close up photo of the non quick release side? I suspect I'm missing a little part. Thanks.
    The Photo above DOES show the correct way to assemble the parts.
    29er and 26er
    Mar 2012
    Bump!
    Can anyone tell me if I have my parts aligned the correct way from the picture in post #6 Also am I missing any parts?
    Thanks in advance!
    Click Click Click
    Why? Why would you want to intentionally dis-assemble the quick release axle? This is a "quick" release fork and hub. You just open the quick release lever and pull the axle straight out and then remove the wheel, easy as pie. No need to disassemble the axle to get the wheel off.
    29er and 26er
    Mar 2012
    Please examine the photo of the actual fork in post #6. There is NO Drop Out!!!
    I've never seen this before, and it explains why I removed the axle.
    Do I have a one-off fork? Someone has had to run into this with their Talon in the past. I just want to make sure I have it put back together correctly.
    Thanks in advance for any help.
    Click Click Click
    Quote Originally Posted by p08757 View Post
    I have the same exact fork, the whole purpose of a thru axle fork / hub is that there is no drop out. I will post some pictures of how this works later today.
    29er and 26er
    Mar 2012
    Many thanks! This will help me keep my mind!
    Reputation Points added to your account....
    Click Click Click
    Here you go...
    First, open the quick release lever:
    Then with one hand hold the quick release lever in the open position with one hand, with the other hand on the other side of the wheel push the round part to the left of the red clamp toward the center of the wheel, then with the hand on the quick release side, pull the entire quick release bar out of the hub / fork.
    Remove the wheel and do your stuff, then replace the wheel, and with the quick release lever in the open position shove it back in there until you hear it click (I do not think it matters which side you put it in (I put mine in so that the QR part is on the opposite side of the disc brake.
    Then close the quick release lever.
    There is no need to ever disassemble the quick release axle in order to remove the wheel (that would kind of take the "quick" out of quick release, LOL)
    I hope this helps you guys. They showed me all of this at the shop when I purchased the bike, otherwise I may have been wondering the same thing.
    Dennis
    29er and 26er
    Mar 2012
    Thanks Dennis! I've never seen this before, and I have it assembled wrong now. I will fool with it and get it assembled correctly in short order now.
    Question -- When things are assembled correctly and the quick release is locked, should I see any of the red piece showing?
    Click Click Click
    Yes, it should look exactly like the last picture in my post, except the QR lever would be closed, but you would see some of the red part. Once you get the hang of it it really is a pretty nice setup. Pretty much all of the thru axle hubs are like this (or similar). This is actually a nice feature of this otherwise crappy fork.
    29er and 26er
    Mar 2012
    As soon as I figure out the correct way to assemble the axle I will post correct pictures. so if anyone else ends up in my shoes this thread will help.
    I will now edit post #8 to reflect that the picture shown is NOT the correct way to assemble the parts
    29er and 26er
    Mar 2012
    This IS the correct way to put it back together. I didn't push it all of the way through so the red part was showing when I went back to install it.
    Click Click Click
    So, are you back up and running?
    For those people with this fork, please keep in mind that this is NOT the way to take off the wheel. This is a quick release QR15 hub. Just follow my instructions above. You do not and should not disassemble the axle to remove the rim/tire from the bike.
    29er and 26er
    Mar 2012
    Yes I'm back and running with it installed properly. Thank you very much for your help!
